What grit of sanding disk do I use to strip the paint on my car?
Discussion in 'The Hokey Ass Message Board' started by xhotrodder, Sep 11, 2012.
  1. DD COOPMAN
    DD COOPMAN
    If ya have any "feel" for a DA, 80 works fine. I've used 80 and can easily control to strip one coat at a time, if wanted. And, MOST of my strip jobs have been on FIBERGL*** Corvettes...much softer than metal. Use 80! DD
  2. gasmanm01
    gasmanm01
    i use the stripping pads in the tool dept. at lowes. 9.99 each, fits a 3 " grinder, took 4 of them to strip my f-1 to where it was shiney. then coated it with osphoe, let it set overnite, wiped off the dry residue and put three coats of slick sand high build primer.
  3. pimpin paint
    pimpin paint
    from so cal
    Hey,
    Ya doin this in your home shop? Got little jeeters about, or Momma walkin thru your shop? If yes is the answer to any of the above, then ain't no way I'd disc sand an old automotive finish off a job! Chemmie stripper is faster, will save your compressor/electric grinder, and produces little dust to clean up/ inhale:(
    Most of the ''heavy metals'' in automotive paint, ya know the ones that made it last for decades?:D wind up in places like your lungs , liver, kidneys or your gut, if not your's your kids/family members.
    " Humpty Dumpty was pushed "
  4. ROADSTER1927
    ROADSTER1927
    Stripping pads all the way for me! This is my 60 chev totally cleaned up with them. Gary:D:D
  5. outlawsteel
    outlawsteel
    This is the way to go. 80 grit wont remove quickly. But if you are scared of getting into the metal then slap on some 80 and go to work.:D
  6. fastcar1953
    fastcar1953
    about 5 of these to do whole car
    norms30a likes this.
  7. It depends on how many layers you're dealing with, but if you're stripping it I'm ***uming that there are several.
    I use 40 grit on a DA until I just start to see the grit cutting into the metal. Then I go to an 80 grit to finish it off. The 80 grit will leave the metal with a good bite for any primer and/or sealer.
  8. xhotrodder
    xhotrodder
  9. Jimbo17
    Jimbo17
    I vote for 180 and yes it takes more work but you also get a much better surface to work with.
    Just my opinion Jimbo
  10. big creep
    big creep
    this is the way to do it, its how i did it!
  11. 55 dude
    55 dude
    anyone any updates too ad to this thread? i'm doing a pedal car for my granddaughter. thanks.
  12. HOTRODPRIMER
    HOTRODPRIMER
    Something the size of a pedal car I think I would use a liquid paint stripper or better yet put the body in a bead blasting cabinet. HRP
  13. indyjps
    indyjps
    Once you get it down, use ospho or similar to kill the surface rust that the car has acquired.
    Heat gun and a razor blade work surprising well to knock down the first layer. Pair that with stripper, brake fluid and it moves pretty quickly.
    I like the variable speed buffer idea or an electric orbital sander, unless you have a big compressor, DA'ING and entire car will be frustrating. It will likely kill a "big box store" air compressor.
    Dont hesitate to use different plans for different panels. Its a ****py job any way you go about it.
  14. crminal
    crminal
    Been very successful with the "rice cake" stripping wheels in a 4 1/2" angle grinder.
  15. bonzo-1
    bonzo-1
  16. Ralphies54
    Ralphies54
    Forget sanding it'll kill you. Stripped dozens of cars with Aircraft stripper and single edge razor blades in a holder,1 coat of stripper and hold the blade at a angle and paint peels off like crazy. No muss, No fuss, let it drop onto newspaper roll it up and toss it , finish up with stripper and steel wool im those hard to get at places. Ralphie
    GordonC and j-jock like this.
  17. Phil1934
    Phil1934
    I did a truck with cup wire brushes on a 7" grinder. Just wear eye protection as it throws wires.
  18. I stripped both vehicles in my avatar in a weekend using the stipping disks , found using the ones on a drill, lasted longer
    and left the metal nicer, than the ones made for the grinder
  19. TrevO
    TrevO
    from AZ
    Hey Hooligan, which model polisher/sander do you use from harbor freight? Also, does it heat up the metal much and what grit are you using on the velcro pad to strip paint with? I am stripping paint now and it is taking forever using a d/a and 80 because my d/a needs more air than my compressor can supply. Thanks.
  20. low budget
    low budget
    from Central Ky
    I was recently introduced to a 8 inch mud hog sander and I think I would really like it for covering some territory with it,given the chance.
  21. Toymont
    Toymont
    from Montana
    I agree, the sandblaster disks on a 4 inch angle grinder work like a charm. I did the cab on my Stude truck.
  22. Montrose818
    Montrose818
    hello. I am a lurker. I bought a 3m clean strip disc (5", hook and loop, 2500rpm max) and a GV-5010 sander, based on this suggestion.
    My question is though, how do I use the disc with that sander? It seems to only take 5" sandpaper with a small hole. The clean strip disc shows it to use with a drill.
    I know its an old post, but hopefully someone can chime in.
    Thank you folks.
  23. metlmunchr
    metlmunchr
    You need a hook and loop pad for your sander to replace the plastic backing disc that's on it now.
  24. OLDSMAN
    OLDSMAN
    Yes the larger the number the finer paper.
  25. Ralphies54 likes this.
