Technical Better lighting for MOON gauges?
Discussion in 'The Hokey Ass Message Board' started by 6-bangertim, Sep 16, 2016.
  1. 6-bangertim
    6-bangertim
    I have the trip-gauge set from MOON, only the voltmeter is easy to read at night - despite being futher away (mounted under the dash). Oil and water gauges are mounted in the dash, next to the key-switch. (HATED that a PO cut into the dash - but it is a good, visible location.) Seems like the gaps to let the light in are larger in the voltmeter, than the water and oil.
    Is there a BRIGHTER bulb I could try in the socket? I can't think of a way to split the gauge apart to tune-up the gauge-face gap a little, for more light. Any ideas? Thanks, Tim
  2. 19Eddy30
    19Eddy30
    from VA
    Yes, & there is a bulb spec chart ,
    Also led spec chart
  3. WDobos
    WDobos
    I installed led bulbs in my SWs and that did the trick
  4. dicer2000
    dicer2000
    Would you mind posting a pic of how you mounted your gauges? Thanks
