Hot Rods '25 T Roadster Sports Rod.
Discussion in 'The Hokey Ass Message Board' started by Limey Kid, Nov 14, 2015.
  1.
  2. Limey Kid
    Limey Kid
    Bill, I have seen your truck at a couple of shows, love the way it looks and sits.
    Wilmington is run by the ECTA. Similar rules and cl***es as SCTA/Boneville/El Mirage.
    It's an airport runway in Ohio between Columbus and Cinnci, south of Dayton. Info on their website.
    Cheers,
    Stewart.
  3. TigerFan
    TigerFan
    from Athens, GA
    Did the fix for the clutch travel work? I sure hope so. Do you want to post some pictures so the HAMB can help you figure out a solution that might have escaped you?
    This is a great build. You, the car, and the story are an inspiration. Fight through the frustration...
  4. floored
    floored
    Defeat is not an option! I've been patiently waiting for next weekend to get here so I can see your roadster in real life. Good Luck, and hoping to meet you soon.
    Ron
  5. Harms Way
    Harms Way
    Stu,....... Hold Fast !, Dig Deep !.... This WILL happen,....
    If a worn out old "curmudgeon",... Could be of help. You have my number Pal.
  6. Bill Rinaldi
    Bill Rinaldi
    ECTA-----East Coast Timing ***. DUH-----I know exactly where the air strip is!!!! Have talked to couple of Buddies more than once about trying to take a Bonneville car to run there. It's a heck of a lot easier for a midwest group to get to Wilmington Ohio for a shake down/lets see how it runs go than it is to get to Bonneville Utah to test it. I had it in my head the first time out goal was some sort of a road course and ECTA was an acronym for the sponsoring body. Next time I'll think about it before I blurt it out. I'm committed to the Newport In. hill climb on the same week end, I'd really like to see the car make it's debut but I can't do both. I'm sure you'll beat your clutch cable problem, and don't forget you've got a WHOLE BUNCH of HAMBers pulling for you, if you need help, describe it and ASK for it!!! It WILL happen. Bill Rinaldi
  7. BuiltFerComfort
    BuiltFerComfort
    See also if you could change the leverage at the bell housing side of things. Hang in there!
  8. Don't give up now! You're so close!
  9. Limey Kid
    Limey Kid
    Some pictures from the build to give a sence of how tight I am for space. It's a 23 T with 26 hood sides. It has a full non removable floor on the bottom of the frame rails. From firewall to radiator is 26". The grille shell is 20" wide, the firewall is 25" wide. There's 10lbs of poop in a 5lbs bag. As an indicator, to adjust the clutch at the bellhousing I need to take out the battery. To get the battery out i need to take out the starter first. I had to fit all my components/parts into a given small space. It all fits, just, and to get to anything, you may have to take something else off first. I think it's just my piss poor design of my pedal box.
    kiwijeff, Stogy and volvobrynk like this.
  10. BuiltFerComfort
    BuiltFerComfort
    Is there a place to put a cable ratio lever some place in-line of the cable? It's just a pivot /lever that has different lengths - so you can get more clutch action for given pedal input.
    volvobrynk likes this.
  11. Quite a quandary .....can you put a slot in the floor so a lengthened clutch lever can extend through the floor and operate a reshaped rod to the throw out arm or clutch master cylinder....whichever is appropriate? That ***umes you can remove the clutch pedal.
    I know what you're up against. The Whiskey Ridge Special wore me out on redesigns when I built it and after I started driving it.
    Charlie
  12. Blues4U
    Blues4U
    from So Cal
    You got this Stewart!
  13. millersgarage
    millersgarage
    It's ALIVE!!
    And some much anticipated laps around the 'hood
  14. Limey Kid
    Limey Kid
    Sometimes in life you need tea and sympathy, other times you need a slap upside the head. Jeff came round this morning, saw what I couldn't, and we fixed it. James came over at that point and advised on the clutch. It has been a long week this ****** thing has faught me to the end. As Erik reminded me today "I was just being a drama queen". Shut up, think it through, and get it done! Just needed a new perspective, and a slap upside the head!
    It revs great, can't wait to open this thing up. Thanks everybody.
    Cheers,
    Stewart.
    kiwijeff, Stogy, The 39 guy and 4 others like this.
  15. AHotRod
    AHotRod
    It looks and sounds AWESOME !
    I LOVE IT !
  16. You Beauty!!!!!!
    Charlie.
  17. robbovius
    robbovius
    Nice work Stewart, that thing is utterly *****en ;-)
  18. Kick***! It sounds fantastic!
  19. Limey Kid
    Limey Kid
    image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg So I DROVE it out on the street and took some pictures in its race trim. Just need to bleed the brakes one more time and we are ready to go. Last image is of the deck lid which was made by Jimmy and Nate, where everybody who helped and the kids that painted it signed it for me. The deck lid, and hood top made by Clark, are my favourite parts on the car.
    It's been a hard road but we got there in the end. I could not have done this alone. Friends helped me a LOT, these pictures couldn't have been taken today without them. I am forever in their debt. Thank you guys.
    Cheers,
    Stewart.
    kiwijeff, Stogy, The 39 guy and 11 others like this.
  20. SimonSez
    SimonSez
    That's awesome - been watching the thread since the beginning and real glad you made it!!
  21. metal man
    metal man
    You are quite welcome, my friend. I wish you lived closer so we could do this all the time.
    Sent from my SM-G900V using The H.A.M.B. mobile app
  22. bengeltiger
    bengeltiger
    Just.....bad.....***! Congrats!
  23. Kiwi Tinbender
    Kiwi Tinbender
    SEE!! I KNEW YOU COULD DO IT!! Sorry, I was shouting over the loud but sweeet exhaust note. Got all the safety stuff you need to run? I would make a headrest unit to clamp or weld to that drivers side rear downtube. I know that ECTA does not require a HANS at lower speeds. Belts, fire system? Hope you have got everything sussed as per their Rulebook........
    Good grief---I`m on tenderhooks now....that is what 30 plus years at the Salt will do....:oops::rolleyes:o_O:D
    Go get `em Stewart !!!
  24. Limey Kid
    Limey Kid
    Welded the headrest on last night. Belts are in. Don't needHans or fire system. Got my helmet suit and undies.
    Didn't get time for a test run so my licensing run will be it. We can do this.
    Cheers,
    Stewart.
    kiwijeff, AHotRod, SR100 and 3 others like this.
  25. charlesf
    charlesf
    I was going to call, to be sure we were still "on." See you in Wilmington. BTW, if time permits we should have a celebratory dinner on Friday. I'll bet the crew will pitch in to pick up your tab!
    Chuck
    AHotRod likes this.
  26. gnichols
    gnichols
    from Tampa, FL
    Well dang.... congrats all around! Gary
  27. I would still run a HANS or something similar. Even a slower spin out and sudden stop could be enough to make your head wanna leave your neck. That thing turned out really cool!
  28. Kiwi Tinbender
    Kiwi Tinbender
    I can`t stand it......PICS AND REPORT NEEDED!!.....Shouting again. Too hyped up.
    And i`m not even anywhere close!!! Go get em....
  29. TigerFan
    TigerFan
    from Athens, GA
  30. Limey Kid
    Limey Kid
    Pictures and report when I'm back on Monday.
    Cheers,
    Stewart.
    Kiwi Tinbender and Blues4U like this.
