Technical Ford Flathead V8 + Webers
Discussion in 'Traditional Hot Rods' started by zurferjoe, Oct 13, 2016.
  1. zurferjoe
    zurferjoe
    from Germany
    Hi there thought you might be interested in my Ford Flathead engine update .I have made a manifold Setup to take 4 Weber 40 DCOEs for my bellytanker .It will either Fly or Die !! I was inspired by the
    Ford Flathead V8 engine in the Speedway Motors Museum .The inlet manifods are made by 3D printing process in Carbon based PLA .To see if it al fits and flows .I am now going to make casting boxes so I can cast this a in alloy.Then get the rest done and on the Dyno !! Hope you l ike it !! :)
    tomkelly88 and Texas Webb like this.
  2. big duece
    big duece
    from kansas
    I dig it; working on a Frenchenstein myself. Biggest hurdle will dialing in chokes. Most likely will have to be custom made, standard sizes are too large. Once you determine choke size, you can jet around that. DSC09463.JPG DSC09732.JPG
  3. Mike51Merc
    Mike51Merc
    Seriously 3D printed? That's the coolest thing of all. I'm just imagining the possibilities.
    tomkelly88 likes this.
  4. zurferjoe
    zurferjoe
    from Germany
    Thats why I put it on the Forum !! Wish you many sleepless nights my friend :) !!
  5. zurferjoe
    zurferjoe
    from Germany
    Twos Company Four is a Riot :)
  6. Mike51Merc
    Mike51Merc
    I'm imagining a 3D printed block, with metal sleeves for all the friction surfaces. Feasible?
  7. Cool stuff . . . will be interesting to see how well they run and how easy the tuneup is. Good luck!
  8. banjorear
    banjorear
    Wow! Love it. Keep us updated. Seems like a lot a fuel going in, but sounds like it will be running either at idle or flat out. Good luck with this and keep 'em flat.
    I would love to know more about the process. I'm familiar with the 3D printing process with plastic, but not metal.
  9. zurferjoe
    zurferjoe
    from Germany
    Now your cooking ! Yes it is possibe ! I will Show you the finished article soon ! Gotta build a biger Rep Rap !
  10. zurferjoe
    zurferjoe
    from Germany
    "When in doubt Keep it Flatout " Im printing in Carbonfil20 it melts at 250 degrees I have been Told it woud be best to run your engine with the Hood off !!! You dont know how far you can go until you go to far !!
  11. banjorear
    banjorear
    Yeah buddy. Please just make sure you are wearing a fire suit of some sort. We need you around to give us the scoop on how it's done.
    Too late may mean dirt nap, but fingers crossed your old girl won't reach 250 F.
  12. 28dreyer
    28dreyer
    from Minnesota
    In keeping with the OP's Weber side draft manifold, readers may be interested in this early (probably late 40's to 50's) set-up.
    Riley side draft carburetors were the hot set-up for the big and little Offy's as well as most of the Model A and B conversions such as HAL, McDowell, Rutherford, and of course, Riley.
    Pictured is the Sandice (made in Milwaukee) V8-60 side draft manifold mounting two small Riley carbs on the Bob Clemmons midget. ClemmonsSandice manifold4.JPG ClemmonsSandice manifold2.JPG ClemmonsSandice manifold3.JPG
  13. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    image.jpg Looks very good. Here is one my friend made(not Webers) for 4 individual carbs; in theory each throat is individually tuned.Looks great on paper,untried in real world.
  14. 4wd1936
    4wd1936
    from NY
    Here's how I did it. It works but not any better than a couple of Strombergs, looks cool though under the coffee table.
  15. H380
    H380
    from Louisiana
  16. zurferjoe
    zurferjoe
    from Germany
    So your getting 300bhp with two Strombergs ?The engine in the Speedway Motors Museum did .Here it is in all its glory . 18628_L_15dead91.jpg
  17. X38
    X38
    There is more going on in that engine than some Webers.:rolleyes:
    Jet96 likes this.
  18. zurferjoe
    zurferjoe
    from Germany
    Block Manufacturer : Ford
    Block Material : Iron
    Cylinders : 8
    Cubic Inches : 304.2
    Bore : 3.375 in
    Stroke : 4.25 in
    Block Year : 1949
    Head Manufacturer : Kong
    Head Material : Aluminum
    Cam : In Block
    Cam Drive : Gear
    Carburetion : 4 Weber Dual Throat
    Head Year :
    Rotating ***embly: 180 Degree Crank, with Chevrolet Rods and Main Bearings
    Dyno Results: 300 HP @ 7500 RPM ***embled By: Chet Osgood
    Your not wrong there but its no secret stuff just good old knowhow ! Made in America !!
