Any Owners of '18~'22 Dodge Coupes ??
Discussion in 'The Hokey Ass Message Board' started by DE SOTO, Nov 27, 2009.
  1. DE SOTO
    DE SOTO
    I recently picked up a 1922 Dodge 3w Dr Coupe & am leaning towards a Late '20's Early '30's Strip Down Build.
    B***ically Stock with Extra weight (Fenders & Boards) Stripped off, Stock running gear, Lowered a bit & maybe a slight Chop just to bring down the TALL roof line.
    I would like to see if anyone here has one of these Coupe's or has any parts they removed from an '18~'22 Dodge in a Hot Rod Build.
    I would post a pic .... But Dont know how :rolleyes: Any Help ?
  2. DE SOTO
    DE SOTO
    No One has any Early Dodge Stuff ??
  3. vernmotor
    vernmotor
    from ohio
    well I like to see a pic... so at the bottom of the page in stead of quick reply go to advanced..and go to manage files then up load your pic
  4. vernmotor
    vernmotor
    from ohio
    OK we some pics cool car...from De soto..
    kiwijeff likes this.
  5. DE SOTO
    DE SOTO
    Thanks Jamie for posting up pics of my '22 Dodge.
    Now Ya All can see what it is .... Anything out there Ya wanna Share ?
    Interested in seeing pics of Your Early Dodge or interested in your spare parts.
  6. milkweed
    milkweed
    from SLC UT
    there is a 22 in the cl***ifieds for sale but its completley done i sold it half finished it was way worse then what you have. the piece that is missing on your back was nailed on and didnt go all the way around. what ever the material the top was done out of filled in the gap also some wood and padding.1925 had a complete roof that was all steel hope this helps you out
  7. Brandy
    Brandy
    from Texas
    Plowboys Tommy Gun? Wasn't that a 22 Dodge?
    Hmmmmmmmmmmm I'll be back in a second to edit this thread!
    It was originally a 4 door, Valentine and Plowboy reconfingered.......
    http://www.jalopyjournal.com/forum/showthread.php?t=64380&highlight=tommi+gunn
  8. DE SOTO
    DE SOTO
    Nope,
    Thats a bit later ... 'Bout a '28
    Build is a bit New Wave also, I am trying to go more late '20's
    Early '30's Strip Down.
    Even thinking of putting the fenders back on .....
  9. Brandy
    Brandy
    from Texas
    Ack, nobody ever said I was good at identifying ANYTHING.;)
    Wow, I can't even imagine..............but I also doubt anyone has many pics of them.:(
  10. noboD
    noboD
    The roof was aluminum. I have a '24 coupe but it's stock so pics of it wouldn't help you. Does it run and drive? There are lots of DB owners in Calif. How about an underslung?
  11. DE SOTO
    DE SOTO
    Even pics of a stocker would be Cool so i can see a Stock bodied one.
    I need to see the back of the Cab Area.
    No underslung, They get WAYYYY to Low for them Big wheels.
    Engine looks like it has been rebuilt but not sure yet, Has all th drive train in it but is missing Brake rods & some Bolt ons from the engine.
    I put '25 Dodge Front Shackles on the back which are about 1 1/2 inchs longer & switched the Rear End Floater to the top of the spring.. Lowered it alot.
    You can see by the difference at the rear wheel well from pic 1 & 2.
    Now i need to find someone that can drop the stock axle a few inches
  12. beatnik
    beatnik
    Here's a couple of stockers. I really like them and have been keeping my eye out for an eary Dodge coupe, but there hard to come by.
  13. Stone
    Stone
  14. filthy frank
    filthy frank
    i like pic # 2 in the back yard,weld a bracket under the front axle and put it on top of the leif springs for a better stance.and no, i only have parts for 32/33 mopars.filthy frank.
  15. Left Turn
    Left Turn
    from Omaha, NE
    Very cool, I've got an '18-'22 frame I'm using...
    It's cool to see what a body would have looked like on top of it.. Didn't know the rear springs stuck out like that... That's pretty cool.
    All I've got for one is the front axle and the hubs, and a rear axle with no center...
  16. 117harv
    117harv
    Drop the front about 2", finish the cab and take about 3" or 4" out and your done!
    It looks and sits perfect as is.
  17. DE SOTO
    DE SOTO
    I wouldnt weld & Flip the front axle ... Not enough room between Springs & frame.
    I won't Notch the frame either, That set up looks HOKEY to me !
    Thats the Plan ...
    Going to see about dropping the front axle, Finish the Back of the Cab, Prime it one color & run it .... If the Banger comes to Life :D
  18. Left Turn
    Left Turn
    from Omaha, NE
    Just like DE SOTO said, hardly any room for that axle once you flip it.. Pretty much the same out back too...
    The rails I don't think are thick enough to cut into... and your basic up over and down notch would look like hell... but... If you took and measured the rails just after the front shackles, and just before the rears, and relief cut the hell out of a peice of square tube and bent it so it had a gradual swoop to clear the axle that wouldn't look bad.. But your basic simple notch wouldn't look right... And option 2 is alot of work... A dropped axle and if need be a couple of leaves removed would be perfect.
    I'm thinkin' of tryin' the hard way out... All it takes is some square tubing and a lot of patience.. And if I don't like it the s**** trailer is a few feet away from the shop door..
  19. partsdawg
    partsdawg
    from Minnesota
    Got a 1915 body but thats too old
  20. martin
    martin
    That`ll be a neat thing to get around in Rick,
    What sort of top speed are we looking at here mate ?:D
  21. thats gonna be sweet!
  22. DE SOTO
    DE SOTO
    I think 50 would be Pushin it !!!
    I need to find some Old Timer Dodge guys & find the tricks.
    I do understand these were faster than any "T" or "A" Fords, If that meens anything.:rolleyes:
  23. DE SOTO
    DE SOTO
    Any more info or Pics on These Old Coupes ?
  24. Left Turn
    Left Turn
    from Omaha, NE
    Hey, I got that extra axel off for ya, Just haven't had a chance to snap a few pics... Just lettin' ya know I haven't forgot...
    Oh did you want the hubs and all the steering linkage too? or just the axel?
  25. lindross
    lindross
  26. I have a 25 Dodge coupe. Sits on a Model A front section and a box section rear. Runs a 302 and C4 with S10 Rear and Speedway front end.Oh and a Ford grill shell which may disappear.
  27. Stone
    Stone
    Any more pics?
  28. junkyardroad
    junkyardroad
    from Colorado
    Here's my 1925 Dodge.
  29. texkbc
    texkbc
    Here is my 1918 roadster.
  30. 23crate
    23crate
    from nz
    `signs up .. great to see another one... top pic is what ive started with ... the 2nd pic is one I found somewhere but never since.... similar tale with the third..
    ive got a model A frame, and a 318 / `904 combo ..
    looking at a 5" chop . late 20s dodge visor , and a complete rebuild of the non existent trunk
    hows progress?
    'crate
