Technical LaSalle Transmission and the Kurtis Tommy Lee Special
Discussion in 'Traditional Hot Rods' started by 1turbobrick, Dec 23, 2013.
  1. 1turbobrick
    1turbobrick
    Hi all. The Kurtis Tommy Lee Special started out life with a LaSalle (top-shift) transmission. At some point the LaSalle ****** was discarded and an old Ford truck transmission was installed in its place. We'd like to put the correct transmission back in but had some questions about the configuration. Hopefully the experts here will be able to answer them...
    Any pictures posted here and elsewhere of a LaSalle transmission shows an extended output shaft housing and u-joint flange. The TLS has a torque tube style drive train. Since the torque tube is original to the car (or at least the configuration), the original LaSalle ****** must have bolted to the torque tube. I can't see this happening unless the output shaft extension comes off and the torque tube bolts up in its place. Is this possible? Are there shorter output shafts available for the LaSalle ******?
    Thanks for helping us wrap our heads around this...
  2. alchemy
    alchemy
    The Lasalle trans is longer than a Ford trans, so if somebody subs***uted the Ford, they also put in a longer torquetube.
    The most common way to install them back in the old days was to remove the tail housing from the Lasalle and modify the trans to bolt up to the torquetube.
    Search "Lasalle transmission" on here and you will find posts with tech articles showing the modifications needed to put the Ford U-joint and clamshell on the back of the Lasalle trans. I have an article in an ancient mag (somewhere) that shows it being done with chalk and a hacksaw. A bit of precision work will be required on the respline of the output shaft though.
  3. Hnstray
    Hnstray
    from Quincy, IL
    The Cad/LaSalle transmissions were indeed modified to work with the Ford torque tube driveline. The method I have seen involved installing the rear mount/u-joint housing housing of the Ford transmission onto the C/L trans main case by drilling the C/L case for the Ford bolt pattern. Then, shortening and resplining the main shaft to the required length and Ford U-joint spline.
    While it does require some machine work, it is a fairly simple adaptation.
  4. 1turbobrick
    1turbobrick
    Perfect! Just the info we were looking for...:)
    Thanks!
  5. Paul
    Paul
    Editor
    old article showing basics of conversion;
    there is a bit more to it
    and a picture of mine;
    kidcampbell71 likes this.
  6. jebbesen
    jebbesen
    from Winona, MN
    Any chance you could tell me what issue of Rodding and Restyling this is in?
  7. Mine is converted to Ford torque tube. See my post "Original Paint Coupe" on page 1 for photos
  8. electricalguy
    electricalguy
    Dale......if you need any ***istance locally, contact us, as Brant(Flashback58)is getting pretty good at working on torque tubes......
  9. cad-lasalle
    cad-lasalle
    from grafton nh
    I think I might know where there is one of those transmissions adapted to a Ford torque tube. If you get back to me, I'll go look for it.
  10. 1turbobrick
    1turbobrick
    Whoa...dredging up a 3 year-old thread. Thanks again for all the info and offers to help. At this point the car is not being driven and likely won't be driven appreciably in the foreseeable future. Those of you who know where the car is will understand why that is. We've got plenty of other projects at the moment but may come back to it at some point.
