Projects 1931 Olds 5W Coupe Build
Discussion in 'The Hokey Ass Message Board' started by 66miles99, Dec 5, 2010.
  1. HRK-hotrods
    HRK-hotrods
    Thanks... You're a lot further along than me. I've had my 29' Chevy roadster almost 9 years and have been slowly gathering parts. Almost ready to build so I need to get my head around this again.
  2. 66miles99
    66miles99
    from Canada
    The original material used typically was whatever was available, oak, ash, they were not particularly loyal to any one species. The brochures I read always just said "hardwood", I wanted something reasonably affordable which I ***umed was their criteria as well! The material I took out of mine was softer although 50 years in a field might do that to ya'.
  3. 66miles99
    66miles99
    from Canada
    More wood work this weekend.
    Stogy likes this.
  4. 66miles99
    66miles99
    from Canada
    And now if it rains and I had a windshield I could clean it.
  5. 66miles99
    66miles99
    from Canada
    New fender well installed sure does stiffen up the back quarter panels.
    Stogy, HRK-hotrods and loudbang like this.
  6. 66miles99
    66miles99
    from Canada
  7. bengeltiger
    bengeltiger
    Just found this thread. Great job! I'd like to see more on your DIY dimple die, too.
  8. 66miles99
    66miles99
    from Canada
    Pretty basic really. Just found parts that fit the bill. 2 1/2" diameter bearing race for the bottom with a 1/2" bolt welded to base plate. The back plate from an angle grinder that had the bevel I needed at the right diameter for the top. After that just a couple of washers and spacers.
    Stogy, bct, bengeltiger and 1 other person like this.
  9. I love this project. Nice job!
  10. bengeltiger
    bengeltiger
    Thanks for sharing that. I like the dimpled holes and am always interested in how different people make their own tools.
  11. 66miles99
    66miles99
    from Canada
    So I had this idea that the Caddy taillights would poke out through the rear trunk. Had kind of a quasi-frenched in look. Unfortunately they struck out so far I couldn't open the trunk and so modification time. I had to pull the tail lights back 1 3/4" to clear the trunk.
    Mounting bracket Before
    After
    Plus I got to use up those two extra Pistons I had!
    T-roaster and Stogy like this.
  12. 66miles99
    66miles99
    from Canada
    Well cleaned up the body. Right now it's got a coat of Gibbs on it, I guess we will see about paint later, love that clean bare metal now though.
  13. bct
    bct
    Great progress .
  14. brady1929
    brady1929
  15. 66miles99
    66miles99
    from Canada
    Thanks! It's slowly progressing.
    Festive dash colors.
    Stogy, T-roaster and loudbang like this.
  16. 66miles99
    66miles99
    from Canada
    I have an issue where the only reasonable route to the bottom of the radiator was through the frame. Basically the Axle gets in the way. So I tried to restrain and protect it best I could.
    And that took up a weekend!
  17. 66miles99
    66miles99
    from Canada
  18. 66miles99
    66miles99
    from Canada
    Didn't follow the instructions very well step 1 was install the fuse box. But then step 2 would be lay on your back for 3 days wiring the dash so I did this instead, hope it doesn't bite me in the *** later.
    tb33anda3rd and loudbang like this.
  19. 66miles99
    66miles99
    from Canada
  20. 66miles99
    66miles99
    from Canada
    Not that it's visible but the windshield (likely the only piece of gl***) is installed.
    Stogy, loudbang, TFoch and 1 other person like this.
  21. 66miles99
    66miles99
    from Canada
    No pictures today, but after lowering the body down over the ch***is I realized 5 clearance issues so far. When you compress all the mechanical and electrical systems into half the available space I guess it's bound to happen. It was a risk I knew would have potential, in the end I think I'll still be a fair bit of trouble ahead.
  22. 66miles99
    66miles99
    from Canada
    2 1/2 years these two have been separated! Time kinda slips by on you sometimes.
    ....the body and the ch***is I mean.
  23. TFoch
    TFoch
    Wow looks great! Taking it for a spin is just around the corner!
  24. 66miles99
    66miles99
    from Canada
    I think that's why its easy to find 8 to 10 hours to work on it each week, 'cause the end is near!
    brEad and loudbang like this.
  25. TFoch
    TFoch
    That's how it was with my 33 Chevy. I busted my **** the last 9 months so I could drive it before the snow would come again. Keep at it, the reward in the end is worth it. By the way that engine fills the compartment nicely!
  26. 66miles99
    66miles99
    from Canada
    Thanks for the encouragement! Yes the inline definitely takes up the right proportional amount of space the Olds are a little longer than the fords in that regard.
  27. 66miles99
    66miles99
    from Canada
    I think I've spent $500 in wire and connections! Picking up new custom battery cable tonight.
    Remote trunk battery means another solenoid required to avoid the live 1/0 cable running thru the ch***is waiting to start a fire.
    loudbang and T-roaster like this.
  28. 66miles99
    66miles99
    from Canada
    Battery secured and looking very non de script after the cover installed in the end.
    Spoke with my local starter and alternator shop and they talked me into a Northstar battery, pretty good warranty, said they were as good or better than Odyssey?
    loudbang and TFoch like this.
  29. loudbang
    Battery posts on the side?
  30. TFoch
    TFoch
    I like those battery straps!
