1952-59 Ford Heater hose stuff (not the water hoses)
Discussion in 'Off Topic Hot Rods & Customs' started by Jimmy2car, Oct 5, 2016.
  1. Jimmy2car
    Jimmy2car
    from No. Cal
    Anyone have a good subs***ute for the hose/tubes that connect the heater box to the heater motor part?
    Some of it is round (about 3" or so in diameter) and some is square about 3" on each side with clamps?
    Thanks
    Jim
  2. JeffB2
    JeffB2
    from Phoenix,AZ
    The quality of Dennis Carpenters rubber for those vents on 1952-54 Fords is garbage, mine rotted apart in less than 6 months. From the blower motor I used 4'' aluminum dryer vent (see picture) the vent rubbers that are square on one end round on the other,some guys have found that using a section from a 7:50" X 16" inner tube which is much thicker than the aftermarket vents will hold up very well.
    Rui likes this.
  3. JeffB2
    JeffB2
    from Phoenix,AZ
    The quality of Dennis Carpenters rubber for those vents on 1952-54 Fords is garbage, mine rotted apart in less than 6 months. From the blower motor I used 4'' aluminum dryer vent (see picture) the vent rubbers that are square on one end round on the other,some guys have found that using a section from a 7:50" X 16" inner tube which is much thicker than the aftermarket vents will hold up very well. View attachment 3343468
  4. Jimmy2car
    Jimmy2car
    from No. Cal
    Thanks Jeff
    That looks like a good alternative to me.
    Anyone know about the square stuff?
    Best,
    Jim
  5. JeffB2
    JeffB2
    from Phoenix,AZ
  6. Rui
    Rui
    Mine is still holding up.
  7. kgdb
    kgdb
    from The 60"s
    I used rad hose from semi's. Comes in various short lengths and diameters and just cut to fit. Its very durable and looks ok I think.
    Texas57 and DIYGUY like this.
  8. JeffB2
    JeffB2
    from Phoenix,AZ
    Where did you find it at ? And what diameter is it ?
  9. Rui
    Rui
    Very nice. Got me thinking.
  10. HOTRODPRIMER
    HOTRODPRIMER
  11. kgdb
    kgdb
    from The 60"s
    We have some parts dealers here that repair and service semi's, got it from them along with the nice stainless clamps. The diameter that the 55 and 56 use is 4" ID.
  12. PapaVolume
    PapaVolume
    KGDB - that looks clean! I like that idea! I will definitely have to go that route when the time comes.
  13. kgdb
    kgdb
    from The 60"s
    Zapato and Copper Top like this.
  14. Jimmy2car
    Jimmy2car
    from No. Cal
    Jeff
    I used the dryer hose. Works great & looks ok too
    Jim
    JeffB2 likes this.
  15. JeffB2
    JeffB2
    from Phoenix,AZ
    Post a picture of yours too.
  16. Slicks
    Slicks
    from denison tx
    JeffB2 likes this.
  17. Slicks
    Slicks
    from denison tx
    JeffB2 likes this.
  18. Zapato
    Zapato
    kgbd, what did that aircleaner originally come out of ?
  19. turbo hose and m*** air flow sensor hose are some others you might look at try Oreily auto parts performance book
    also Air cleaner plastic pipe (from throttle body to air cleaner housing ) a trip to wrecking yard
  20. kgdb
    kgdb
    from The 60"s
    Its just a after market ***embly. Had it in stock so figured I would use it.
  21. danman55
    danman55
  22. kgdb
    kgdb
    from The 60"s
    Its a great alternative and will last a life time.
