Event Coverage Welcome to the 2017 Meltdown Drags
Discussion in 'The Hokey Ass Message Board' started by Okiedoker, Oct 6, 2016.
  1. Gammz
    Gammz
    from Lincoln Ne
  2. Gammz
    Gammz
    from Lincoln Ne
    [​IMG][​IMG]
    Forgot all about last weekend. Numb nuts raced his way to the finals in trophy street tire. Only to redlight and lose. The pic of with the nova was him taking out the point leader first round. Boom!
  3. powrshftr
    powrshftr
    That kid can really drive!Looking forward to seeing you guys again at the 2017 event.This time we need to hang out more.
    That was my biggest regret from this year's event,even more so than breaking the car: So many good friends that I barely got to spend any time with,and some that I never saw at all...
    Next year the bugs will be out of the car well in advance,and there shall be no shortage of "quality time" spent with good friends in the pits and at Sam's.
    Looking forward to seeing all you guys again.:)
    Scott
    55belairx2 and Gammz like this.
  4. Who who, what what!?
  5. powrshftr
    powrshftr
    Just getting the water outta this thing tonight so we don't have any more popped frost plugs...[emoji15]
    Bought a mechanical oil pressure gauge to replace the stock electrical unit as well,and some copper line to replace that cheesy plastic **** the gauge comes with.
    That will be one less thing to worry about.
    Also going to swap out the H-pattern shifter for the inline Long shifter that came with the transmission.Im not a huge fan of the linkage that came with the H-pattern unit anyway.
    I guess having all winter to think things over won't be so bad...It'll give me a chance to figure out a way to fit all these on the tail light panel once I start mowing you guys down at the track...;)[​IMG]
    [emoji16]
    Scott xoxo
  6. saltflats
    saltflats
    from Missouri
    Looks all business there Scott.
    It would be good to get rid of the oil sender. Looks like a oil down.
    powrshftr likes this.
  7. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    Glad your back Scott! The Meltdown thread and Border Bandits are my favorite on the HAMB . The bantering is all in good hearted fun! But us FORD guys need to stick together ! Larry
    loudbang, powrshftr and Gammz like this.
  8. saltflats
    saltflats
    from Missouri
    You know you guys have to stick together because no one else can stand the carnage as a loner.
  9. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    Always have been a loner James. All my friends and family drive G M's . But I am not afraid SPEED either! Besides if your not breaking something your not trying hard enough!!!!:rolleyes:
    lol Larry
  10. 55chieftain
    55chieftain
    Goodluck to everyone, cant wait till next year. hopefully can pick up another .5 by than. Gotta get a new set of seatbelts also for next year.
    powrshftr, loudbang and saltflats like this.
  11. Saxxon
    Saxxon
    Another .5 ??? We'll have to start calling your 9S*****eftain
    powrshftr, loudbang and 55chieftain like this.
  12. 55chieftain
    55chieftain
    Just being optimistic lol. More stall, transbrake hopefully and more tuning. Would like to work on getting 60 down in 1.30's. Went 10.54 in some good air this fall.
    55belairx2 and loudbang like this.
  13. Saxxon
    Saxxon
    10.54 is moving - especially in a brick the size of the Chief... I never did make another good run this summer. Had a soft 10.05 / 130 and a 1.67 60 ft at the Fall Fall Out then spent the rest of the weekend changing intake gaskets. Think we have it solved, just in time to out it away
    55chieftain, powrshftr and loudbang like this.
  14. saltflats
    saltflats
    from Missouri
    Did you get a handle on the rear springs?
  15. Tickety Boo
    Tickety Boo
    from Wisconsin
    Really should clear coat the vinyl stickers on Scott, otherwise they may blow off with your doors.:rolleyes:
    powrshftr, Gammz, loudbang and 2 others like this.
  16. saltflats
    saltflats
    from Missouri
    I think he needs a big stack with his name on them to hand out.
    powrshftr, Gammz and loudbang like this.
  17. 55chieftain
    55chieftain
    I boxed an area around the springs to contain them better, they are still somewhat loose. I added in a junkyard rear sway bar to control body roll on accel, also helped alot in decell at the end of the track. Also added in a crossmember with a pinion snubber .
  18. saltflats
    saltflats
    from Missouri
    Have you run it after that (I read you did)
    How much help was it on the 60 foot?
  19. 55chieftain
    55chieftain
    Helped a little I think, went 1.43. Biggest part was body was rolling over and hitting slick on rr and that is gone. Now i can throw more at it at launch with more stall and a tb without worry.
  20. saltflats
    saltflats
    from Missouri
    I was trying to find the picture I sent you. Look like the Ol Indian is kickin its heals.
  21. Tickety Boo
    Tickety Boo
    from Wisconsin
    Have to get some ( I have Shaken the Shaker ) vinyl made.:p Shaker.jpg
  22. Saxxon
    Saxxon
    Here's a preview for the "What are you doing to get ready for Meltdown 2018" thread when it gets started. Just closed the deal on this. It's a "real" 1948 Austin without the vent windows. Very minor rust, very straight, doors and windows work great. The original box comes with it. (The box is aluminum !). The frame is solid and I may not swap it out. Already has leaf springs in the rear... I will do a straight axle swap in the front
    We have my brother's bracket bash Ranger PU that's been sitting neglected for the last few years while we run vintage and his daughter's dragster. It has a roller cam 347 Windsor w 10.1 compression and decent heads that would transplant nicely. The 8.8 might even be narrow enough...
    I always wanted one of these...
    This is the plan
  23. saltflats
    saltflats
    from Missouri
    I like your vision.
  24. 55chieftain
    55chieftain
    Swamp Rat 4, Tickety Boo and loudbang like this.
  25. loudbang
    Have you given any thought to the old one airbag on the p***enger side rear to even out that launch? I forget the name but there was a company that made them for drag racing not the "air bag" suspension they have now for lowering and raising customs.
    Had them in all my cl*** racers and they work great.
    powrshftr and saltflats like this.
  26. 55chieftain
    55chieftain
    So far the sway bar is working , from there an anti roll bar set up would probably be the next step. Or also go with ladder bars and floaters with the arb to take the leaf spring out of the equation.
  27. Well, if we're talking stupid, we could put that 306/Nash 5speed in there, only injected on pop, and lite them candles!.., or go completely bonkers, blown on some % ezzz.:eek:
    powrshftr and Saxxon like this.
  28. Slim Jim Miller should be receiving a CP Piston care package today, so all ya'll better climb in your back pockets
    and start a pray'n!
    powrshftr and Tickety Boo like this.
  29. PJ&C \'67 March Meet.jpg A good soul named KingWilly here on the HAMB sent me a private message yesterday. Turns out his buddy took this pic at the 1967 March Meet in Bakersfield. Sure wish we could find this ****er! If we ever stripped down Yesterdays Child, and turned it into a clone of this car (our original idea before we found all the previous owners, and history of the Child) how many would beat us senseless for it?
    powrshftr, Deuced Up! and enloe like this.
  30. Deuced Up!
    Deuced Up!
