Features Falcons done right?
Discussion in 'The Hokey Ass Message Board' started by guiseart, Nov 20, 2005.
  1. Cptfalcon
    Cptfalcon
    Picked my 62 up Earlier this month. It's far from "right", but for $500…
    This thread is awesome. So much inspiration.
    Bigcheese327 likes this.
  2. crowen57
    crowen57
  3. Bigcheese327
    Bigcheese327
  4. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    Nice blog post, Bigcheese.
    I dig the power plant.
    All of that through a 7.25"?
  5. nitroracer
    nitroracer
    Nicely done Bigcheese. Those RB engines make for good cheap swap fodder and its nice to stay with the inline six. I looked into those and 90s BMW sixes for swapping into my old Ford.
  6. Erose999
    Erose999
    from Athens GA
    I've been working on my '62 for about a decade now. When I got it it had been (badly) converted to a later 200 six and a C4 auto. The wiring was gone, as were the instruments, etc etc. I finished the auto conversion, did a painless-style wiring harness and drove it like that for a couple years.
    Then I built a 200 and added a SROD transmission I found in an old Fox body Capri. The 200 is built for 9:1 compression, zero deck height, with the big log head, Carter YFA, and Duraspark II. I also have a cheap tri-y header and a 2.5" exhaust.
    The SROD is a 3+od transmission. Took a lot of cutting out the floor and braces to get it installed because that shifter is right where the lateral crossbar of the frame that supports for floor pan goes. And I'm not super impressed with the SROD. The gears ratios are not optimal, especially with the underpowered, low revving six. It's fine on the highway in overdrive. If I had it to do over I'd have shelled out the dough for a T5.
    The last part of the drivetrain is an 8" unit from a Maverick. The center chunk is from a '65 Falcon and has 3.50 gears. The Maverick 8" will just fit under the Falcon. I have maybe 1/4" clearance between tires and fender lips. The wider drum brakes with finned drums are from a Granada with that weird, otherwise useless WER code rear end. They fit the 8" perfectly.
    Granada front brakes, and 65 V8 steering, as well
    Working on finishing the suspension now. I rebuilt the front end with 65 Falcon steering, roller bearing perches, roller idler arm, and homebrew solid mount adjustable strut rods. I also did the "Shelby" mod to drop the lower control arm. I added a 3/4" sway bar to the rear end. Need new rear leaves, caltracs, and a bigger front sway bar. Once I finish all that it'll be onto the interior and body work.
    Later on I may V8 swap the car. I imagine it'd go like stink with a dirty 351 Windsor. I have the frame stands, and a set of V8 coil springs should I decide to. I figure I should build the rest of the car first to where it can handle V8 power. Right now I'm happy putting along a few MPH under the speed limit and getting mileage in the high 20's.
  7. gimpyshotrods
    gimpyshotrods
    I want that dashboard trim/radio delete plate.
    need louvers ? likes this.
  8. Erose999
    Erose999
    from Athens GA
    One other thing about my '62 above is I have these Procar seats in it and I am not a fan of them. They sit at a nice height and are comfortable for cruising, but they have no side support at all. Taking corners I feel like I might fall out of the seat.
    I saw a post earlier where someone had used the other style of Procar lowbacks (the ones with a more wraparound back). How did those work out?
  9. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    I've got a set in my 63 Futura sedan and they've worked out very well for me.
    A buddy of mine had installed the same seats as above in his 63 Hardtop and I tried them- I thought they were too firm and slippery....
    And this is for you, Gimpy.....
    Posted with an IBM Selectric
    droppedstepside, Thor1 and rjones35 like this.
  10. gimpyshotrods
    gimpyshotrods
  11. need louvers ?
    need louvers ?
    I've never seen that type of block off before.
  12. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    Here's the PN.
    Very scarce. Got this one for $120 on eGay about 4 years back.
  13. Erose999
    Erose999
    from Athens GA
    Yeah, those are the other style of seats I'm thinking of. So those hold you in alright in the corners? I have a set of original '65 Mustang buckets as well, I guess my other option would be to invest in the TMI style seat covers and padding with actual bolsters in them.
  14. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    Yes.
    Very comfy and no slip and slide like the others.
  15. BigDogSS
    BigDogSS
    from SoCal
    Awesome Falcons!
    Not to be a downer, but I saw on the news that 63-64-ish Falcon convertible burned up in the Blue Cut fire here in SoCal :-(
  16. gimpyshotrods
    gimpyshotrods
    I saw that too. Plenty of good replacement Falcons to be had.
    Lives, and lifetimes, not so much.[emoji25]
  17. Leon Sandcastle
    Leon Sandcastle
    Decided to dive in on my 62 crewcab falcon and glad I did, guy before me said he had it all ready to go, I decided to cut half a coil up front and do a visual on the rest... dangerous is the understatement, what wasn't stripped, bent, or broke was missing hardware. So I rebuilt the upper control arms, new ball joints, cut half a coil, drilled the Shelby relocation holes, got new lower control arms, new wheel bearings, and everything for the brakes minus backing plates. Good times!
    Sent from my HTC One A9 using The H.A.M.B. mobile app
  18. RetroSpeed
    RetroSpeed
    This is my new 1960 Falcon two door wagon acquired four weeks ago. I have lowered it three inches, installed 1960 Buick taillights and added stainless steel window shades.
    The wagon is a garage mate to my 1963 Ranchero.
  19. scrap metal 48
    scrap metal 48
    I like the tail light treatment^^^...
  20. RetroSpeed
    RetroSpeed
    Thanks s**** metal 48. The Ranchero also has 1960 Buick tail lights.
  21. ROCKETMAN65
    ROCKETMAN65
    I have 62 Mercury Comet. What is the largest tire and rim can be installed on the car without a mini-tub? I plan on installing a shortened 9" Ford Rear End on the car.
  22. ROCKETMAN65
    ROCKETMAN65
    I have a 62 Mercury Comet that I'm turning into a street rod. Can you tell me what is the largest tire and rims that will fit on the car without having to mini-tub? I plan on installing a modified Ford 9" Rear End.
    Thanks!
  23. Ram Air Bob
    Ram Air Bob
    Nice work on the Car. Resullts look good.
    I see you did the disc brake conversion, I have just finished the swap on a 64 Comet. Can you tell me the steering parts you used. Right now I have the Versaises outer tie rod ends, and the **** that came with the car. The steering box is a 1" sector shaft. And the pitman arm (which is loose) hits the clutch linkage. Did you modify the steering stops on the strot rods? Thanks for the help.
    droppedstepside likes this.
  24. Claynan
    Claynan
    IMG_6607.JPG Adding a couple of mine to keep the post going. 64 Sprint convert and a newly acquired 64 Futura.
  25. Well, here's my Australian 'sprint'! Couldn't afford to bring one out of the states to Tasmania, so we made our own version, cut up a 1965 Aussie XP coupe, added a Xk tear end with an Aussie Xl front. Running a 351 Windsor, C4 & shortened 9".[​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  26. RmK57
    RmK57
    Turned out really nice! /\ /\ /\ /\ /\
    loudbang and Hotdoggin DaddyO like this.
  27. Bigcheese327
    Bigcheese327
  28. scrap metal 48
    scrap metal 48
    Hey crowbar, very very cool.. Great job...
  29. hemifalcon
    hemifalcon
    More pictures and details please.. Car is black and looks smooth--great work and great aesthetic..
  30. Evilfalcon1961
    Evilfalcon1961
    from Ma
    IMG_20161213_102724.jpg my two falcons.. I haven't posted on here in awhile IMG_20161103_074944.jpg
