Hot Rods The '32 nobody wanted.
Discussion in 'The Hokey Ass Message Board' started by Pete, Sep 21, 2016.
  1. Pete
    Pete
    I'm familiar with the PJ's....
    I'm in a small town Just west of Boston.
    Lone Star Mopar likes this.
  2. bostonhemi
    bostonhemi
    We used to play Mission hill in baseball on occasion (Savin Hill). Impressive building skills.
  3. I'm @ Hanscom Famcamp in Bedford. My ride currently in storage and no place to work.
    I'm in a small town Just west of Boston.[/QUOTE]
  4. Pete
    Pete
    image.jpeg image.jpeg Did some work today on the roof while I wait for parts.
    This particular roof is not from this car but is in fact a 5 window unit.
    I received it in 3 pieces, not cut in 3 pieces but torched in 3 pieces....it's a bit rough but fixable. The fella I got it from..... If I remember correctly... Said it was on his 34 roadster?? Yea, that's what I thought! Anyways... It'll be just fine with some manipulation and heat.
  5. hammeredt
    hammeredt
    Ahhh, the wizard uses a fire stick to work his magic, nice!
  6. Pete
    Pete
    no WIZZARDry here.... Just a smith torch.
  7. The37Kid
    The37Kid
    No metallic MIG worms!!!!!!!!!!!!!!! LOVE IT! Bob
  8. Pete
    Pete
    I love gas welding, nice soft malleable weld with workable metal.
    ct1932ford likes this.
  9. AHotRod
    AHotRod
    Go Pete Go !
    What 'style' and look are you aiming for?
    OHV power ?
    bd180 likes this.
  10. The37Kid
    The37Kid
    Just think of all the custom bodies that were built in the 1920's and 1930's with gas welding, filed smooth, with little filler. Bob
    DylanHill1931 likes this.
  11. Fitnessguy
    Fitnessguy
    Crazy the hours that must have took!!
  12. zombiecat
    zombiecat
    Wow! Very inspiring. This makes me feel a lot better about my project. Following this one.
  13. Hendee
    Hendee
    Doing well Pete. Great to see another of your builds. Always informative and awesome rolled into one. I'm watching and learning.
  14. nailhead terry
    nailhead terry
    Man progress is a good thing my old coupe looked like they chopped it with a chain saw they lapped every thing then they channeled it the cross member was made out of bed railings and they could not weld but they knew how to cut **** up .It was the only 32 frame I have ever had to threw away ! I had to replace my cowl and many hours replacing panels keep going !
  15. great to see, perseverance and a plan in action. Look forward to seeing it evolve.
    Cheers,
    Drewfus
  16. louisb
    louisb
    Veddy cool!
    --louis
  17. Pete
    Pete
    Started making the subrails this morning, transferred the frame rails onto some heavy duty matting, then traced the patterns on to some nice thick plate.
    Tomorrow I'll start in the sub rail skirts, those will tie the A and B pillars together and allow me to hang the quarters.
  18. Nice work Pete!
  19. Angry Frenchman
    Angry Frenchman
  20. Pete
    Pete
    I'm getting pumped, I'm waiting on a few big packages to arrive. Once I get those bad larrys I'll be able to fast forward.
  21. F&J
    F&J
    Wow that was a big step done today.
    Look at that door inner bottom...I never saw one in New England before :)
    onekoolkat1950 and wheeldog57 like this.
  22. The37Kid
    The37Kid
    Great to see the pieces going together. Just wondering if Fordor front doors and Coupe doors are the same length? Bob
  23. Pete
    Pete
    Bob,
    I have both coupe and 4 door sedan.
    There's actually a few differences.
    1) The door top height
    2) The actual length is different. The 4 door sedan door is 3/8" Shorter.
    3) Door handles. The 5 window appears to have only a handle on the p***enger door with no lock? The 4 door has both a lock and handle.
  24. Pete
    Pete
    Oh, and I'm not sure if it's just the doors I'm using...maybe they got tweaked at some point....but they don't close all the way, let me say it another way, the doors close to the point where the A pillar and the jamb are fully closed but the rear of the door doesn't meet the B pillar. That's why in one of the photos you can see I removed the inner door panel.
  25. Corn Fed
    Corn Fed
    My dad also used Fordor doors on his Coupe and had the same interference problem at the A pillar. I think Fordors sit wider over the frame at the B pillar so the doors are made slightly different on the front. That was pushing 20 years ago, so I don't remember for sure what we did. But I believe we got them to fit by bending the hinges some and possibly taking a sliver out of the inner front panel and bending the front door edge back.
    To make the top back corner of the door fit, I know we slit it at an angle from the corner of the window opening going upwards towards the top outer corner. We pulled it apart until the corner was closer to square. Then filled the pie shape gap.
    Nailhead A-V8 likes this.
  26. Pete
    Pete
    Corn fed.... Exactly!
    I removed the inner door panel than made a slice at the bottom inner door panel, this allows the A pillar to be rolled/tipped in more... And let's the door fully close. And I'll trim the upper inner panel later.
  27. chickenshift
    chickenshift
    Subscribed! Always dug your builds and working with what you have. Can't wait to see the progress.
  28. dentisaurus
    dentisaurus
    from Boston
    Wow, lot of skill and background knowledge need for this job. Seems really fitting that much of this car(S) was cut up with a gas axe and is being rebuilt with gas welds. Look forward to seeing the 32 that everybody wants when you're done with this.
  29. Pete
    Pete
    Haha......
    A lot of research and learn as I go.
    I have a few more cars / projects in the same disarray as this one.... They seem to find me...,or maybe I find them? But none the less I enjoy the challenge.
    onekoolkat1950 and ABONES like this.
  30. A Boner
    A Boner
    Just a thought.....
    Why channel it? Seems like it would be easier to just reconstruct it sitting on top of the frame. For sure, it would make reconstructing the floor easier. I like hiboys......you may not.
    Keep up the great work!
