Projects Rehpotsirhcj’s 30 Flathead Coupe
Discussion in 'Traditional Hot Rods' started by Rehpotsirhcj, May 30, 2010.
  1. Rehpotsirhcj
    Rehpotsirhcj
    I'm getting ready to get the front and rear axles mounted to the frame so I thought I'd mount some new tires to get the height right.... the neighbors think I'm nuts :D
    I'm working a side job and selling off every spare part I have for new Cokers and the axle drop.
    chryslerfan55 and brEad like this.
  2. Rehpotsirhcj
    Rehpotsirhcj
    Maybe one of the most cluttered shop spaces on the Hamb. I think I'm pretty close on the trans mount location. I couldn't resist throwing the cowl on there. Cant wait to have a roller.
  3. 343w
    343w
    Isn't it funny when the (non-rodder) neighbors come around and look at what's going on with a project build, it's like we're from another planet or something. And they say," you're going to get that thing on the road!" "It will take you years to finish that thing." And I say,"and you point is?"
    chryslerfan55 and kidcampbell71 like this.
  4. Rehpotsirhcj
    Rehpotsirhcj
    Can you spot the A-bone parts a**** the clutter? :D
    Got my axle back from Greg (296V8), turned out great.
    Waiting for my bushing reamer to arrive so I can hang the spindles.
    I ordered spring perches without paying attention to the length. These are longer to allow for a lower shock mount. I haven't thought out my shock location, so I don't whether I can use them or not.
    My goal at this point is to get the front and rear end mocked up and bolted to the frame so I can locate the motor/trans and x-member.
    chryslerfan55 and Vic Walter like this.
  5. chopt top kid
    chopt top kid
    That right there is one of Henry's finest!!! and 296V8 made it just right!!!;)
    And don't sweat the small stuff!!! Size does matter!!!
  6. Mr48chev
    That looks like it is coming along nicely. And it appears that it was you that had the A frame for sale on Craigslist a while back.
  7. Rehpotsirhcj
    Rehpotsirhcj
    I'm going through serious hot rod withdrawal.
    I'm building my shop and have zero time for my much neglected pile of **** parts.
    I'm super excited at the prospect of an actual floor, but damn, I'd rather be buying tires and a wood kit instead of 2x8s and roofing.
    Rant over.
  8. Rehpotsirhcj
    Rehpotsirhcj
    A bit of an update.
    My shop build has set me back quite a bit, and move in day is still a ways off.
    Still, I've been working a bit as I have time. I'm planing to ***emble the body over the winter.
    I worked the worst of the thrashed metal and stick welds out of the drivers side top, and cut out little template to help line everything up. Its still very rough, but its coming together slowly.
    I'm going to level the subrails on the A-frame and hang the posts etc. with the wood kit, and then begin the patchwork.
    last pic (off-topic I know) is the coupe's new home in progress.
    Outback and chryslerfan55 like this.
  9. Rehpotsirhcj
    Rehpotsirhcj
    I started working on the new real subrails yesterday and, while I was at it, decided to go ahead with a mini-channel for a better fit to the 32 frame. I'm going to cut down the front legs of the firewall, curve the lower edge etc. so that it retains a stock look. I'll use the existing rivet holes on the top edge.
    It fits and looks much better on the frame now, no gaps.
  10. Rehpotsirhcj
    Rehpotsirhcj
    Worked a bit more over the holiday weekend.
    Once I started to pull the body back, closer to where it should be I found (as I suspected from other threads) that I needed to spread the fire wall to make up a bit of the width difference.
    Crazy teenager with a camera
    Split firewall, now its roughly where it should be on the frame and the channel is just about 3/4 of an inch
    started modifying the firewall "feet". I'd like it to look as stock as possible when they're finished.
    these small mods so far really helped get rid of the gap between the subrails and the frame
    Finished mocking up the new rear subrails and hung the quarters to start
    getting everything lined up where it should be.
    Sloooowly coming together.
    That's all I have for the moment.
  11. AHotRod
    AHotRod
    Do you have heat in the shop?
    That little boy of yours is now 4 years older, right?
    Keep pushing on!
  12. mad mikey
    mad mikey
    Nice job, coming along well!
    lothiandon1940 likes this.
  13. Rehpotsirhcj
    Rehpotsirhcj
    thanks, appreciate it.
    Yup, he's six now. I'm not winning any races with the build, that's for sure.
    Only a kerosine heater in the shed, its okay unless it gets below freezing. We're hoping to be in the new shop by next winter.
    chryslerfan55 and lothiandon1940 like this.
  14. Rehpotsirhcj
    Rehpotsirhcj
    Deck lid!
    I've been looking for one for quite a while.
    Anyone have experience (tips or tricks) in separating the skin from the inner panel?
  15. Xman
    Xman
    Just found your build. I really like what your doing. Take your time, do it right and do it your way. Love it!
  16. Rehpotsirhcj
    Rehpotsirhcj
    Thanks a ton, I'll do it my way..and probably suffer the consequences, oh well.
    I really like what you've done with your 34, even though it will likely be a "useless pain in the ***" :D. Hope to check it out one day.
  17. Xman
    Xman
    Did you stop at the Saturday Amocat get together this year during the Good Guys in Puyallup? Do it if you can next year. I had my duece there this year.
  18. Wildbill29tudor
    Wildbill29tudor
    Subscribed! Great thread
  19. Rehpotsirhcj
    Rehpotsirhcj
    Move in day!
    Still lots to do on the shop, but time to start building again, I'm Stoked!
  20. Uncle Bob
    Uncle Bob
    from Salado, Tx
    You need more junk Chris, I can still see floor........................:D
  21. Rehpotsirhcj
    Rehpotsirhcj
    Everything went on the floor so I could move the old shed over to my neighbor's house. It looks much better at his place than mine : )
  22. Rehpotsirhcj
    Rehpotsirhcj
    Frame table in the works!
  23. kidcampbell71
    kidcampbell71
    Congrats' man. I have to say that I was happy to see no snow when you built the work space....I say that, only because of the snow on the ground....flathead pulling pics'. That's a man possessed there ! It's nice to have parts ****tered, rather then parts stacked. Big difference. Room to breathe....and air out !! Good luck!
  24. Rehpotsirhcj
    Rehpotsirhcj
    Okay, so I think this might be the longest running build on the HAMB, and with no end in sight...in my defense, I did build a shop, and enter grad school.
    I have a few more years before my boy is driving, so here we are : )
    Striping fixing and fitting the body panels this winter. The doors seem great so far, lots of work yet to do on the quarters .[​IMG]
  25. Uncle Bob
    Uncle Bob
    from Salado, Tx
    There's an old saying, "it's about the journey, not the destination.....", or some such. Just keep pluggin' away Chris......
    Hitchhiker likes this.
  26. swifty
    swifty
    You sure like working with wood don't you. Wooden wheels on your rear axle, wooden body trolley, wooden shop. I think you should swap the coupe for a woody LOL
    Good to see some progress and any progress is good.
  27. Rehpotsirhcj
    Rehpotsirhcj
    Found a rear panel on CL that still has the stock brace. Not in bad shape, but I'll never understand the thinking behind a half inch of Bondo. Note that the panel is completely accessible from the back side. My floor was pink. :)
  28. BLUECOLLARKUSTOMS
    BLUECOLLARKUSTOMS
    Keep it up, if you're like me, finding a usable part at a swapmeet is just what is needed to get back at it and keep the project going.
  29. Rehpotsirhcj
    Rehpotsirhcj
    Finally some time to work on my project!
    I pulled the skin from the deck lid and worked out the largest of the dents. All four edges need to be replaced, so still a lot of work to do.
    I'm missing the p***enger side trunk drip rail/channel in case anyone has a lead.
  30. Rehpotsirhcj
    Rehpotsirhcj
    The never ending, never finished coupe.
    But, new frame rails, so I'm happy.[​IMG]
