Technical Lowering an HEI distributor cap
Discussion in 'The Hokey Ass Message Board' started by Neighborwood, Oct 17, 2016.
  1. loudbang
    Posting these for Neighborwood.
    His caption with them:
    "The pictures with the original V8 HEI then the conversion and a view of the Cross fire manifold converted to Carburation.
    Below the distributor is an 83 Corvette FI cross ram ( Crossfire). It is converted to two 32 - 36 Weber carbs. Just right for a 305.
    All the things I did for the conversion is Interesting for a manifold which at its inception was a mistake in design in 1968. It was internally baffled the EGR was converted to the PCV entry point so g***es reach both sides equally then the manifold runners were opened up to match the 305 ports. To make the carburetors fit the manifold low points were filled with J B weld In an 1800# roadster I was friendly with the local tire store."
    Rich S., MaxCubes, TFoch and 2 others like this.
  2. Neighborwood
    Neighborwood
    MSD engineer I talked to quoted his remedy for the high cap problem. I did not go further because that was more then three times what I had in the whole engine, intake, manifold and carburetor setup. Had less then $4,000 in the whole car. That included 5 engine variations that sat in that ch***is. 2 Toyota, 250 Chevy six, Jaguar six and the 305.
    Hnstray and loudbang like this.
  3. Neighborwood
    Neighborwood
    Scroll down. Big Bang posted the pictures for me. Thank you ****
  4. MaxCubes
    MaxCubes
    For anyone interested... This cap for sale on eBay...
  5. verde742
    verde742
    how much was it, are they readily available?
    I will need one like it, eventually ....
  6. MaxCubes
    MaxCubes
    $69
  7. Shadow Creek
    Shadow Creek
    Got a link? I looked on Ebay but I guess I’m not using the right key words...
  8. pprather
    pprather
    Search: 'HEI crab cap' on the auction site.
    Phil
  9. Hombre
    Hombre
  10. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Are there 4 and 6 cylinder crab caps for HEI?
  11. brigrat
    brigrat
    from Wa.St.
    Not like the older HEI's, it takes a remote mounted coil.......................................................
    King ford likes this.
  12. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    External coil okay for me. Just need the flat top side.
  13. MaxCubes
    MaxCubes
    Cap from 4.3 Vortec V6 can be applied to the base part the same way as V8 Vortec cap
  14. MaxCubes
    MaxCubes
    Let me know if you want a six cylinder HEI crab cap, can post one on eBay for same price
  15. MaxCubes
    MaxCubes
    I'm going to post some pictures of the process I use to make this cap...
  16. MaxCubes
    MaxCubes
    4.jpg Start with a cap from a 1976 Chevy C10 with a 4.1 250 six cylinder engine
  17. MaxCubes
    MaxCubes
    Cut the top part off like shown
  18. MaxCubes
    MaxCubes
    You will need to trim these tabs so you can insert the vortec top half
  19. MaxCubes
    MaxCubes
    Use a flat yet course surface to smooth the rough cut... cinder block works good
  20. MaxCubes
    MaxCubes
    Get a 1996-1999 chevy 1500 5.7 vortec cap and cut it shorter like shown... use same sanding block to flatten it even
    Driver50x likes this.
  21. MaxCubes
    MaxCubes
  22. MaxCubes
    MaxCubes
    You'll need to trim the webbing so you can insert it in the lower part
  23. MaxCubes
    MaxCubes
    You may need to work around the inner edge with a hand file so the top part will fit snuggly in the lower cap
  24. MaxCubes
    MaxCubes
    Insert the top vortec half into the lower 76 part.... You see the little rib that the red arrow is pointing to?... the cap must be oriented like this
  25. MaxCubes
    MaxCubes
    Also... this screw must be dead center between the coil post and number 6 post
  26. MaxCubes
    MaxCubes
    Get a rotor from same 1976 Chevy 250 motor..... you do not need to modify it
  27. MaxCubes
    MaxCubes
    Before you glue anything... install the 76 250 rotor to your distributor and install your new low profile cap to the distributor. Spin the distributor with your hand to make sure your rotor is not getting stuck or hitting anything.. if it hits, you need to sand the upper vortec cap shorter and/or you have the top part pushed too deep in the lower part
  28. MaxCubes
    MaxCubes
    The hold down hooks need to be centered between the inner br*** terminals... the square alignment tooth (green arrow) needs to be positioned as shown in relation to the upper vortec cap
    fauj likes this.
  29. MaxCubes
    MaxCubes
    These are the instructions and diagrams I printed to customers when I was selling these on eBay...
    fauj likes this.
  30. MaxCubes
    MaxCubes
    wiring if you want to use a vortec coil...
    tb33anda3rd likes this.
