Hot Rods PARTS YOU USED FROM OTHER MAKES BUT NOT NECESSARILY FOR THEIR INTENDED PURPOSE
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Oct 9, 2016.
  1. HOTRODPRIMER
    HOTRODPRIMER
    I was replying to Rons kitchen sink thread and when I was going through my albums I noticed I have used different automobile parts but not for their original intend.
    #1 - I used Nisson windshield rubber around the fixed gl*** on the sides of the Ranch Wagon,no one makes rubber for this.
    Until I installed this rubber everytime I washed the car or it rained it took on water,this solved the problem.
    #2 - Heaven forbid I used 1966 VW running board trim,I cut 2" off each end and modified it to slip over the straps we made to aide in getting in and out of the back seat.
    #3 - I picked this piece of Chevy vinyl top trim at the upholstery shop with this in mind,worked well transiting from vinyl to carpet. HRP
    RICH B, Ford52PU, VANDENPLAS and 5 others like this.
  2. 49ratfink
    49ratfink
    I made a large tail light into a tach cup...
  3. HOTRODPRIMER
    HOTRODPRIMER
    That's a nice looking tach. HRP
    Greenblade and Landmule like this.
  4. HOTRODPRIMER
    HOTRODPRIMER
    No one else thinks outside the box? HRP
  5. AVater
    AVater
    IMG_1863.JPG Well-- just a bit. Found this Cherokee radiator hose combined with the inner spring from another unknown hose worked well to go around the right mount generator on my flathead.
  6. robtlor
    robtlor
    from Lincoln NE
    Used VW door latches in my 2 dr sed. Bob
    Tickety Boo likes this.
  7. buford36
    buford36
    from Maine
    Chevrolet bumper over rider for a license plate surround/light... back.jpg
  8. stillrunners
    stillrunners
    from dallas
    For my great twin nephews wagon - I tossed out of the cheap factory wheels and installed some NOS lawn mower wheels I had in stock. There will be two guys cruising this little red wagon so they will need some good runners.....tried to work in some spinners....but you know they wouldn't last long....
  9. Blues4U
    Blues4U
    from So Cal
    All the time, I call it "Parts Bin Engineering".
    flatheadpete and GreenMonster48 like this.
  10. milwscruffy
    milwscruffy
    I put a Ford nine inch in everything but a Ford. Also use mid 1980's Camaro gl*** outside rubber seal on lots of rods. It is vulcanized onto a metal backing strip, which makes it easy to form.
    stillrunners likes this.
  11. I have used parts from about 13 different vehicles on my '40. That's how my wife came up with the name Alphabet Soup. Only used a few for a different purpose. Rear fender braces are made from wiper linkage off a Freightliner fire engine. Main hoop of the roll bar was a divider from a paddy wagon. Electrical junction block is made out of plastic usually used to make wear blocks for can making machines. Ladder bars are made from Chevy pick-up rear track arms. And the same-only-different, I used up-sweep dragster headers upside down to make fender well type headers. Gene.
  12. LAROKE
    LAROKE
    I'll have to "steal" that idea. I've got one of those small 2" Mooneyes tachs that I got for a similar application ('54 Chevy truck accessory clock housing). It was too small for that. I eventually found a tach that fit the clock housing better.
  13. butch27
    butch27
    I made rear shock mounts for the banjo rear out of '53 Chevy steering arms. the shape fit right around the axle housing and I angeled the arms to where I wanted the shock to connect.
    charleyw and Max Gearhead like this.
  14. Raiman1959
    Raiman1959
    I made my headlight arm brackets on my roadster from the 'clutch & brake' pedal arms (one was a bit shorter,.. I cut the other down to size) which had come off a 1953 Willys jeep...came out nice actually!
  15. HOTRODPRIMER
    HOTRODPRIMER
    A lot of us use different make components but for their intend use on different cars and trucks.
    I have a Chevy truck driveshaft in the wagon along with a GM alternator. HRP
  16. cretin
    cretin
    I do this kind of thing a lot, but the only example I can come up with off the top of my head right now, is I repurposed some 50's Chevy truck E-brake cable mounts into supports for the roof on our Packard project when the roof is open. Unfortunately, I don't currently have photos. I'll have to take some, and ad to this thread as I remember other things.
  17. 59 Edsel stainless trim ,59 Chevy fender spires, perfume bottle for traffic light finder etc.. 20160114_134138.jpg 20160114_134029.jpg
  18. stillrunners
    stillrunners
    from dallas
    Ron....that looks sooo factory....nice work on the trim. Have to tell us more about that perfume bottle !
    Greenblade and Ron Funkhouser like this.
  19. Not a car part, but a pair of junk harbor freight 4" grinders gave up their spindles for inside door handle mounts. Good bearings, will last a lifetime!
    Don't fret, the vice-grips are temporary, until I do some precision grinding to make a square shank.
    Flat Roy likes this.
  20. Thanks, I like chopped tops, but its hard to see the traffic lights. So I just used my one of my wife's perfume bottles with some Velcro on top of the 34s ash tray. Anything gl*** or acrylic will work. Acts as a prism This bottle is a little black skirt with clear legs and heels kinda cool. Ron...
  21. timwhit
    timwhit
    Used one of these 49-50 Merc rear seat ash tray knobs on my glove box door. Along with a Vega box, Maverick rearend, unknown driveshaft and e-brake. Dodge caravan center seat. 036.JPG
  22. cretin
    cretin
    That's very cool. Being on the metal working side, I don't often think about what can be used for interior. Gets me thinking! Thanks for the inspiration.
    Most things with legs, heels, and a little black skirt act as a prison don't they? :D
    Ron Funkhouser likes this.
  23. verde742
    verde742
    what brand of perfume?
  24. HOTRODPRIMER
    HOTRODPRIMER
    This is what I'm talking about,but what are these?HRP
  25. DDDenny
    At first I thought it might be a headrest, but looks to be mounted too high.
    Best guess is a speaker pod made from old headlight bucket.
  26. HOTRODPRIMER
    HOTRODPRIMER
    That's what I was thinking,guess we will have to wait for Ron to fill us in. HRP
  27. 20160113_150859.jpg 059.jpg They are $3. headlight buckets, to look like floating headrest. They are the right height if you are setting straight up in the seat. But with the chopped top I have to set forward on a pillow { drivers side} lol. The Edsel trim was only $10. I like swap meet and junkyard parts. The perfume bottle is one I kept, after my Wife was finished with it. Some cheap stuff that I can't remember the brand. Its a 34 Dodge so I used a PT Cruiser emblem on the inside of the 20160114_134212.jpg rear door, as it looked deco. The old delivery was originally Hot Rodded in the 60s. Thanks Ron...
  28. Sancho
    Sancho
    "Head over Heels"
  29. HOTRODPRIMER
    HOTRODPRIMER
    Screen door latch on a suicide door is a simple hardware store safety piece. HRP
    Flat Roy and hrm2k like this.
  30. josephthreedogs
    josephthreedogs
    I used a Mills slot machine cast indian head as a decorative piece on my "62 Pontiac GP tach mount. ( picture to come later.)
