Projects "I'm here to pick up the rubbish"
Discussion in 'Traditional Hot Rods' started by Drylake, Jul 18, 2016.
  1. Drylake
    Drylake
    1475139858817.jpg got my 35 wires back from abrasive blasting. One came up pretty bad. More progress!
    Sent from my SM-N910G using The H.A.M.B. mobile app
  2. Drylake
    Drylake
    1475140061458.jpg i have a selection of tyres ready to go but will probably run the black wall big littles.
    chryslerfan55 and tomkelly88 like this.
  3. Bruce A Lyke
    Bruce A Lyke
    Always like to see this sort of build, subscribed
  4. edwardlloyd
    edwardlloyd
    from Germany
    Wow. You hit the jackpot. People just don't find deuce roadsters like that anymore.
    cactus1 likes this.
  5. Drylake
    Drylake
    Thanks Edwardlloyd, I hammer the internet every day to find this gear and love it!
  6. Drylake
    Drylake
    Finally got the chance to pick up the flatheads and front ends etc from glen Innes nsw. Drove from Adelaide, what a long drive! Around 38hrs in total! Got some of the parts i need though, fast forward my project with a big hit of parts! I'll post photos of my finds as i sort through buckets of parts and piles of gear boxes.
  7. Drylake
    Drylake
    1476783407268.jpg 1476783418904.jpg I also am in negotiations with a 1950's aluminium caravan to tow along to long distance swap meets!
  8. Drylake
    Drylake
    My tool box in the back of the ute is also full of flatty parts! 1476783665022.jpg the caravan is a paddock find but will clean up well like the one in the photo has been.
  9. Drylake
    Drylake
    There is a luggage rack in a****st the parts that is in quite good condition. I thought it was model A but it looks wrong and might be early chrysler. I'll post some photos when i get the chance.
  10. treb11
    treb11
    are those Canadian heads aluminum?
  11. Drylake
    Drylake
    Yeah, there are two with canadian alloy heads. 4 out of the 5 engines will clean up well and have clean bores. I have alot of sorting and cleaning to do! 10 gear boxes in total in various condition. 1476868377978.jpg
  12. Drylake
    Drylake
    1476961742121.jpg 1476961750198.jpg 1476961756488.jpg 1476961761288.jpg 1476965224529.jpg 1476965224529.jpg I've been going through the top loaders tonight checking on vanpelt to identify them. I believe i have an early 39 pickup trans and a couple of earlier 37-38's which would make sense given the flatheads that came with the lot. The canadian 21 stud heads are pretty clean. I'm not sure if they originally came with flat top pistons in 37? But I'll check to see if it is standard bore tomorrow.
  13. tomkelly88
    tomkelly88
    Wow, those heads are super clean.
    Looks like you picked up a pretty good hoard there!
  14. Drylake
    Drylake
    [​IMG][​IMG]got the first parch in, after all my hunting for parts it's time to do some work. Ideally i would have rounded up the parts before starting the post but i was too excited to share my find! .
  15. Drylake
    Drylake
    1477377687859.jpg i keep a s**** bin in the shed for 1930's patch panels. Sometimes it saves me making patches from scratch. This time i cut part of the patch out of a 33-34 dodge sedan quarter window. Using the corner radius for the inner radius of the roadster quarter. Worked all right and saved me alot of time.
  16. Drylake
    Drylake
    1477396932901.jpg luggage rack, might be 32 but seems too narrow. Any ideas?
  17. Drylake
    Drylake
    1477993363982.jpg shed is full at the moment. I put the ch***is on the rotisserie on the weekend to make it easy welding up some holes that won't be necessary using the copper block backing method. I still have to chase up front and rear end components to get it mocked up and rolling. I'm hoping the bendigo swap meet will be a winner for me! Steering box is going to be 40 ford along with the steering wheel, which will have a modified 56 horn ****on.[​IMG]
  18. Drylake
    Drylake
    [​IMG] just need to remove the box. I have been thinking of modifying the cross member for motor mounts, and maybe using the column out of this toasty old truck. I have spotted a good idea on here using the original motor mounts on the cross member for the 21 stud fabbing mounts to reach forward. Looked neat.
  19. Drylake
    Drylake
    Dodgejodge and Asphalt Demon like this.
  20. typo41
    typo41
    When Chick and I were in Australia, I remember a buried yard outside of Tumit,
    It might be there, it might be gone,,, but it was loaded including a Pilot Ute, Ill have to find the photos
  21. Drylake
    Drylake
    Cool! Alot of cars were buried, my grandpa has told me stories of pushing car bodies and porcelain signs etc. piled up into a ditch and covered up with dirt. Lost for ever.
  23. Drylake
    Drylake
    The most common i find is 1917-22 ford fenders. My grandpa has an 80 acre orchard and that was his method of cleaning up as was with most larger properties. Avoid carting it and getting someone else to bury it.
    Asphalt Demon likes this.
  24. jim galli
    jim galli
    Ah! The ruby sheep.
  25. Drylake
    Drylake
  26. Zuffen
    Zuffen
    from Sydney
    Flynn's is the yard outside Cooma in the Snowy Mountains. Tumut is nearby..
    Still there and you still need to look out for the snakes!
    chryslerfan55 and Drylake like this.
  27. Drylake
    Drylake
    Thanks snakes are ok, leave them alone and they'll leave you alone. Or carry a shovel!
  28. D.Conrad
    D.Conrad
    Helped clean out a widow's garage recently. GRILLS 001 (640x480).jpg Ronny\'s grills & Manifolds 001 (640x480).jpg
  29. jim galli
    jim galli
    Sure, where we take the rubbish
  30. 36brothers
    36brothers
    Wow! What did the guy you helped get?
