[/ATTACH] View attachment 3324102 1927 Ford Coupe Hotrod If you want the baddest ride don't let this one p*** you by.... I have combined the best of different eras and included some hidden modern technology. If you aren't ready for stop light launches, wind in your hair, screaming pipes and the object of desire, then this is not the ride for you. This is all bare metal with Gibbs Oil on it. The windows are Lexan and tinted blue. The headlight holders are brake shoes. The window cranks are ratchets (waiting on parts for the windows to install the door windows) Custom perimeter 2x4 ch***is. The perimeter frame allowed me to channel it 3" and yet still drop the floor down 3" for added leg room and allows you to sit more relaxed. 3 link ladder bars, Coilovers. Reversed Corvair box. SBC 350 with **** crank and rods, small domed pistons, Thumper camshaft, World S/R Heads 3x2 carbs on Offenhauser intake Lake Headers have baffles (still sounds mean) New Aluminum Radiator and electric fan 350 turbo trans (just rebuilt) B&M ratchet shifter 3.73 Posi rearend 4 Wheel Disc Brakes Tilton dual Mastercylinders 37 Ford front axle, new Kingpins and roller bearings, spring, chrome shocks and tire rod ends Custom All Steel Interior (clear coated) Bear claw latches with engine valves as poppers LED Turn Signals the front are hidden and the rears are in plain sight but appear hidden Built in 2 port USB charger and phone holder Everything is either new or has been rebuilt this year. There is no top for it. CLEAN CLEAR Illinois ***le and is currently registered in Illinois, so no ***le worries. 815-483-0815 View attachment 3324102
