Hot Rods Let's have our own 85th anniversary event for the 40 ford...
Discussion in 'The Hokey Ass Message Board' started by Moriarity, Feb 10, 2015.
  1. The sedan used to belong to Ron Myers, pinstriper extraordinaire. Cool car with a dressed nailhead.
    hotrodharry2 and i.rant like this.
  2. woodz, CW's40TPU, my2nd40 and 17 others like this.
  3. This little Tudor got a mill on Monday
  4. 47ragtop
    47ragtop
    Absolutely perfection imho !! You took a great find and in a very short time made it the car of my dreams.
    Ron Funkhouser, agshelby and 509garyd like this.
  5. wutnxt
    wutnxt
    Yep !
  6. enloe
    enloe
    from east , tn.
    SOME I FOUND TODAY CRUISING THE NET SORRY IF THEY ARE REPOSTS
    woodz, CW's40TPU, LOU WELLS and 9 others like this.
  7. Got my beater running and driving this month! Drove it to work yesterday.
    woodz, MO_JUNK, LOU WELLS and 22 others like this.
  8. Another shot with the white walls. Cruising the boardwalk in Ocean City, MD.
  9. Moriarity
    Moriarity
    SUPER MODERATOR
  10. Thanks -
    It's a little worn on the outside - but it runs and drives like a new car. I am shocked at how easy it is to drive and to shift. It feels much more modern than I had expected. The stance came out perfect - great work on the axle drop and customer service from Nostalgia Sid.
    Moriarity likes this.
  11. Moriarity
    Moriarity
    SUPER MODERATOR
  12. Moriarity
    Moriarity
    SUPER MODERATOR
    My sentiments exactly. 40 fords are wonderful driving cars....It really confuses me that some people think they need to modernize them
  13. j3harleys
    j3harleys
  14. Moriarity
    Moriarity
    SUPER MODERATOR
    woodz, old skoool, Mr.Norton and 6 others like this.
  15. Moriarity
    Moriarity
    SUPER MODERATOR
    woodz, Old-Soul, DC40 and 3 others like this.
  16. Moriarity
    Moriarity
    SUPER MODERATOR
  17. 40LUV
    40LUV
    from Mid Jersey
    100_6489.jpg 100_6500.jpg At a local show in Pennsylvania, then back home.
  18. Ford salesman's spiel reel for 1940
    Enjoy
    Bill
  19. The 39 guy
    The 39 guy
    Thanks Bill ! That was fun to watch!
    lothiandon1940 likes this.
  20. Here's a question for you 40 Ford Guru's, does an 8 inch wheel fit under a stock 40 rear fender? A friend of mine is building one and he was asking me. He has a Chassis Engineering parallel kit under it with a 9 inch Ford. I told him to do some measuring and figure out his back spacing and go from there.
  21. olscrounger
    olscrounger
    Ol55-sent you a note about wheels
    OL 55 likes this.
  22. dirty old man
    dirty old man
    My '40 has 8.8" Ford with 7" wheels and Chassis Eng. parallel spring kit and 2.35X15 tires. It fits, but it's close. To pull an inflated wheel and tire you have to sorta scoot it to the rear and down rather than straight down. May require custom backspacing also.
    Olscrounger, I'm sure all of us would appreciate your info here, as it is a forum:rolleyes:
    47ragtop and barryvanhook like this.
  23. olscrounger
    olscrounger
    Ok--8's don't fit too well-will rub inner wheel wells toward the front. 7's with 235/75/15 is what I have used on 9 or 10 40's and they must be the right offset or they will rub as well. Have a set of these with tires that I use when I do a 40-no two are the same-bolt these on then adjust as needed for correct backspace with spacers or whatever and have a set made-again no two are ever exactly the same nor are they exactly the same side to side as far as fenders etc. Hope this helps I have the offsets for both front and rear somewhere around here I think. Mine and the last two had 58 1/2 inch wide rears
    LOU WELLS, i.rant, 47ragtop and 2 others like this.
  24. My coupe has a 58" wide 8" Grenada rear end, 15x7 with 3.75" backspace, and 235/70/15's, and I tend to rub the backside on uneven surfaces, like a driveway entrance. there is just a little room between the sidewall and fender lip. I would advise against an 8" wheel, unless it was a truck.
  25. Thanks guys. Now back to our regularly scheduled program. :)
    woodz, 504640, PONTNAK123 and 9 others like this.
  26. alchemy
    alchemy
    That is perfection for a '40 with whitewalls! It sits SOOOO nice!
    woodz and OL 55 like this.
  27. Moriarity
    Moriarity
    SUPER MODERATOR
  28. hotrodharry2
    hotrodharry2
    from Michigan
    I always enjoy Moriarity's pictures in all the different daily stops he makes. I always tell myself to take a few of these shots (like our local "Don's Drive Inn" hamburger stand, however I get side tracked and forget them. Here's a color shot taken a week ago! I had my own color cruise and ran into others doing the same. Love the '40 Fords!
