Projects My Av8 Roadster Build
Discussion in 'Traditional Hot Rods' started by lodaddyo, Sep 17, 2016.
  1. lodaddyo
    lodaddyo
    Thanks guys! More to come so stay tuned
    1947knuck likes this.
  2. lodaddyo
    lodaddyo
    image.jpeg Well i got the flathead all together and turned my attention to the frame. At one point it had some damage to left side frame rail. The top frame rail was bent down. Used my torch and some pliers and worked the top rail level. It worked out ok and looks alot better.
    I also extended the radiator mount pads to give me a little extra clearance to fit this 8ba in. If anybodys tried to fit an 8ba in a model a . Its tight!
  3. Atwater Mike
    Atwater Mike
    Little lower slice to the firewall, too...They fit, but you're right about 'tight'!
    lodaddyo likes this.
  4. louisb
    louisb
    I ended up converting my 8ba to the 59 configuration up front for more room. Not much room up there. I like your idea too.
    --louis
  5. lodaddyo
    lodaddyo
    I really didnt want to cut into the firewall, i did have to indent the right side to be able to get the head off. I also used a mid 60's 12v generator and machined the mounting tabs off and fit a 37 fan mount generator pulley and fan. I also trimed the front pulley off the the double crank pulley.
  6. hotrodA
    hotrodA
    Looking great!
    I really want to retro-fit my old heap, and this is why.
  7. Glen E MacDonald
    Glen E MacDonald
    Where did that radiator come from?
  8. lodaddyo
    lodaddyo
    Brice Thomas Radiators in Alabama. Very nice radiators. The top tank is stamped
    http://www.cgj.com/
    1947knuck and edwardlloyd like this.
  9. louisb
    louisb
    I have been looking at that same radiator. They do a br*** one as well and I have been trying to decide between the two.
    Edit: After seeing yours I went ahead and ordered the aluminum one.Did you get a stock height or chopped radiator?
    --louis
  10. VERY kool - keep em coming !
  11. lodaddyo
    lodaddyo
    Stock height 32 radiator. I didnt realize they made a br*** one
    1947knuck and Stogy like this.
  12. louisb
    louisb
    It cost twice as much which is why I went with the aluminum one. Coat of black paint and most won't know the difference.
    --louis
    Stogy and lodaddyo like this.
  13. I powder coated my aluminum radiator (avatar), satin black, cost $40. This is a great build, watching!!
    Stogy, kidcampbell71 and louisb like this.
  14. lodaddyo
    lodaddyo
    Thanks! I bought some of the eastwood radiator paint for mine. I never heard of powder coating a radiator.
  15. lodaddyo
    lodaddyo
    Heres a pic of of the car mocked up with some splash shields i picked up at Pate this year. Not sure if im gonna run them or not.
  16. louisb
    louisb
    I like it. Reminds me of loudpedal's roadster. Always liked this car.
    If you decide not to use them I need a set for my full fendered project.
    --louis
    Lil'Alb, 1947knuck, hfh and 10 others like this.
  17. lodaddyo
    lodaddyo
    Yeah man i love that car! If i dont use them ill hit you up
  18. waxhead
    waxhead
    from West Oz
    I vote for running the splash shields :)
    Runnin shine, lodaddyo and Never2low like this.
  19. NoSurf
    NoSurf
    Very nice work.
    Looks great!
  20. dentisaurus
    dentisaurus
    from Boston
    Car envy, garage envy, Hmm....
    Like the way this is going, keep it up.
  21. 1-SHOT
    1-SHOT
    from Denton
    Just curious how good do the power coated radiators work compared to the painted ones?
    Bigcheese327 likes this.
  22. I'm watching
  23. Never2low
    Never2low
    I'll 2nd that!:cool:
  24. lodaddyo
    lodaddyo
    Thanks for the positive feedback guys! Heres a little update. Working on the steering. Picked up a 48 f-1 steering box off craigslist.
    Got it torn down and parts ordered for a full rebuild
    Got the steering box cut and model a sector gear housing according to "the book"
    Parts cleaned up in the blast cabinet, ready to be welded together. Cleaned up some original tie rod ends as well
  25. There are a lot of things I've never heard of, and powder-coating radiators is one of them It seems to me that the powder coating would insulate the radiator fins from the air, decreasing the amount of heat transfer which could occur. It will be interesting to learn how well a coated radiator cools.
    oliver westlund, 3340 and Dannerr like this.
  26. lodaddyo
    lodaddyo
    I had th exact same thoughts. Would like to hear more about it.
    1947knuck and Dannerr like this.
  27. lodaddyo
    lodaddyo
    Worked on the gas tank and battery box tonight. Im using a "tanks" 17gal universal tank mounted in the trunk. Decided to go with the Odyssey pc680. Fabbed up a mount for the gas tank that ties into the subfloor and anchored at the top to the quarter support. Should be sturdy enough. Made a box and hold down for the battery.
    Made the Rack for the tank out of 1" square tubing
    Battery box
    I need to get a piece of sheetmetal to make a bulkhead between the tank and battery. Im happy with the way it turned out
  28. Never2low
    Never2low
    lodaddyo and Dannerr like this.
  29. lodaddyo
    lodaddyo
    Got the tail light bracket on. Big thanks to Mike Bowling for the new bracket. I had fabbed up another one, didnt really like the way it looked. Mike stepped in and offered one up out his stash. Looks much better image.jpeg
  30. lodaddyo
    lodaddyo
    Pulled the s**** pedal ***embly out the 35 ford pickup. Pretty tight fit, but its gonna work good. Gonna have to heat and bend the pedal when i get the linkage hooked up
