1952-59 Ford Question - How can i convert to POWER STEERING in 54 Ford Sunliner
Discussion in 'Off Topic Hot Rods & Customs' started by fordstandard, Oct 5, 2016.
  1. fordstandard
    fordstandard
    What swaps work ?
    What new systems work ?
  2. Pheaton193
    Pheaton193
    from Reno, NV
    I used a Unisteer Electric Power Steering unit with a stock steering box on my '53. Works quite well...
  3. 54sunliner
    54sunliner
    Borgeson, makes the setup, should be bolt on kit, not cheap though. What engine? headers?
  4. JeffB2
    JeffB2
    from Phoenix,AZ
    Try using the search option here"for this forum only" there is a lot of discussion in the archives and pictures.
  5. Texas57
    Texas57
    I'm 99% sure the Borgenson unit will get you a quicker ratio box as well....a big plus imo. Had they been available when I did the Rack and pinion, I for sure would have looked into it as an option if it did not present any clearance issues with my 4.6.
  6. Pheaton193
    Pheaton193
    from Reno, NV
    I skipped the hoses and power robbing ps pump. Many newer cars today have EPS. An easy install that saves space and works perfectly. You can even adjust the effort needed to turn the steering wheel. You can expect spend about a $1000 with EPS.
  7. Slicks
    Slicks
    from denison tx
    I used the borgenson unit on my 55 works real well i will be using one on my wagon you have to cut the steering column an add a u joint
  8. LBL
    LBL
    Slicks, can you tell me how much you cut the steering column or if you used a new column, what length column you used ..Thanks
