Hot Rods 1932 5W Parked in 1952
Discussion in 'The Hokey Ass Message Board' started by T&A Flathead, Oct 15, 2016.
  1. bowie
    bowie
    AWESOME! Congrats, I love when the right kind of guy ends up with these type of finds.
    T&A Flathead likes this.
  2. wedjim
    wedjim
    from Kissimmee
  3. wheeldog57
    wheeldog57
    Wicked neat Tim, maybe you can get it to TROG 2017 Jersey. See you there, again
    Sent from my SM-G900V using The H.A.M.B. mobile app
  4. oj
    oj
    Great story and I think she made the right choice for the cars' new owner.
    I think I'd have to call the car 'Cookie' and remember her everytime you heard its name.
  5. reefer
    reefer
    Great score and great write up.Ive seen a couple of similar stories on here over the years and then seen them for sale on eBay a short while later....I hope you stick with the plan and do the car justice.
    Please update us regularily, I love these kind of posts.
    Hnstray and T&A Flathead like this.
  6. draggin'GTO
    draggin'GTO
    Great car and great story too.:cool:
    Looking forward to updates, especially after the first wash!;)
  7. mike bowling
    mike bowling
    I think I'm going to cry, you lucky Son of a Gun!
    (Too bad "3wLarry" didn't get to see this one.)
  8. Rand Man
    Rand Man
    Never2low and T&A Flathead like this.
  9. hotrd32
    hotrd32
    from WA
    Man that's a find of a Life Time! Congrats to you.
  10. T&A Flathead
    T&A Flathead
    Many have asked about my plans for the coupe. Since I didn't expect to ever get another 32 it wasn't in my plans to build another. So this car will probably have 2 phases. I'd like to clean it up and get it running, nothing much more than that for the moment.
    Phase 2 will look more like this with a plain looking but healthy built flathead V8, 3.54 gear in the rear and a 39 box.
    Kinda like this coupe and Dan Webbs sedan.
    caseyajones, wedjim, i.rant and 7 others like this.
  11. Squablow
    Squablow
    48 Dodge steering wheel. Sweet car, great story! Hope to see it back on the road soon.
    kiwijeff, triman62, brad2v and 5 others like this.
  12. louisb
    louisb
    Great story. Be cool to see it driving.
    --louis
  13. qzjrd5
    qzjrd5
    from Troy, MI
    Awesome story! Congrats!
  14. T&A Flathead
    T&A Flathead
    So true.
    For those patiently watching for it on eBay, you'll never find it there.
    Baumi and 29bowtie like this.
  15. T&A Flathead
    T&A Flathead
    You know, I was thinking about how 3wLarry would like to have seen it while I was looking at it and dragging it out of the barn. I have a feeling he got a pretty good view from where he is at.
  16. alchemy
    alchemy
    Your coupe is early production 32. The single finger hood hooks, the innie dash, the flat firewall. When you are cleaning it out check the front cross sill in front of the seat for the production plant and the number body it was down the line. I bet the serial number is early too.
    My Tudor has the same features and was the 180th Tudor built in Des Moines.
  17. The serial number (VIN) should be stamped into the top of the left frame rail and visible without removing anything but rust and dirt. If the flywheel housing is original its will also be on a pad on the flywheel housing. The DMV will want to use the one on the frame. It will take the form of star AB 5000000 star and up. Check to be sure it matches the ***le before you do anything else.
    Charlie Stephens
  18. Here is what you are going to need to know when changing the engine to a V8. You can probably ignore a lot of these since the write up is oriented towards a restoration.
    The following changes need to be made when replacing a Model B with a V8 (21 stud, others will require a few more things):
    Of course engine, motor mounts
    Muffler and exhaust system before muffler (same after)
    Radiator
    Radiator support rods
    Engine steady rods
    Hubcaps
    Starter switch (if it is early B with pull starter)
    Transmission (gears interchange but cases are different)
    Choke (B is a cable, V8 is a rod)
    Accelerator linkage
    Engine splash pans
    Gas line needs to be routed from right on Model B to left on V8
    The B will have a few extra holes in the firewall pad from mounting the 4 cyl engine snubber
    Need to add emblem to headlight bar
    Need to accept the fact that the serial number (VIN) is for a 4 cylinder
    Charlie Stephens
  19. Max Gearhead
    Max Gearhead
    from Wisconsin
  20. tfeverfred
    tfeverfred
    Speechless.............
  21. big duece
    big duece
    from kansas
    Congrats.... Some time when I am up your way, would love to see it.
  22. This makes me happy.
    Congrats man!!! You got "The One"
    Thanks for sharing the story.
    HotRods are awesome, but when there is a great
    story attached, that's a whole other level.
    29bowtie and T&A Flathead like this.
  23. thommoina33
    thommoina33
    Alliance Member
    from australia
    What a great story and find. I know we're all hot rodders here but sometimes you've just got to be sympathetic with the build for certain cars that we're lucky to come across.
    Doing to much somehow takes away from the history and story that the car holds and tells.
    I really like the plan, doing the same with mine.
    Congrats on the score of a lifetime.
  24. vintagehotrods
    vintagehotrods
    Congratulations! It's so cool to see they are still being found and rescued by someone like you that will preserve it and its history. Back in the 80's and 90's there were so many beautiful old Deuces that were found and then were blown apart, original parts sold off and built into smoothie billet street rods. And before that stock car racers destroyed hundreds of them. It just makes me sick to think about it. I'm so glad that doesn't happen very often anymore and "traditional" has become the norm.
    And there's nothing wrong with hoarding Deuces, you just can't help it because its called the Deuce Disease and there is no known cure!
  25. 32ford5
    32ford5
    from Australia
    So, so cool. Thanks for posting. Keep us updated as it comes back to life.
  26. Congratulations to you. you treated the widow fairly, and she appreciated it. You were a gentleman, and it paid off.
  27. displaced_kiwi
    displaced_kiwi
    from Olathe KS
    Congrats Tim. Great car and story. You are both lucky and the right caretaker for that 32. Looking forward to following your update posts. I hope alls going well in Laverne and Shirley land.
    cheers
    ricki
  28. scotti32
    scotti32
    Wow, Great 5w, dream find. Hope you get it running soon, keep updating photos please.
  29. T&A Flathead
    T&A Flathead
    This weekend I plan on starting the process of cleaning it up.
    Now that it is in my shop i can work on it a little bit at a time. I have a 48 Ford ragtop that needs to get started and finished first.
    Here is a couple of pics of it in the garage.
  30. El Hueso
    El Hueso
    Too cool! Looks like it is in good hands!
