Technical Starting trouble
Discussion in 'The Hokey Ass Message Board' started by 440+6, Sep 23, 2016.
  1. 440+6
    440+6
    from Illinois
    Hi,
    I Finally got my cylinder head back for my 194 Chevy last week. I bought everything new from a carburetor and distributor cap, wires etc. I hooked everything up but it does not start it just turns over. I don't know what's wrong I'm thinking it might be fuel pressure or points. What should I do or am I doing something wrong?
    Thanks
  2. Engine man
    Engine man
    from Wisconsin
    Since I don't know your skill level I will ask some basic questions.
    Are you getting any gas squirting from the accelerator pump?
    Are you getting spark at the plug wires?
    Did you get the valves set correctly?
    I ***ume you have the plug wires in the proper firing order.
  3. Yamaha970
    Yamaha970
    Turn engine over so points are in closed position with cap off and key on reach in and open the points..should see spark...pull coil wire out of cap and place it next to something metal then open the points again by hand it should be a loud zap with nice orangey spark..if this works you should have spark..
  4. 440+6
    440+6
    from Illinois
    I am getting a little gas from the pump, I am also getting spark from the wires and as far as I know I do have the valves set correctly.
  5. Yamaha970
    Yamaha970
    Direction of distributor rotor going the same way you think it is..
  6. ClayMart
    ClayMart
    Compression? Cranking vacuum? Did you change camshaft or timing gears? Did you set TDC for the ignition correctly on the compression stroke, not the exhaust stroke? :confused:
