Hot Rods Shed some light on what this is...
Discussion in 'The Hokey Ass Message Board' started by soloma, Oct 15, 2016.
  1. soloma
    soloma
    from ontario
    [​IMG][​IMG]
    Is it a mix of T and A stuff? Frame tank cowl etc look A...but the cab back screams T....
  2. clunker
    clunker
    from Boston MA
    Cowl and back window kinda look like a '28 A closed cab p.u ? IMG_1476545858.665316.jpg
    But the two horizontal trim details above and below the handle look like a lot of 20's GM trucks View attachment 3351472
    LOU WELLS likes this.
  3. The37Kid
    The37Kid
    Have to get my Ford truck book out to confirm this, but that looks like a 1926-27 TT truck cab. You can swap in a 28-29 cowl to really confuse people. frame looks to be AA truck, no idea what the axles are. Bob
  4. tinsled
    tinsled
    Wheels are not ford at all...
  5. soloma
    soloma
    from ontario
    Bottom of the cowl panel is curved though...aren't the TT's straight...
  6. The37Kid
    The37Kid
    Excellent point, maybe we are looking at an aftermarket cab that used a 28-29 Ford cowl, but that one belt molding rib on the post is odd. Bob
  7. soloma
    soloma
    from ontario
    Agreed. That's what I can't figure out is that extra belt line....
  8. theHIGHLANDER
    theHIGHLANDER
    It's really kool but i would go so far as to call it "T & A". Just sayin...
  9. gimpyshotrods
    gimpyshotrods
    Nope. I drive a '29A Closed Cab pickup. Not a single part of that cab is a 1928 or 1929.
    Not even the cowl posts. The lower bead that runs from the cab corners, across the doors, also continues onto the cowl post, and around it. This bead, and the other one does not exist on a 1928/29A closed cab. Cowl detail.JPG
    Also, the 1928/29A ccpu used the leftover doors and cowl posts from the 1927 parts bins, so "all-new" is debatable.
  10. falcongeorge
    falcongeorge
    from BC
    Looks like a chevy to me...
    Hnstray likes this.
  11. Is the inner door structure etc. Made of wood? Here in Canada, alot of our model a trucks (AA for sure, but not sure about the pickup) looked alot like that. Every big model a truck here I've seen (and I've seen quite a few) were different than the normal closed cab that you see from the USA.
  12. Imwalkin
    Imwalkin
    from Tucson, Az
    I would bet it is made out of a sedan.
  13. mountainman2
    mountainman2
    "Shed some light on what this is..."
    parts pile.......
  14. Saxman
    Saxman
    To me too.
