Projects My Av8 Roadster Build
Discussion in 'Traditional Hot Rods' started by lodaddyo, Sep 17, 2016.
  1. Aaron D.
    Aaron D.
    This may shed some light on painting the radiator black.
  2. Aaron -- The discussion was about powder coating radiators, not painting them. Radiator manufacturers say that if you paint a radiator, you should use a very light coat of paint, so that you don't insulate the radiator from the air surrounding it. Insulating the radiator from the air around it reduces the amount of heat the radiator can transfer to the air, which is what cools the coolant inside. Powder coating is about 10 times as thick as a good layer of paint, so that's a bunch of insulation.
    3340, itsmee, Stogy and 2 others like this.
  3. flamingokid
    flamingokid
    You're doing all of the right things,keep up the good work.
    Stogy and lodaddyo like this.
  4. lodaddyo
    lodaddyo
    Thanks ! I appreciate it
    1947knuck, Stogy and flamingokid like this.
  5. lodaddyo
    lodaddyo
    Working on fuel lines this morning. Been to every auto parts store in this town. No "ford nut" carb fittings. I figured our local napa would have it. No dice. image.jpeg
  6. lodaddyo
    lodaddyo
    Not much progress lately, i did weld some new brackets on my radiator, which had to come up one inch for fan clearance.
    Ordered some lower hoses from AULIZ here on the hamb. Had to trim an inch off the ends but they worked perfect to make the connection
    Grille shell mounted. Looks pretty good
  7. Good looking build - glad you worked with Flop - he is the man now isn't he! LOL
    Stogy, kidcampbell71 and lodaddyo like this.
  8. lodaddyo
    lodaddyo
    thanks man! yeah Tom is a great guy, glad we got together on this project
    1947knuck and Stogy like this.
  9. Ryan
    Ryan
    ADMINISTRATOR
    I'm loving this car.
  10. lodaddyo
    lodaddyo
    Hey man! Thanks alot. You'll be able to check it out at the roundup if everything goes right
    1947knuck likes this.
  11. lodaddyo
    lodaddyo
    Made a little progress lately. Ive been hunting for a 33/34 front wishbone for my suspension. I knew the 35 i had wasnt gonna work fo what i needed. I was lucky enough to track down one here locally. Made the deal and went picked it up.
    Got it installed on the axle and put it all back under th car. Fabbed up a bracket off my f-1 trans crossmember to mount the ball. Ill finish welding it when i pull the body back off
    Had to drop the steering arms to clear the wishbone to run the tie rod underneath. Not sure if i did this the right way but i took measurements and scribed some lines on the backingplates and made sure everything lined back up
    When i put the front axle back together i used a super low reverse eye front spring. Hard to tell in the pic but it lowered the front a good bit.
    Mocked up some 682j guide headlights i got from a buddy
    My little helper (in high heels) working on my tire.
  12. john dioli
    john dioli
    Nice build
    lodaddyo likes this.
  13. qzjrd5
    qzjrd5
    from Troy, MI
    Very cool build! Looks great!
  14. lodaddyo
    lodaddyo
    thanks guys! the plan Wednesday when I get off of work is to pull the 35 banjo out and start tearing it down for a rebuild. Got a new set of 3.54's to put in it. also gonna order a reverse eye main rear spring to get the rear down just a hair.
    QcATudor, cruiserjohn76 and 1947knuck like this.
  15. Jimmy2car
    Jimmy2car
    from No. Cal
    Lodad
    You're going to love that Odyssey battery.
    I've had the same one in my 32 for almost 5
    years & love it. Starts my big flathead just fine
    Jim
  16. dan@larescorp
    dan@larescorp
    Did your little helper overhear you talking about installing a nailhead?
    Randall, lodaddyo and Dannerr like this.
  17. lodaddyo
    lodaddyo
    Thanks Jim, yeah from what ive read its a pretty powerful little battery. Glad to hear youve had good luck with it
  18. lodaddyo
    lodaddyo
    Lol, no nailhead talk! She just like to weild that hammer!
  19. -Brent-
    -Brent-
    Coming along really well.
  20. lodaddyo
    lodaddyo
    Got the banjo pulled out and tore down. It was a 4.11 r&p. Axle seals and carrier bearing races knocked out and i pressed the pinion out of the housing. I didnt get a picture of the contraption i used to press the pinion out. Put a little heat on it and she popped right out. Axles and spider gears look really good. Gonna clean it all up and start setting up the 3.54's tomorrow. No idea what im doing but i have the service manual to help me out
  21. Danekejt
    Danekejt
    from Pa
    ok quote, "No idea what im doing" and yet it will be masterful. I have legitly "No idea what im doing" I would have a picture of broken **** on the table, with screw drivers sticking out of the wall an inch deep.
    Stogy, lodaddyo and Dannerr like this.
  22. lodaddyo
    lodaddyo
    Haha! Well maybe i should of said ive never done one before. Either it will work or it wont. Ill give it a shot!
  23. treb11
    treb11
    There is a pretty good thread about shimming a banjo somewhere on here.
    Stogy likes this.
  24. What a great build keep the updates coming.
  25. Roger53
    Roger53
    Great build ya have going and had the same help from my grand kids this summer. Keep the pis's coming. And we had some of the white stuff today! Roger
  26. CURSED GEARS
    CURSED GEARS
    Looks like its going together pretty quick.
    Good stuff.
  27. Rand Man
    Rand Man
  28. swifty straights
    swifty straights
    LOOKING GREAT! I REALLY LIKE YOUR TASTE! WELL BUILT AND PUT TOGETHER!
  29. clem
    clem
    May be different down here, but I got some from tractor wreckers, and diesel service firms.
  30. clem
    clem
    Did I mention, neat car, neat thread, - Thanks
