Technical Help with Rear End I.D.
Discussion in 'The Hokey Ass Message Board' started by TS057, Oct 7, 2016.
  1. TS057
    TS057
    from Fargo, ND
    I need some help in identifying a rear end. The guy who has it was told it's a Ford 9" with 5 x 4.5" bolt pattern. It is about 54.5" wide from mounting surface to mounting surface. There is no ID tag or anything like that. If it's a 9" it would have had to have been narrowed I would think. The center housing just doesn't look like a 9" to me. I searched around the interwebs but am not having much luck. I'm hoping to find something narrower to put in my Shoebox and the 8" I have isn't quite as narrow as I'd like. Anyways if anyone can I.D. this thing I'd really appreciate it!
    Tanner
  2. ididntdoit1960
    ididntdoit1960
    from Western MA
    deff NOT a 9......looks 50 ford ish to me
  3. TS057
    TS057
    from Fargo, ND
  4. TS057
    TS057
    from Fargo, ND
    I think you're right... I'm not able to look at mine right now but it does look somewhat familiar. My stock '51 rear end is ~57 1/4" when I've measured it so I'm thinking either it's been narrowed or more likely this guys just measured wrong.
  5. F&J
    F&J
    Shoebox should have a "mechanics" typeU-joint flange.
    Mopars and others used that circular flange, but mopars had axle nuts always? Old lever shock means 30s-or so?
    Crazy Steve and Hnstray like this.
  6. Looks Mopar to me.....
  7. Did you mean what you wrote here?
  8. Los_Control
    Los_Control
    from TX
    This is a 49 dodge rearend, 4x4.5 bolt pattern, wish I had a better photo but all I have.
    The ribs on the hogs head looks similar, yours may be older then 49 though. uncle 007.jpg
  9. squirrel
    really old mopar? like 1930s
  10. TS057
    TS057
    from Fargo, ND
    Sorry.. .meant 5 x 4.5" as in Ford pattern... In any case it's not even close to what the guy thought or was told. Thanks for your help guys.
