Features *OFFICIAL* Ford Unibody 61-63 Pict Thread
Discussion in 'The Hokey Ass Message Board' started by SpnkyMcGee, Nov 29, 2007.
  1. fiveoh108
    fiveoh108
  2. midnightautosupply
    midnightautosupply
    from mo
    Here are some pictures of my 61 Ford unibody with a 520 cid Cadillac engine its a ratrod built to have fun and do burnout contests with spiderweb headliner tube grille louvered hood Nostalgic Sids dropped axle Custom made tailgate All work done by Myself with lots of help from many great friends and a few ***holes. thanks for looking -- Huck
  3. midnightautosupply
    midnightautosupply
    from mo
  4. fiveoh108
    fiveoh108
    I can't see any pictures
    Mike T
  5. Terrible T
    Terrible T
    Here's my 62 uni powered by a 500cid cadillac
  6. drtybiker
    drtybiker
    from florida
    I would also like to see the build to this flipped front str axle slick
  7. drtybiker
    drtybiker
    from florida
    Can someone point me to a build thread that shows the process of putting a str axle on the topside of the leafs I really wanna make sure mine is the best it can be I have spent a few hours andd cannot find a actual build with a play by play description of what was done and how it was done and with what materials etc.ect.ect......Thank You
  8. guano
    guano
    from Oregon
    Drug this home yesterday.
  9. Jigger
    Jigger
    Hey guys, great thread... Can I join in? Just finished some art for fellow HAMB member mctim64.
    He commissioned the art I’ve ***led "Field Truck of Dreams” based on his Uni. Tim also released it
    to me as part of my “Dreamer” series.
    Here are links to Tim’s truck
    http://www.jalopyjournal.com/forum/threads/62-ford-unibody-lsr-truck.573420/
    http://www.jalopyjournal.com/forum/threads/ford-unibody-lsr-truck-photo-shoot.614180/
    http://www.jalopyjournal.com/forum/...age-for-the-land-speed-racing-unibody.924558/
    Cooon likes this.
  10. Nellynel07
    Nellynel07
    Just picked up this 63 big back window !
    Nice little truck. Driver quality. Some paint bubbles here and there. But it's all there. Haven't decided if I wanna flip it or build it!
  11. Here's a thread where I flipped a front axle, corrected the geometry, on a '62 Uni. Has been proven stable up to nearly 150 mph in land speed racing. As much of a step by step with pictures as possible. Hope it helps:
    http://www.jalopyjournal.com/forum/index.php?threads/531700/
    Todd
  12. drtybiker
    drtybiker
    from florida
    Thanks man this is exactly what I was looking for, astronomical ryde you have there,thats one tuff truck
    Sent from my GT-P5113 using Tapatalk
    BIGREDTODD likes this.
  13. FTF
    FTF
    Signage completed by Leonard Wren, think he really nailed it for me. I'm the third generation Noah. DSC01850.JPG DSC01847.JPG
    southpaw-customs likes this.
  14. Thanks, that truck became @mctim64's land speed racer, shown in @Jigger's post above.
    4rod and Jigger like this.
  15. Unibodyguy
    Unibodyguy
    Well here's mine drive it a lot stock pretty much.[​IMG]
    Cooon and 4rod like this.
  16. 4rod
    4rod
    Bringing this thread back to life here's mine
    Now here
    And here
    Full on suspension drop. Used bigredtodd 's uni thread. Putting engine in today.
    Cooon likes this.
  17. 4rod
    4rod
    As promised got engine in
    Cooon likes this.
  18. 56longroof
    56longroof
  19. Unibodyguy
    Unibodyguy
    Here's Big Red out front the other night after a bath [emoji6][​IMG]
    A very Long Bed!!! [​IMG]
    Yup looking good! Trucks a 61 F250 Unibody, Yblock 4 speed.
  20. Timbermax
    Timbermax
    20161001_171723.jpg 20161001_171800.jpg I've been working on my 62 for the last few months. Everything works now. Just need to figure out how to drop it.
    Cooon likes this.
  21. 4rod
    4rod
    Hey great lookin truck. PM me for more info, however lowering depends on budget and your fab skills. Flipping front axel was my choice and the rear I lengthened shackles and removed springs. You can also follow my build thread
  22. Timbermax
    Timbermax
    Thank you. Im pretty open cost wise but I would like to do it myself. I was hoping to just pull a few leafs front and rear as i only want a 2-3 inch drop but ive read that's pretty bad to do. I was going to have the leafs de-arched but they wont because of the pitting. (Doesn't look that bad to me to be honest) I'm not sure what direction i want to go. I only plan to drive it to the occasional Rat Rod show in the summer time. Any input would be great. Thanks.
  23. LM14
    LM14
    from Iowa
    Since this post is back on the top again, thought I would update a little progress on my '62.
    Put in an Industrial Ch***is/Dakota front suspension.
    Built a smooth tailgate and frenched the hinges.
    Got it ready for a big window section in the back of the cab.
    Re-worked the inner fenders so they were mirror images of each other.
    Mounted the 390 (with a 428 crank) and C6.
    Tightened up the taillight openings a little. Also welded all the box cap seams.
    Also started the interior. **** buckets and Ididit tilt/shift column.
    Also have a 4 bar and panhard bar for the 9" rear going in next.
    100_4009.JPG DSCN0018.JPG DSCN0625.JPG DSCN0812.JPG DSCN0814.JPG 100_4009.JPG DSCN0816.JPG
    Cooon, 4rod and chaddilac like this.
  24. 4rod
    4rod
    Timbermax
    Removing leafs is fine, just do three at first every other one. Keeping the main leaf and start from there. Depending on how tired they are you might get the drop you need. There a lot of variables though. Some shops don't want the responsibility messing with springs. But occasionally you can find one. It's takes a lot to drop over 4 to 6 inches. Flipping axel, maybe drop axel, just remember you'll have to start compensating for the steering and ride when you lower things. To eliminate any bump n steer you should raise steering box the amount you lower. However 2 3 inches may not have to. Just my 2 cents.
  25. el shad
    el shad
    Cooon likes this.
  26. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    its not, but looks like a nice fake job from the pics.
  27. el shad
    el shad
    Correct. Its a 64 longbed.
  28. Old-Soul
    Old-Soul
    How about this '61 shortbox my 15 yr old cousin traded a case of beer for??
    michael knight likes this.
  29. Sweet deal. Would he trade it to me for two cases of beer?:D
  30. Old-Soul
    Old-Soul
    I told him he better take two cases and he complained "But the guy only said one!"
    Only 15 and he's already a cheap ***.
