Folks Of Interest Early Stewart Warner gauge thread
Discussion in 'The Hokey Ass Message Board' started by Pat Pryor, May 13, 2016.
  1. ChuckleHead_Al
    ChuckleHead_Al
    this panel will get the police special speedo, its a early stewart warner panel that i made a new insert for, ive never seen any liturature on them but it had a sw part number on it. it has the early 2" smooth bezel gauges
    another set of the 2"rs ive collected[/QUOTE]
    Wish I could afford a Fuel and Temp gauge, they're so expensive. Hoping to get lucky one day.
    Speed~On likes this.
  2. Seems to me that the 2" tulip water temp is the hardest to find.
    Rochesters:
  3. alchemy
    alchemy
    Oh God! Now the 2" SW's are getting expensive too?!
    ChuckleHead_Al likes this.
  4. ChuckleHead_Al
    ChuckleHead_Al
    Yes, the fuel gauge averages around 700 bucks, the Temp, well I've never seen a Temp gauge for sale. Some of the guys that posted have them all [emoji12] [emoji23] [emoji28]
    Sent from my SM-N920P using The H.A.M.B. mobile app
  5. alchemy
    alchemy
    How many do you want?!
  6. ChuckleHead_Al
    ChuckleHead_Al
    I wish I could get a Temp and Fuel gauge, but unfortunately I cannot afford them.
  7. RICH B
    RICH B
    Okie Pete and kidcampbell71 like this.
  8. Pat Pryor
    Pat Pryor
    kidcampbell71 likes this.
  9. Pete
    Pete
    Goddam ***us !
    That's quite a gauge collection.
    heavydumper and kidcampbell71 like this.
  10. RICH B
    RICH B
    I hope that means the roadster is being restored; I was intrigued by that car when it was on ebay all those years ago and always wondered what happened to it. Have you posted anything more about it?
  11. Pat Pryor
    Pat Pryor
    Not yet, I'll start a build thread soon.
    Okie Pete, kidcampbell71 and RICH B like this.
  12. These had been in storage for about 50 years when I got them. They are (so I'm told) out of a 1938 Allard.
    I posted in this thread by Ryan from 2006 and got some info (that I no longer have)...
    http://www.jalopyjournal.com/forum/threads/early-tachometers-teach-and-win.134755/#post-1507915
    They were in this '32 roadster that was built in 1949-50...
    10 years later, I still have them and they are still wearing the same dirt. Probably about time I cleaned them up (a little). I'm concerned about damaging them, any ideas for cleaning without messing them up? I have no interest in "restoring" them, just want them clean and functional.
  13. alchemy
    alchemy
    Big A, those speedo and tachs have three small screws holding the bezel and gl*** onto the bucket. You can undo those screws and carefully remove the front ***embly. Be careful though as all the inner rings and gl*** will be loose, so don't drop them.
    Clean the rings and gl*** as you wish, replace the gasket material with some fresh stuff from the parts store (might take some careful knife work to cut the round shape if you don't have a comp*** cutter like I do). You can remove the inner workings from the bucket with two more screws on the backside of the bucket. A couple drops of sewing machine oil in obvious spots is all it will hopefully need to make things spin easily. I don't recommend removing the needle from the guts, or using anything except light compressed air to clean the faces. Those parts are too fragile and the paint is likely to crack.
  14. Thanks for that info. I will pull them out of hibernation again and have a look.
    I sent the photos to an Allard expert in the UK and just got a reply... Allard never used SW gauges. Curiouser and curiouser.
  15. Speed~On
    Speed~On
    I don't have much, but here's what I have...
    Stewart Warner 2 5/8" Amps gauge. Smooth bezel, front mount, curved gl***.
    2 5/8" Stewart Warner 150psi Oil Pressure Gauge. Front Mount, Curved Gl***, Crescent Needle, Smooth Bezel
    New in box 2 5/8" Stewart Warner Oil Pressure Gauge. Smooth Bezel, Curved gl***, Cresent Needle, Front Mount.
    It's still in it's original box, in the sealed bag from the factory! Dated June 1960. I'm not going to unseal the bag! At least not yet.
    Another Stewart Warner 2 5/8" Oil Pressure Gauge from a swap meet.
    Here is a very large (6" diameter) 1935 Speedometer in my dash. I had HAMBer e1956v completely rebuild it, set the odometer, and calibrate it. Everything on it works great.
  16. Pat Pryor
    Pat Pryor
    T
    Thats a strange oil pressure gauge. Weird looking bezel. Must be late 60s? Mid 60s. The short tail pointer didn't start coming into production until the mid 50s also.
    kidcampbell71 and Speed~On like this.
  17. louisb
    louisb
    No wonder I can't find any gauges, ***us has them all.
    --louis
  18. alchemy
    alchemy
    Yeah, Speed-On's swap meet oil pressure has a weird bezel. Looks like it's not SW. Might be a bad repro, or another brand bezel.
  19. Speed~On
    Speed~On
    It's just a different bezel, the face has the Stewart Warner print and the casing is stamped Stewart Warner.
    Okie Pete likes this.
  20. alchemy
    alchemy
    Yes, that's what I meant.
    There is a well known builder in California who does lots of 32's, and whomever he uses to restore the old SW's in some of those cars uses a similar bezel to yours. Maybe that's where yours came from too.
    I think the shape of Pat Pryor's new bezel looks much more like real Stewart-Warner. I'll have to get some for some needy gauges of mine.
  21. Pat Pryor
    Pat Pryor
    Here's another little something for you guys.
    Little typo
  22. Speed~On
    Speed~On
    ^^ Pat has all the cool stuff!^^
  23. Speed~On
    Speed~On
    The mail box has been good to me. Here's two more I added to my collection this week. Both Stewart Warner
    2 5/8", curved gl***, smooth bezel, front mount.
  24. Here's mine. Sold in the 48 bell cat. For 55 dollars iv been told. This is the 4 hole and they also made a five hole like ***us has. image.jpg image.jpg
  25. Speed~On
    Speed~On
  26. PRIMER STUDIO
    PRIMER STUDIO
    from Butte,MT
  27. Here is a panel set, they are a little crusty, still trying to get them presentable.
  28. Anyone know anything about these SW gauges? You don't see many red white and green gauges.
  29. Here is a set of 2 5/8" I recently sold
  30. Speed~On
    Speed~On
    Here is a 4" rear mount 100 psi Oil pressure gauge I picked up. I believe it is from the MotoMeter Co. They were located in La Crosse, WI. I think these were produced in the early 1930's, it fits in the largest hole in an Auburn dash. It has a beautiful br*** housing that's in great condition, the green light window on the side of the bezel, and a great crescent needle. The gauge is in remarkable condition.
    To give you an idea just how large this gauge is, here it is next to one of my 2 5/8" SW Oil Pressure gauges.
    The pictures do not do this gauge justice, it is beautiful in person.
    Okie Pete, 97, kidcampbell71 and 5 others like this.
