Customs 48 chevy pickup old air product AC system
Discussion in 'The Hokey Ass Message Board' started by dover12, Oct 25, 2016.
  1. dover12
    dover12
    from maryland
    installed one in my truck per instructions. all connected correctly, had a service center charge the AC. gauges show charged, air is not very cold at all. What should the AC air temp be at the vents?
    Engine cooling system is good to go. Engine runs at 190 degree ish.
    has anyone had problems with these units ?
  2. 4t8f1
    4t8f1
    I have an Old Air system in my F1 and it works well but you can't have any flow through the heater core for the
    AC / evaporator to cool the air. Make sure the heater valve (manual, electric or vac) is shutting off coolant flow to the core.
  3. 38Chevy454
    38Chevy454
    Also need to have good airflow over the condenser up front. It has to transfer the heat as much as possible for best cooling in the evaporator portion.
  4. TudorJeff
    TudorJeff
    Temp at the vent should be able to get to low 40s pretty easily I believe.
