Technical Insert for Weber aluminum flywheel?
Discussion in 'The Hokey Ass Message Board' started by falcongeorge, Oct 5, 2016.
  1. newenglander
    newenglander
    McLeod used to own Weber. They should be able handle it for you.
    loudbang and falcongeorge like this.
  2. falcongeorge
    falcongeorge
    from BC
    I was looking a bit askance at that as well. Its going on a '57 283 with 327 rods, so it will need to be re-balanced anyway.
    I was supposed to keep an eye out for a bottom at Monroe, but I totally forgot. FWIW, I paid $200 CDN ( :eek::)) for the bell, so VERY cheap. with the dollar the way it is, that's about $170 US, and I didn't have to pay any shipping. If nothing else, I will make a new bottom out of 1/4" plate.
  3. newenglander
    newenglander
    The inserts are also furnace hardened.
  4. falcongeorge
    falcongeorge
    from BC
    Thanks for the info!
  5. Atwater Mike
    Atwater Mike
    Wish I could tell you whether it was 'pressure cast' or not, George. That was in 1961 (?) or thereabouts, and that 'old Y block' was turning 7 grand every time I ran it.
    The Chevy sissies cried every week, "Fords don't go that fast, he must be cheating!"
    Jerks about wore out the head bolt holes from all the teardowns...not ONCE did they realize the pistons were in there backwards! LOL
    That flywheel coming in sure cooled my heels for awhile...
  6. falcongeorge
    falcongeorge
    from BC
    Reminds of a great story about my old Mentor, Bob Crosbie. I had put together several SBC's and mopars that way, was talking to him about putting them in backwards in a sbf I was building. He didn't bat an eye, just said "cant see how it'll hurt, if you are putting it together, it'll probably blow up anyway...":rolleyes::D
  7. dumprat
    dumprat
    from b.c.
    I had my steel insert torch cut. But there are dozens of water jet guys around. That is an easy part to fix George.
  8. falcongeorge
    falcongeorge
    from BC
    Further to this, this is a passage from Merchants of Speed...
    gas pumper likes this.
