Hot Rods Wyke 32 Sedan
Discussion in 'The Hokey Ass Message Board' started by cornfieldcustoms, May 16, 2015.
  1. cornfieldcustoms
    cornfieldcustoms
  2. cornfieldcustoms
    cornfieldcustoms
    working on ****oning up the rear of the chop. stills need some hammering in a few spots but is coming around nicely
    ryan also is getting the door tops cut and fit back to the body, then we will have to re align the hinges to account for laid back posts
    Stogy and Ron Funkhouser like this.
  3. Eric1967
    Eric1967
    from Union, Mo
    Keep the pics coming. This is an awesome build
  4. cornfieldcustoms
    cornfieldcustoms
    finally back on this one for a little bit.
    the quarter panels are a little rough at the bottoms and around the wheel wells. we also wanted to rais the wheel well 1" for clearance with the large tires. So with that said there wasnt much of a choice except to make new quarters. so here is the process so far
    after all the patterning the major shaping of the panel took place. here is the cleaned up bare quarter cleco'd in place
    then i had to make a die set to do the lower half of the center body line/ belt line. after the die said was made and tested. the belt line was hammered into the top of the panel
    then moving onto the wheel well bead. this was a challenge to lay out. had to raise just the center of the wheel well, then blend that arc into rest of the stock radius of the wheel well, all while keeping it round and smooth. so after that was determined and laid out, i had to make a guide fence for the dies to ride on to put the bead in
    after the fence was done, and a hand full of dry runs on setting the wheel well bead. it was a go and hammered in the wheel well bead
    Then had to turn the edge of wheel well bead to turn under to meet the wheel well. used the power hammer and a tipping die set i made to do this. here is the panel with the old quarter removed, and the new one cleco'd in place. still some tuning to do on the wheel well tipped edge, and turn the edge for the door jamb. but starting to look like something. hope to make the wheel well tomorrow.
  5. bigheadbaxter
    bigheadbaxter
    Stogy likes this.
  6. Rodders
    Rodders
    Very nice
    Stogy likes this.
  7. Lorenzini
    Lorenzini
    Great craftsmanship!
    Stogy likes this.
  8. brady1929
    brady1929
    Amazing
    Stogy likes this.
  9. FOURTYDLX
    FOURTYDLX
    You are a master metal man.
    Stogy likes this.
  10. cornfieldcustoms
    cornfieldcustoms
    thanks guys
    thanks but i wouldnt say i am a master. i still have a lot to learn, but only being 30 i hope to continue to grow and build nicer cars and parts
  11. cornfieldcustoms
    cornfieldcustoms
    a little more progress from today. got the inner wheel well made. still need to do some bead work on it. then i can start the t******* and welding. not bad for a 2 pc hand made quarter
    Stogy and Tim_with_a_T like this.
  12. alchemy
    alchemy
    You made two mirror image guide fences? Can't you just draw a line and free-hand that? Or does it get jerked crooked?
    Stogy likes this.
  13. cornfieldcustoms
    cornfieldcustoms
    you can not draw the line and free hand it. you wont be able to control the panel and get smooth body line. making guide fences is the best route with odd shaped lines in panels
    Stogy likes this.
  14. That looks great Mike !
    Stogy likes this.
  15. milwscruffy
    milwscruffy
    Better to be a master than a baiter ! :cool:
  16. Pewsplace
    Pewsplace
    WOW! I have never seen quarter panels made in that fashion. Outstanding work!
    Stogy likes this.
  17. cornfieldcustoms
    cornfieldcustoms
    got the fading accent bead done in the wheel well today as well as some t******* and fine tuning. now i can start the final t******* and fitting to get the wheel well ready to weld into the new quarter. then it will be ready to weld in the car
    also started finishing the new roof panel on the p*** side that Kyle Yo*** started for me back in July
    Stogy and Champscotty58 like this.
  18. YJ4000
    YJ4000
    Very nice. Always like seeing your work.
    Ryan.
    Stogy likes this.
  19. Outstanding craftsmanship!
    Stogy likes this.
  20. 383deuce
    383deuce
    All I can say at this stage of the build is.....WOW#!
    Stogy likes this.
  21. scotti32
    scotti32
    Wow, absolutely outstanding work. Wish i could get you to do some work on mine.
    Stogy likes this.
  22. vintagehotrods
    vintagehotrods
    Henry has to be smiling at what you are doing to bring this old girl back to life. Hell, I think you hammer a whole car together from flat stock! Amazing workmanship!
    Stogy likes this.
  23. cornfieldcustoms
    cornfieldcustoms
    thanks for the kind words guys
    Stogy likes this.
  24. coopsdaddy
    coopsdaddy
    from oklahoma
    What pedal ***embly did you use?
    Nice work!
  25. cornfieldcustoms
    cornfieldcustoms
    got the tack strip recess hammered into the roof panel
    Stogy and Runnin shine like this.
  26. cornfieldcustoms
    cornfieldcustoms
    things didnt quite go as planned on the recess for the rain gutters. some how either i miss measured or the pattern moved as i was laying out the line. so the recess was about .375 to high at the front of the car. instead of throwing away the piece that i had a ton of time in, it was better to cut and add a section in the panel to move the recess down. had to do a little shrinking and stretching to make it fit right but it resolved the problem
    cut and the piece moved down with the filler tacked in
    welded solid and a p*** through the power hammer to flatten out the weld. still need to add a little form to the bottom edge and some planishing, but it coming around.
    Stogy and 117harv like this.
  27. cornfieldcustoms
    cornfieldcustoms
