1931 Ford Model A Sedan
Discussion in 'Cars For Sale' started by Crusty Nut, Sep 15, 2016.
  1. Crusty Nut
    Crusty Nut
    City: Eureka, Ca
    State: California
    Price: 21,000
    1931 Ford Model A 4 door sedan hot rod.
    Fun little sedan with a stock height Briggs body. All steel except for hood and grill shell
    Fully boxed Model A frame with a rear Z and cross member to clear rear axle
    In the rear is a narrowed 9" Ford axle with detroit locker, 3.50 gear and Strange SS axles, coil overs and 4 bar
    In the front is a Super Bell axle, TCI wishbones, mono leaf spring, GM disk brakes, and Unisteer half rack steering
    Engine is a stock 1974 454 with a Weiand intake, spread bore Holley carb, and a high torque starter. It's cooled by a Walker radiator with A/C condenser and trans cooler, Also has a Cooling Components shroud and fan. It runs 190* no matter the weather
    Stock 700R-4 transmission
    GM tilt column and heated, electric reclining seats
    Custom 20 gallon fuel tank behind the rear seat
    8" power brake booster, proportioning valve, and Optima battery mounted under the floor
    I'm listing this for a friend. He is hard of hearing so phones are a little tough, and doesn't do computers. He built this up over the last few years and has lost interest as land speed racing has taken most of his time. The car has about 5000 miles on it, the engine has much more but runs like a big block top. Clear ***le, drive off into the sunset. $21K or offer.
    Thanks for looking. I can be reached at 707-599-2315. -Matt
  2. Crusty Nut
    Crusty Nut
  3. Crusty Nut
    Crusty Nut
  4. Crusty Nut
    Crusty Nut
  5. Crusty Nut
    Crusty Nut
  6. Crusty Nut
    Crusty Nut
  7. Crusty Nut
    Crusty Nut
  8. Crusty Nut
    Crusty Nut
