Massive parts sale
Discussion in 'Parts For Sale' started by 71buickfreak, Oct 14, 2016.
  1. 71buickfreak
    71buickfreak
    from Oklahoma
    City: Stillwater- Go Pokes!
    State: Oklahoma (Boomer!)
    Price: Varies
    I have a ton of street rod and hot rod parts for sale, including a bunch of Vintiques resto parts for model As, early Chevys, and Ford. I am including the master list of my inventory. I will try to keep it updated as we go. Retail prices are listed, I am selling at 40% off retail price. The more you buy, the better the discount. I will sell large lots as well. Shipping will be quoted after you tell me what you want.
    Please ask if you need a better description, some of these are not very good.
    EDL1202 - AIR CLEANER, 94 SERIES, ROUND, S QTY 3 RETAIL EACH $21.5;
    EDL1207 - AIR CLEANER, PRO-FLO SERIES, ROU QTY 1 RETAIL EACH $30.49;
    EDL1221 - AIR CLEANER, ROUND, STEEL TOP,14 QTY 1 RETAIL EACH $29.95;
    EDL1235 - AIR CLEANER, PRO-FLO SERIES, OVA QTY 1 RETAIL EACH $81.08;
    EDL12801 - POLISHED FUEL BLOCK DUAL CARB QTY 1 RETAIL EACH $57.83;
    EDL12851 - FUEL BLOCK, TRIPLE, POLISHED QTY 1 RETAIL EACH $80.94;
    EDL12901 - FUEL BLOCK, QUAD, POLISHED QTY 1 RETAIL EACH $63.6;
    LOKTR-1200HT - TRUNK RELEASE CABLE KIT QTY 2 RETAIL EACH $138.9;
    LOKTR-1200U - TRUNK RELEASE CABLE KIT QTY 1 RETAIL EACH $104.94;
    LOKTRP-4003 - STAINLESS STEEL CABLE BRACKET QTY 1 RETAIL EACH $53.14;
    LOKXBAG-6131 - BILLET ALUMINUM CURVED AUTOMATIC BRAKE PAD QTY 1 RETAIL EACH $63.14;
    LOKXBAG-6152 - CHROMED STEEL BRAKE/CLUTCH PAD QTY 1 RETAIL EACH $56.43;
    LOKXFMS64L60DB - SHIFTER GM 4L60E QTY 1 RETAIL EACH $251.95;
    LOKXSK-6878 - MIDNIGHT SERIES; SHIFTER KNOB ADAPTER QTY 1 RETAIL EACH $32.42;
    LOKXTC-1000TP - MIDNIGHT SERIES; TUNED PORT HI-TK THRTTL CABLE QTY 1 RETAIL EACH $69.74;
    MITWMS15 - UNIV WIPER MOTOR (1-1/2" SHAFT LENGTH) QTY 2 RETAIL EACH $135;
    MITWMS2 - UNIV WIPER MOTOR (2" SHAFT LENGTh) QTY 2 RETAIL EACH $135;
    MITWMS25 - UNIV WIPER MOTOR (2-1/2" SHAFT LENGTH) QTY 3 RETAIL EACH $135;
    MITWMS3 - UNIV WIPER MOTOR (3" SHAFT LENGT QTY 3 RETAIL EACH $135;
    MRG101B - INT GSKT,SB CHEV STK PORT QTY 6 RETAIL EACH $16.95;
    MRG102G - INT GSKT,SB CHEV MED PORT QTY 1 RETAIL EACH $17.95;
    MRG106 - INT GSKT,SB CHEV MED PORT QTY 6 RETAIL EACH $20.95;
    MRG108 - INT GSKT,BB CHEV RECT PORT QTY 1 RETAIL EACH $17.95;
    MRG113 - INT GSKT,SB CHEV LRG PORT QTY 2 RETAIL EACH $23.95;
    MRG1130 - STEEL SHIM HD GSKT SB CHEV -PR QTY 1 RETAIL EACH $26.95;
    MRG116 - INT GSKT,SB CHEV LRG PORT QTY 2 RETAIL EACH $23.95;
    MRG1190 - COLL GSKT SQ 2-1/2 X 3-5/16 BC QTY 13 RETAIL EACH $4.95;
    MRG1193 - COLL GSKT RD 3-3/8 X 4-1/2 BC QTY 4 RETAIL EACH $4.95;
    MRG1200 - DISCONTINUED HDR FLNGE QTY 26 RETAIL EACH $3.95;
    MRG1203 - COLL GSKT TR 3-1/2 X 4-7/16 BC QTY 3 RETAIL EACH $4.95;
    MRG1204 - COLL GSKT TR 3 X 3-7/8 BC QTY 20 RETAIL EACH $4.95;
    MRG1204C - COLL GSKT TR 3 X 3-7/8 BC QTY 8 RETAIL EACH $8.95;
    MRG1206 - COLL GSKT SQ 3-1/2 X 5 BC QTY 9 RETAIL EACH $2.95;
    MRG1207 - DISCONTINUED HDR FLNGE QTY 16 RETAIL EACH $2.95;
    MRG1280 - COIL,SPRING CONTROL QTY 1 RETAIL EACH $17.95;
    MRG1287 - SUPER RUBBER SPRING SPACER QTY 1 RETAIL EACH $15.95;
    MRG1350 - ALUM,COOL CAN-BRUSHED QTY 1 RETAIL EACH $108.95;
    MRG1428 - WHEEL WEIGHTS-SELF ADHESIVE QTY 3 RETAIL EACH $8.95;
    MRG1440 - WHEEL NUTS 7/16IN.RH CHROME QTY 3 RETAIL EACH $10.95;
    MRG1444 - WHEEL NUTS 12MM X 1.5 CHROME QTY 4 RETAIL EACH $7.95;
    MRG1450A - 14"X5"ROUND PAPER A/C ELEM QTY 1 RETAIL EACH $15.95;
    MRG1485A - ELEMENT,REPLACEMENT 6.5"X2.43" QTY 1 RETAIL EACH $7.95;
    MRG1490 - AIR CLEANER 2 BBL 6 1/2" QTY 1 RETAIL EACH $24.95;
    MRG150 - EXH GSKT CHEV RD PORT QTY 2 RETAIL EACH $13.95;
    MRG1509 - HOLLEY 4BBL BOWL/MET GASKET QTY 7 RETAIL EACH $6.95;
    MRG150A - EXH GSKT SB CHEV STOCK QTY 10 RETAIL EACH $13.95;
    MRG150C - EXH GSKT SB CHEV SQ PORT QTY 2 RETAIL EACH $15.95;
    MRG152A - EXH GSKT,BB CHEV RD PORT QTY 1 RETAIL EACH $18.95;
    MRG153 - EXH GSKT,BB CHEV SQ PORT QTY 2 RETAIL EACH $15.95;
    MRG154 - EXH GSKT,BB CHEV LRG SQ PORT QTY 2 RETAIL EACH $15.95;
    MRG155 - EXH&INT MANIFOLD SET CHEV I6 QTY 1 RETAIL EACH $14.95;
    MRG1593 - TIMING TAPE CHRY 383-440 7-1/4 QTY 1 RETAIL EACH $9.95;
    MRG16 - REPL,DRAIN PLUG WSHR NYLON QTY 1 RETAIL EACH $6.95;
    PPP10301 - DISCONTINUED MODULAR CHASSIS HAR QTY 1 RETAIL EACH $150;
    PPP10302 - DISCOONTINUED MODULAR CHASSIS HA QTY 2 RETAIL EACH $57;
    PPP10303 - DISCONTINUED MODULAR CHASSIS HAR QTY 1 RETAIL EACH $41.95;
    PPP10310 - DISCONTINUED MODULAR CHASSIS HAR QTY 1 RETAIL EACH $21;
    PPP10311 - DISCONTINUED MODULAR CHASSIS HAR QTY 1 RETAIL EACH $21;
    PPP10320 - DISCONTINUED MODULAR CHASSIS HAR QTY 2 RETAIL EACH $27;
    PPP10321 - DISCONTINUED MODULAR CHASSIS HAR QTY 2 RETAIL EACH $27;
    PPP12000 - FUSE BLOCK COVER - SIDE BY SIDE QTY 1 RETAIL EACH $29.69;
    PPP12001 - FUSE BLOCK COVER - DIAGONAL FLAS QTY 2 RETAIL EACH $32.24;
    PPP50201 - 8-SWITCH PANEL/NON-FUSED/DASH MO QTY 1 RETAIL EACH $299.97;
    PPP50710 - MASTER DISCONNECT SWITCH W/PANEL QTY 1 RETAIL EACH $79.75;
    PPP60406 - WELD IN OXYGEN SENSOR FITTING/BU QTY 1 RETAIL EACH $11.01;
    PPP60408 - DISCONTINUED TPI AIR INTAKE QTY 1 RETAIL EACH $0;
    PPP70103 - CIRKIT BOSS AUXILIARY FUSE BLOCK QTY 1 RETAIL EACH $68.02;
    PPP70107 - CIRKIT BOSS AUXILIARY FUSE BLOCK QTY 1 RETAIL EACH $81.97;
    PRR5031 - POLISHED ART DECO A/C CONTROL BE QTY 6 RETAIL EACH $29;
    PRR5032 - BINARY SWITCH KIT (w/BEADLOCK FI QTY 16 RETAIL EACH $28;
    PRR5033 - TRINARY SWITCH KIT (w/BEADLOCK F QTY 1 RETAIL EACH $39.95;
    PRR5040-PLATES - ALUM 4 HOLE INLINE HEAT / AC BLK PLATES QTY 49 RETAIL EACH $10;
    PRR5050 - 170-DEG RELAY KIT W/SNSR (ON-185 QTY 2 RETAIL EACH $49.95;
    PRR5051 - 200-DEG RELAY KIT W/SNSR (ON-200 QTY 6 RETAIL EACH $49.95;
    PRR6218 - ELEMEN AIR/CLNR QTY 9 RETAIL EACH $3;
    PRR6320 - S/S DROP-DOWN BATTERY BOX (OPTIM QTY 2 RETAIL EACH $129.95;
    PRR6323 - BL-MLD "OPTIMA" BATT TRAY (GRP 3 QTY 1 RETAIL EACH $69.95;
    PRR6325 - BL-MLD "OPTIMA" BATT TRAY (GRP 2 QTY 2 RETAIL EACH $76.95;
    PRR7801 - ALUM LO-PRO BRTH QTY 2 RETAIL EACH $33;
    PRR7801P - POL ALUM 1" LO-PROFILE 2-PC BRTH QTY 2 RETAIL EACH $36;
    PRR7803 - SAT ALUM 3/4" "LO-PROFILE" 2-PC QTY 2 RETAIL EACH $33;
    PRR7803P - POL ALUM 3/4" "LO-PROFILE" 2-PC QTY 1 RETAIL EACH $36;
    PRR8000 - PR RAW CST IRN "RAM HORN" SBC EX QTY 1 RETAIL EACH $159.95;
    PRR8155 - "GUIDE STYLE" S/S T/SIG W/AMBER QTY 1 RETAIL EACH $69.95;
    PRR8160 - HIDDEN ANTENNA KIT QTY 2 RETAIL EACH $39.95;
    PRR8165 - FULLY AUTOMATIC ANTENNA POWER AN QTY 3 RETAIL EACH $39.95;
    PRR8200 - SML CHR SGL-ELE LT W/AMBER LENS QTY 15 RETAIL EACH $9.95;
    PRR8211C - 72" LAP-ONLY BLUE W/CHROME LATCH QTY 6 RETAIL EACH $24.95;
    PRR8211D - 72" LAP-ONLY MAROON W/CHROME LAT QTY 4 RETAIL EACH $24.95;
    PRR8211E - 72" LAP-ONLY GRAY W/CHROME LATCH QTY 7 RETAIL EACH $24.95;
    PRR8211F - 72" LAP-ONLY TAN W/CHROME LATCH QTY 3 RETAIL EACH $24.95;
    PRR8211G - 72" LAP-ONLY BRT RED W/CHROME LA QTY 4 RETAIL EACH $24.95;
    PRR8213B - 72" CHR LATCH 2PT RETRACTABLE BL QTY 1 RETAIL EACH $39.95;
    PRR8213C - 72" CHR LATCH 2-PT RETRACTABLE B QTY 5 RETAIL EACH $39.95;
    PRR8213D - 72" CHROME LATCH 2PT RETRACTABLE QTY 2 RETAIL EACH $39.95;
    PRR8213E - 72" CHROME LATCH 2PT RETRACTABLE QTY 4 RETAIL EACH $39.95;
    PRR8213F - 72" CHROME LATCH 2PT RETRACTABLE QTY 15 RETAIL EACH $39.95;
    PRR8213G - 72" CHR LATCH 2-PT RETACT BRIGHT QTY 6 RETAIL EACH $39.95;
    PRR8238 - 39 LED FLUSH MOUNT T/LIGHT W/BE QTY 11 RETAIL EACH $34.95;
    PRR8239 - 39 LED CONVERSION LENSE (each) QTY 9 RETAIL EACH $27.95;
    PRR8247 - 42-'48 CHEV LED CONVERSION LENS QTY 33 RETAIL EACH $27.95;
    PRR8250 - "LITES-IN-BOLTS" LICENSE PLATE B QTY 8 RETAIL EACH $18.95;
    PRR8257 - RED "1157"-TO-LED CONVERSION BUL QTY 4 RETAIL EACH $8.95;
    PRR8258 - PONTIAC ROUND TAIL LIGHT ASSY (R QTY 2 RETAIL EACH $29.95;
    PRR8260 - EACH 7" CHROME H/LAMP WITH AMBE QTY 4 RETAIL EACH $79.98;
    PRR9010 - UNIVERSAL IGNITION SWITCH W/2 KE QTY 4 RETAIL EACH $14.95;
    PRR9021 - 50-PACK 11/16" CHR ACORN NUT CVR QTY 3 RETAIL EACH $25;
    PRR9022 - 5-PACK 11/16" CHR ACORN NUT CVRS QTY 19 RETAIL EACH $2.5;
    PRR9023 - 20-PACK 9/16" CHR ACORN NUT CVRS QTY 5 RETAIL EACH $10;
    PRR9024 - 5-PACK 9/16" CHR ACORN NUT CVRS QTY 32 RETAIL EACH $2.5;
    PRR9102 - 14" ROUND FULL FINNED AIR CLEANE QTY 1 RETAIL EACH $99.95;
    PRR9450 - ALUMINUM VENTED CHEVY GAS CAP QTY 8 RETAIL EACH $21;
    PRR9460 - ALUMINUM VENTED FORD GAS CAP QTY 4 RETAIL EACH $21;
    PRR9500D - 12" "DUAL PASS" TRANSCOOLER QTY 7 RETAIL EACH $39.95;
    PRR9515D - 15" "DUAL PASS" TRANSCOOLER QTY 9 RETAIL EACH $44.95;
    PRR9518D - 18" "DUAL PASS" TRANSCOOLER QTY 8 RETAIL EACH $49.95;
    PRR9703 - 3/16" X 10-32 RH MALE QTY 13 RETAIL EACH $2.77;
    PRR9704 - 1/4" X 1/4"-28 RH MALE QTY 5 RETAIL EACH $2.79;
    PRR9705 - 5/16" X 5/16"-24 RH MALE QTY 8 RETAIL EACH $2.84;
    PRR9706 - 3/8" X 3/8"-24 RH MALE QTY 41 RETAIL EACH $3.21;
    PRR9707 - 7/16" X 7/16"-20 RH MALE QTY 8 RETAIL EACH $4.19;
    PRR9708 - 1/2" X 1/2"-20 RH MALE QTY 11 RETAIL EACH $5.01;
    PRR9710 - 5/8" X 5/8"-18 RH MALE QTY 11 RETAIL EACH $7.53;
    PRR9712 - 3/4" X 3/4"-16 RH MALE QTY 7 RETAIL EACH $10.02;
    PRR97610 - 5/8" X 5/8"-18 LH MALE QTY 5 RETAIL EACH $7.53;
    PRR97612 - 3/4" X 3/4"-16 LH MALE QTY 4 RETAIL EACH $10.02;
    PRR9763 - 3/16" X 10-32 LH MALE QTY 11 RETAIL EACH $2.77;
    PRR9764 - 1/4" X 1/4"-28 LH MALE QTY 11 RETAIL EACH $2.79;
    PRR9765 - 5/16" X 5/16"-24 LH MALE QTY 7 RETAIL EACH $2.84;
    PRR9766 - 3/8" X 3/8"-24 LH MALE QTY 25 RETAIL EACH $3.21;
    PRR9767 - 7/16" X 7/16"-20 LH MALE QTY 4 RETAIL EACH $4.19;
    PRR9768 - 1/2" X 1/2"-20 LH MALE QTY 7 RETAIL EACH $5.01;
    PRR9803 - 3/16" X 10-32 RH FEMALE QTY 17 RETAIL EACH $2.77;
    PRR9804 - 1/4" X 1/4"-28 RH FEMALE QTY 6 RETAIL EACH $2.79;
    PRR9805 - 5/16" X 5/16"-24 RH FEMALE QTY 17 RETAIL EACH $2.84;
    PRR9806 - 3/8" X 3/8"-24 RH FEMALE QTY 15 RETAIL EACH $3.21;
    PRR9807 - 7/16" X 7/16"-20 RH FEMALE QTY 1 RETAIL EACH $4.19;
    PRR9808 - 1/2" X 1/2"-20 RH FEMALE QTY 9 RETAIL EACH $5.01;
    PRR9810 - 5/8" X 5/8"-18 RH FEMALE QTY 13 RETAIL EACH $7.53;
    PRR9812 - 3/4" X 3/4"-16 RH FEMALE QTY 4 RETAIL EACH $10.02;
    PRR98610 - 5/8" X 5/8"-18 LH FEMALE QTY 6 RETAIL EACH $7.53;
    PRR98612 - 3/4" X 3/4"-16 LH FEMALE QTY 5 RETAIL EACH $10.02;
    PRR9863 - 3/16" X #10-32 LH FEMALE QTY 19 RETAIL EACH $2.77;
    PRR9864 - 1/4" X 1/4"-28 LH FEMALE QTY 4 RETAIL EACH $2.79;
    PRR9865 - 5/16" X 5/16"-24 LH FEMALE QTY 11 RETAIL EACH $2.84;
    PRR9866 - 3/8" X 3/8"-24 LH FEMALE QTY 5 RETAIL EACH $3.21;
    PRR9867 - 7/16" X 7/16"-20 LH FEMALE QTY 4 RETAIL EACH $4.19;
    PRR9868 - 1/2" X 1/2'-20 LH FEMALE QTY 4 RETAIL EACH $5.01;
    RFWAB-4 - AUTO FUSE BLOCK QTY 1 RETAIL EACH $19.95;
    RFWAC-25 - AIR CONDITIONING FEED WIRES QTY 2 RETAIL EACH $16.95;
    RFWAC-7 - ACCESSORY WIRING KIT QTY 1 RETAIL EACH $60.95;
    RFWAF-29 - ASSORTED ATC FUSES QTY 4 RETAIL EACH $10.95;
    RFWAR-23 - STAND ALONE COOL FAN RELAY-A/C R QTY 1 RETAIL EACH $84.95;
    RFWAT-30 - POTLUCK TERMINALS (ASSORTMENT) QTY 1 RETAIL EACH $16.95;
    RFWB-1002 - DISCONTINUED BULB SPECIAL QTY 7 RETAIL EACH $6;
    RFWB-1005 - 15/3 CP BULB (- - PIN) QTY 3 RETAIL EACH $7.5;
    RFWB-1007A - 15/3 CP AMBER BULB (--_PIN) QTY 3 RETAIL EACH $7.5;
    RFWB-1015 - 50 CP BULB (- -PIN) QTY 1 RETAIL EACH $5.5;
    RFWB-1077 - 50/14 CP BULB (-- _ PIN) QTY 6 RETAIL EACH $6.5;
    RFWB-1077A - AMBER 50/14 CP BULB (--_ PIN) QTY 7 RETAIL EACH $7.5;
    RFWB-1087 - 50/14 CP BULB (--PIN) QTY 6 RETAIL EACH $6.5;
    RFWB-1125 - 1928-34 HEADLIGHT BULB 125/75 CP QTY 8 RETAIL EACH $14.95;
    RFWB-2337 - 1935-39 HEADLIGHT BULB 175/75 CP QTY 2 RETAIL EACH $14.95;
    RFWBC-61 - ROUNDED END CHROME AMBER BRITE L QTY 1 RETAIL EACH $129.95;
    RFWBL-18 - 3/16? BRAKE LINE TEE QTY 1 RETAIL EACH $15.95;
    RFWBR-66 - BRAKE RELIEF RELAY SYSTEM QTY 4 RETAIL EACH $38.95;
    RFWCB-15 - 15A CIRCUIT BREAKER QTY 5 RETAIL EACH $9.95;
    RFWCB-25 - 25A CIRCUIT BREAKER QTY 2 RETAIL EACH $9.95;
    RFWCB-30 - 30 AMP PLUG-IN CIRCUIT BREAKER QTY 1 RETAIL EACH $10.95;
    RFWCT-30 - 3-1/2" BLACK CABLE TIES QTY 1 RETAIL EACH $4.5;
    RFWCT-60 - 8? BLACK CABLE TIES QTY 1 RETAIL EACH $5.5;
    RFWDA-16 - AMBER L.E.D INDICATOR QTY 6 RETAIL EACH $7.5;
    RFWDA-32 - AMBER 5/16" INDICATOR QTY 4 RETAIL EACH $8.95;
    RFWDA-50 - AMBER 1/2" INDICATOR QTY 1 RETAIL EACH $11.5;
    RFWDB-16 - BLUE L.E.D INDICATOR QTY 4 RETAIL EACH $11.95;
    RFWDB-32 - BLUE 5/16" INDICATOR QTY 3 RETAIL EACH $8.95;
    RFWDB-50 - BLUE 1/2" INDICATOR QTY 4 RETAIL EACH $11.5;
    RFWDG-16 - GREEN L.E.D INDICATOR QTY 3 RETAIL EACH $7.5;
    RFWDG-32 - GREEN 5/16 INDICATOR QTY 5 RETAIL EACH $8.95;
    RFWDG-50 - GREEN 1/2 INDICATOR QTY 2 RETAIL EACH $11.5;
    RFWDK-6 - DASH GAUGE WIRE KIT QTY 2 RETAIL EACH $87.95;
    RFWDR-16 - RED LED INDICATOR QTY 3 RETAIL EACH $7.5;
    RFWDR-32 - RED 5/16" INDICATOR QTY 4 RETAIL EACH $8.95;
    RFWDR-50 - RED 1/2" INDICATOR QTY 2 RETAIL EACH $11.5;
    RFWDS-05 - SYNERGY TOGGLE DIMMER SWITCH QTY 1 RETAIL EACH $25.95;
    RFWEL-38 - L.E.D FLASHER QTY 2 RETAIL EACH $73.95; RFWFN-6 - JUMPER CABLE CONT QTY 1 RETAIL EACH $27.95;
    RFWFP-5 - JUMPER CABLE CONT QTY 1 RETAIL EACH $27.95; RFWGA-10 - GROMMET ASSORTMENT QTY 1 RETAIL EACH $16.95;
    STE114878 - DISCONTINUED SENDER HALL EFFECT QTY 1 RETAIL EACH $96.95;
    STE279B-F - SDR, PRESS, 100 PSI, 240-33.5OHM QTY 1 RETAIL EACH $41.95;
    STE280EC - SDR, TMP, KIT, 100-230°F, 1/8" N QTY 3 RETAIL EACH $22.95;
    STE284AE - GA, PRESS, OIL, ELEC, HD, 0-80PS QTY 1 RETAIL EACH $48.95;
    STE284H - GA, VOLT, ELEC, HD, 10-16V, 2-1/ QTY 1 RETAIL EACH $52.95;
    STE334AB-D - SDR, TMP, 100-280°F, 3/8" NPTF, QTY 1 RETAIL EACH $18.95;
    STE366ACY - DISCONTINUED CLUST, 4-GA, DLX, 5 QTY 1 RETAIL EACH $0;
    STE366ACY-1 - DISCONTINUED CLUST, 4-GA, DLX, 5 QTY 2 RETAIL EACH $255.95;
    STE366ADB - FACTORY NON STOCKSDR, SPEED, FOR QTY 1 RETAIL EACH $72.95;
    STE366HM-F - KIT, TUBE, 16FT, 1/8" FEM PT & 1 QTY 1 RETAIL EACH $23.95;
    STE385AB-P - FACTORY NON STOCKSDR, FUEL LEVEL QTY 1 RETAIL EACH $37.95;
    STE391C-D - SDR, FUEL LEVEL, 240OHM, 15.5-24 QTY 1 RETAIL EACH $31.95;
    STE391D-D - SDR, FUEL LEVEL, 240OHM, 15.5-24 QTY 2 RETAIL EACH $31.95;
    STE413717 - SHUNT, AMM, 150 AMP/300 AMP QTY 1 RETAIL EACH $44.95;
    STE813642F - DISCONTINUED 3 HOLE CHROME PANEL QTY 1 RETAIL EACH $22.95;
    STE82112 - GA, VOLT, ELEC, DLX, 10-16V, 2-1 QTY 1 RETAIL EACH $54.95;
    STE82113 - GA, PRESS, OIL, ELEC, DLX, 0-80P QTY 1 RETAIL EACH $47.95;
    STRB01S - BRAKE TRIM - SPLIT ROUND QTY 2 RETAIL EACH $19.5;
    STRB02S - CLUTCH TRIM - SPLIT OVAL QTY 2 RETAIL EACH $19.5;
    STRB03N - STEERING COLUMN TRIM QTY 1 RETAIL EACH $39;
    STRB14NO-PLT - TRIM PLATE ONLY (each) QTY 3 RETAIL EACH $18;
    STRD03 - UNIVERSAL TRUNK LATCH WITH STRIK QTY 4 RETAIL EACH $39;
    STRD04 - UNIVERSAL DECK LID LATCH WITH ST QTY 3 RETAIL EACH $50;
    STRL07-40 - 40-AMP RELAY QTY 2 RETAIL EACH $17.95;
    STRL08 - BRAKE SWITCH QTY 3 RETAIL EACH $22;
    STRL22C - CABLE INSTALLATION KIT (1 DOOR QTY 2 RETAIL EACH $9;
    STRL24E - PAIR MINI LATCH QTY 3 RETAIL EACH $54.95;
    STRL52DL2 - DUMMIE LOADS FOR LED TURN SIGNAL QTY 4 RETAIL EACH $9;
    STRL53N - CLEAR LENS LIGHTS (PAIR) QTY 1 RETAIL EACH $25;
    SUS1612 - DUAL MNT PLATE QTY 1 RETAIL EACH $20;
    SUS1954 - DASH 54-55 C/PU QTY 2 RETAIL EACH $140;
    SUS2001 - SAT ALUM 3" RND "CNTR SWIVEL" MI QTY 2 RETAIL EACH $35;
    SUS2002 - SAT/BRSHD ALUM 3" RND (OFFSET) M QTY 2 RETAIL EACH $35;
    SUS2008 - SAT ALUM 2-3/8" X 3-3/8" RECT CA QTY 2 RETAIL EACH $35;
    SUS2013 - FOOSE L/H MIRROR HEAD 3-1/8" X 4 QTY 2 RETAIL EACH $45;
    SUS2014 - FOOSE R/H MIRROR HEAD 3-1/8" X 4 QTY 2 RETAIL EACH $45;
    SUS2018 - MIRROR LGE/OVAL SATIN QTY 2 RETAIL EACH $40;
    SUS2050LH - SATIN ALUM L/H SHORT MIRROR ARM QTY 1 RETAIL EACH $30;
    SUS2050RH - RH SHORT ARM QTY 1 RETAIL EACH $30;
    SUS2051LH - LH LONG ARM QTY 1 RETAIL EACH $35;
    SUS2051RH - R/H STRAIGHT LONG ARM QTY 1 RETAIL EACH $35;
    SUS2053LH - SAT/BRSHD ALUM "FAT" BENT L/H AR QTY 1 RETAIL EACH $35;
    SUS2053RH - SAT/BRSHD ALUM "FAT" BENT R/H AR QTY 1 RETAIL EACH $35;
    SUS2054RH - R/H TRUCK ARM QTY 1 RETAIL EACH $35;
    SUS2103 - SATIN ALUM STICK-ON INSIDE MIRRO QTY 3 RETAIL EACH $15;
    SUS2103P - STK-ON INSDE POS QTY 1 RETAIL EACH $25;
    SUS2110 - OVAL MIRR0R QTY 2 RETAIL EACH $35;
    SUS2120 - "FOOSE" OVAL INSIDE MIRROR HEAD QTY 2 RETAIL EACH $55;
    SSIS7507 - COPPER BIG BLOCK ROUND GASKETS ( QTY 1 RETAIL EACH $34;
    SSIS7508 - COPPER BIG BLOCK RECTANGLE GASKE QTY 3 RETAIL EACH $34;
    SSIS7541 - CHROME FORD 292-312 VALVE COVER QTY 2 RETAIL EACH $44.95;
    SSIS8422 - POLISHED ALUMINUM BB CHEVY TIMIN QTY 1 RETAIL EACH $40.95;
    SSIS8443 - POLISHED ALUMINUM 1980-84 SB CHE QTY 1 RETAIL EACH $89.95;
    SSIS8444 - POLISHED ALUMINUM 1985-UP SB CHE QTY 4 RETAIL EACH $89.95;
    SSIS8740 - POWER TRUNK LIFT KIT QTY 1 RETAIL EACH $179.95;
    SSIS9136 - 1" PHENOLIC CARBURETOR SPACER WI QTY 4 RETAIL EACH $13.95;
    SSIS9177 - CHROME FUEL FILTER - 3/8" INLET QTY 5 RETAIL EACH $2.95;
    SSIS9212 - CHROME FUEL FILTER - 5/16" INLET QTY 8 RETAIL EACH $2.95;
    SSIS9243 - REPLACEMENT O-RING FOR CHEVY/FOR QTY 19 RETAIL EACH $0.95;
    SSIS9344 - CHROME STEEL 1971-80 MOPAR 360 O QTY 1 RETAIL EACH $71.95;
    SSIS9357 - CHROME 1965-87 FORD 240-300 6-CY QTY 1 RETAIL EACH $24.95;
    SSIS9440 - CHROME 1965-75 FORD 260-289-302- QTY 4 RETAIL EACH $11.95;
    SSIS9617 - CHROME TWIST-ON BREATHER CAP - 2 QTY 3 RETAIL EACH $4.95;
    SSIS9620 - CHROME HOLLEY/AFB CARB MOUNTED L QTY 1 RETAIL EACH $7.95;
    TCI400-4106-00 - PAINTED SHORT SHOCKS QTY 1 RETAIL EACH $71;
    TCI400-4108-00 - PAINTED LONG SHOCKS QTY 1 RETAIL EACH $71;
    TCI400-4108-01 - CHROME LONG SHOCKS QTY 1 RETAIL EACH $104;
    TCI400-4190-00 - SHOCK STUDS QTY 2 RETAIL EACH $19;
    TCI400-4260-00 - LOWER COIL-OVER MOUNTS ONLY QTY 1 RETAIL EACH $74;
    TCI400-4356-01 - CHROME COIL-SPRINGS 400# FOR ALL QTY 1 RETAIL EACH $189;
    TCI400-4531-02 - PR.2INCH SPRG CL (discontinued w QTY 2 RETAIL EACH $28;
    TCI400-4544-02 - DISCONTINUED PR 2-1/4 STN SKL QTY 2 RETAIL EACH $62;
    TCI401-4001-01 - 28-32 WELD-ON F .SHOCK KIT(CRM) QTY 1 RETAIL EACH $245.95;
    TCI401-4140-00 - 28-32 WELD-ON SHORT SHOCK BKT QTY 1 RETAIL EACH $39;
    TCI500-5800-00 - 3/4" REAR ADJUSTOR (PLAIN) QTY 5 RETAIL EACH $24.95;
    TCI500-5812-00 - REAR URETHANE BUSHING(SET) 2 HA QTY 5 RETAIL EACH $9.95;
    VAA20557 VUP DISCONTINUED LIGHT BULB FOR VA 1 QTY 10 RTL 1.5
    VAA20558 VUP LABEL BLOWER SWITCH QTY 2 RTL 3
    VAA20559 VUP LABEL MODE SWITCH QTY 5 RTL 3
    VAA20570 VUP GEN II ROTARY MODE LABEL QTY 5 RTL 3
    VAA20571 VUP GEN II ROTARY THERM LABEL QTY 4 RTL 3
    VAA20572 VUP GEN II ROTARY HEAT LABEL QTY 1 RTL 3
    VAA24676 VUS TRINARY SWITCH KIT QTY 1 RTL 51
    VAA24677 VUS BINARY SWITCH KIT QTY 1 RTL 35
    VAA31603 VUA *6/8 CLAMP QTY 26 RTL 0.75
    VAA31604 VUA 10/12 CLAMP QTY 4 RTL 0.75
    VAA31700 VUD HOSE KIT W/DRIER 134A QTY 1 RTL 109
    VAA31702 VUD HOSE KIT W/O DRIER 134A QTY 1 RTL 105
    VAA33137 VUI GROMMET LARGE QTY 34 RTL 1
    VAA33859 VUF #10 O RING QTY 25 RTL 0.1
    VAA34102 VUG #10 SP SVR HD FTG, 134A QTY 1 RTL 15
    VAA34108 VUG GM A6/R4 COMPRESSOR FTG ASSY QTY 1 RTL 20
    VAA341080 GM COMP ADAPTER COMPLETE KIT QTY 1 RTL 35
    VAA34111 VUG *6 FLAIR BULKHEAD QTY 5 RTL 6.38
    VAA34113 VUG *10 FLAIR BULKHEAD FTG QTY 15 RTL 6.7
    VAA34116 VUG O RING / 6 ADPT QTY 7 RTL 1.25
    VAA34116 VUQ HEATER BULKHEAD QTY 2 RTL 69
    VAA34117 VUG O RING / 8 ADPT QTY 8 RTL 1.25
    VAA34118 VUG O RING / 10 ADPT QTY 22 RTL 1.25
    VAA34119 VUG O RING / 12 ADPT QTY 10 RTL 1.25
    VAA34131 VUG *6 FLAIR BULKHEAD FTTG QTY 3 RTL 7.1
    VAA34132 VUG *8 FLAIR 90 BULKHEAD QTY 1 RTL 7.25
    VAA34211 VUG #6 BULKHEAD FIT STR M ORING QTY 3 RTL 6.95
    VAA34213 VUG #10 BULKHEAD FIT STR M ORING QTY 3 RTL 8
    VAA34213 VUQ 2 WAY AC BULKHED QTY 2 RTL 34.95
    VAA34231 VUG #6 BULKHEAD FIT 90 M O'RING QTY 4 RTL 8.5
    VAA34233 VUG #10 BULKHEAD FIT 90 M O'RING QTY 5 RTL 8.85
    VAA34324 VUG *12 FITTING QTY 5 RTL 5.2
    VAA34411 VUG DISCONTINUED 3/8 FIT #6 HOSE STR QTY 16 RTL 4
    VAA34412 VUG DISCONTINUED 1/2 FIT #8 HOSE STR QTY 12 RTL 4
    VAA34413 VUG DISCONTINUED 5/8 FIT #10 HOSE ST QTY 15 RTL 4
    VAA34417 VUG 90 M ORING FTTG QTY 28 RTL 3.25
    VAA34419 VUG STR M ORING FTNG QTY 7 RTL 3.25
    VAA34421 VUG #6 FM 45 ORING QTY 21 RTL 4
    VAA34422 VUG 1/2 FIT #8 HOSE 45 FM ORING QTY 14 RTL 4
    VAA34423 VUG 5/8 FIT #10 HOSE 45 FM ORING QTY 8 RTL 4
    VAA34431 VUG 3/8 FIT #6 HOSE 90 FM ORING QTY 2 RTL 4
    VAA34432 VUG 1/2 FIT #8 HOSE 90 FM ORING QTY 25 RTL 4
    VAA34433 VUG 5/8 #10 HOSE 90 FM ORING QTY 14 RTL 4
    VAA34440 VUG #6 135 F ORING QTY 5 RTL 8.3
    VAA34441 VUG DISCONTINUED *10 FLAIR FITTING QTY 1 RTL 8
    VAA34442 VUG #8 135 FM ORING QTY 7 RTL 8.3
    VAA34443 VUG #10 135 FM ORING QTY 6 RTL 8.3
    VAA34445 VUG #10 FIT #12 HOSE STRAIGHT FM ORI QTY 2 RTL 5
    VAA34446 VUG #10 FIT #12 HOSE 45 F ORING QTY 9 RTL 5.6
    VAA34447 VUG #10 FIT #12 HOSE 90 FM ORING QTY 7 RTL 5.6
    VAA34825 VUG #6 SPLICER 134A PORT BARB QTY 1 RTL 15
    VAA34826 VUG #8 SPLICER 134A PORT BARB QTY 6 RTL 15
    VAA34827 VUG #10 SPLICE 134A PORT BARB QTY 4 RTL 15
    VAA35019 VCG 57CHV HARDLINE QTY 1 RTL 13.55
    VAA35043 VUG #8 FEEDER BTM EXIT 134A COND. QTY 8 RTL 12.25
    VAA35045 VFG #8 FEEDER S.EXIT S FLOW COND QTY 1 RTL 12.25
    VAA35177 VFG 39 40 FORD #8 COND/COMP LINE QTY 1 RTL 13.25
    VAA35178 VFG 39 40 FRD #6 COND/ENG COMPARTM QTY 1 RTL 13.25
    VAA35342 VUG #6 FEEDER BTM EXIT (03233) QTY 9 RTL 12.25
    VAA35344 VFG #6 FEEDER S.EXIT (03233) QTY 1 RTL 12.25
    VAA354100 #10 STR FM ORING # 12 HOSE BL QTY 25 RTL 5.25
    VAA354200 #10 45 FM ORING # 12 HOSE BL QTY 20 RTL 5.25
    VAA354300 #10 90 FM ORING # 12 HOSE BL QTY 16 RTL 5.25
    VAA35432 VUG #8 90 DEG. FIT W/134 SV.PORT QTY 6 RTL 15
    VAA35433 VUG #10 90 DEG FIT W/134 SV PORT QTY 1 RTL 15
    VAA35440 VUG #8 135 FM ORING W/134 PORT QTY 4 RTL 15
    VAA35442 VUG #10 135 FM ORING W/134 PORT QTY 3 RTL 15
    VAA35444 VUG *6 STRT ADAPTER QTY 1 RTL 3.9
    VAA35453 VUG DISCONTINUED 3/8 #6 HOSE FERRULE QTY 20 RTL 1
    VAA35455 VUG DISCONTINUED 1/2 #8 HOSE FERRULE QTY 18 RTL 1
    VAA35456 VUG DISCONTINUED 5/8 #10 HOSE FERRUL QTY 12 RTL 1
    VAA35532 VUG #8 90 FM BL ORNG 134A PORT QTY 1 RTL 15
    VAA35533 VUG #10 90 FM ORING W/SLV&PRT 134A QTY 1 RTL 15
    VAA35542 VUG #8 135 F ORING W/134 PORT BL QTY 2 RTL 15
    VAA35543 VUG #10 135 F ORING W/134 PORT BL QTY 1 RTL 15
    VAA35811 VUG #6 STR FM BL ORING QTY 4 RTL 4.5
    VAA35812 VUG #8 STR FM BL ORING QTY 2 RTL 4.5
    VAA35813 VUG #10 STR FM BL ORING QTY 2 RTL 4.5
    VAA35821 VUG #6 45 FM ORING BEADLOCK QTY 5 RTL 4.5
    VAA35822 VUG #8 45 FM ORING BL QTY 6 RTL 4.5
    VAA35825 VUG #6 SPLICER 134A PORT BEADLOCK QTY 3 RTL 15
    VAA35826 VUG #8 SPLICER 134A PORT BEADLOCK QTY 1 RTL 15
    VAA35827 VUG #10 SPLICE 134A PORT BEADLOCK QTY 1 RTL 15
    VAA35831 VUG #6 90 FM ORING BEADLOCK QTY 4 RTL 4.5
    VAA35832 VUG #8 90 FM ORING BEADLOCK QTY 3 RTL 4.5
    VAA35833 VUG #10 90 FM ORING BEADLOCK QTY 4 RTL 4.5
    VAA35841 VUG #6 135 F ORING BEADLOCK QTY 2 RTL 9.5
    VAA35842 VUG #8 135 FM ORING BEADLOCK QTY 2 RTL 9.5
    VAA35861 VUG #6 BULKHEAD STR M ORING B.L. QTY 13 RTL 8.5
    VAA35862 VUG #8 BULKHEAD STR M ORING B.L. QTY 2 RTL 8.5
    VAA35863 VUG #10 BLKHD STR M ORNG BL QTY 4 RTL 8.75
    VAA35881 VUG #6 BLKHD 90 BL M ORING QTY 10 RTL 8.75
    VAA35882 VUG #8 BLKHD 90 BL M ORING QTY 4 RTL 8.75
    VAA35883 VUG #10 BLKHD 90 BL M ORING QTY 13 RTL 8.75
    VAA36032 MPA #10 M ORING X 3/8 NPT ADAPTER QTY 1 RTL 21.95
    VAA36033 MPA #10 M ORING X 1/2 NPT ADAPTER QTY 3 RTL 21.95
    VAA36544 VUR #8 STRAIGHT FITTING W/SERVICE PO QTY 1 RTL 42.5
    VINA-16613-SS - S/S HOOD PROP KIT QTY 1 RETAIL EACH $39.95;
    VINA-16622-RS - RUBBER CORNER ST QTY 1 RETAIL EACH $4.95;
    VINA-16718-S - CENTER BUMPER SE QTY 1 RETAIL EACH $7.95;
    VINA-16739-AS - 28-'29 FORD RADIATOR SHELL LACIN QTY 2 RETAIL EACH $10.95;
    VINA-16739-BS - 30/1 SHELL LACE QTY 3 RETAIL EACH $11.95;
    VINA-16740-AS - 28-'29 FORD PASS COWL LACING KI QTY 2 RETAIL EACH $12.95;
    VINA-16740-BS - 30-'31 FORD COWL LACING KIT QTY 3 RETAIL EACH $14.95;
    VINA-16750-APAD - 28/29 HOOD LATCH PAD SET QTY 1 RETAIL EACH $6.95;
    VINA-16750-ASS - 28-'29 FORD S/S 3-HOLE HOOD LATC QTY 4 RETAIL EACH $13.95;
    VINA-16750-BSS - STNLS 30/31LATCH QTY 5 RETAIL EACH $14.95;
    VINA-16750-HCSS - H/LATCH CLIP SET QTY 2 RETAIL EACH $12.95;
    VINA-17508-SS - 12V STNLS COMPL WIPER KIT W/ARM QTY 2 RETAIL EACH $50.95;
    VINA-17681-AS - 28'-29' FD OPEN CAR BLACK INS MI QTY 2 RETAIL EACH $21.95;
    VINA-17681-SS - 30'-31' FORD OPEN CAR STNLS INT QTY 3 RETAIL EACH $37.95;
    VINA-17682-AS - 28'-29' CLOSED CAR BLACK MIRROR QTY 1 RETAIL EACH $23.95;
    VINA-17682-SS - POL S/S '30-'31 FORD CLOSED CAR QTY 1 RETAIL EACH $36.95;
    VINA-17741-A - POL S/S '28-'29 FORD CLSD CAR HN QTY 3 RETAIL EACH $49.95;
    VINA-17741-BL - 30-'31 FD CLSD CAR L/H HNG-PIN QTY 1 RETAIL EACH $49.95;
    VINA-17741-BR - POL S/S 30'-31' FD CLSD CAR R/H QTY 3 RETAIL EACH $49.95;
    VINA-17741-MH - DISCONTINUED WHEN GONE USE B-177 QTY 1 RETAIL EACH 23.95;
    VINA-18200-A - 28/29 WW BRACKTS (open car) QTY 2 RETAIL EACH $82.95;
    VINA-18200-B - 30/35 WW BRACKTS (open car) QTY 1 RETAIL EACH $79.95;
    VINA-18200-C - UNIV CLOSED CAR WING-WING BRKT K QTY 1 RETAIL EACH $82.95;
    VINA-18355-WC - CHRME METER WING QTY 1 RETAIL EACH $26.95;
    VINA-351000 - EACH 28-'31 FORD OPEN-CAR W/S WN QTY 2 RETAIL EACH $4.95;
    VINA-41512-S - 28-'32 FORD TRUNK LID HINGES QTY 1 RETAIL EACH $14.95;
    VINA-41615 - TRUNK LID STRIKR QTY 1 RETAIL EACH $8.95;
    VINA-45463-S - 28-'31 CLSD CAR '28-'34 P/U W/S QTY 4 RETAIL EACH $11.95;
    VINA-45475-SS - PIVOT BOLTS QTY 1 RETAIL EACH $7.95;
    VINA-45477-S - SLIDE ARM WASHER QTY 1 RETAIL EACH $5.95;
    VINA-46335-SS - 28'-31' MODEL "A" POL S/S HINGE QTY 10 RETAIL EACH $4.95;
    VINA-48284 - ESCUTCHEON SPRINGS QTY 59 RETAIL EACH $8.95;
    VINA-702350-0 - 28-'34 ROADSTER OUTSIDE DOOR HAN QTY 2 RETAIL EACH $29.95;
    VINA-702350-AL - 28/29 DOOR HNDL QTY 3 RETAIL EACH $45.95;
    VINA-702350-BL - 30/31 DOOR HNDL QTY 2 RETAIL EACH $45.95;
    VINA-702351-A - 28-'29 FORD NON-LCKNG DOOR HNDL QTY 2 RETAIL EACH $35.95;
    VINA-702351-B - 30/31 DOOR HNDL NON-LOCKING QTY 2 RETAIL EACH $35.95;
    VINA-702352 - LOCK-DECK HANDLE QTY 1 RETAIL EACH $32.95;
    VINA-702356-E - DK HNDL PAD QTY 1 RETAIL EACH $3.95;
    VINA-76819-A - MALE DOVETAIL QTY 2 RETAIL EACH $4;
    VINA-8100-A - 28'-29' FORD CHROME RADIATOR CAP QTY 1 RETAIL EACH $16.95;
    VINA-8100-C - 30'-31' FORD POL STNLS RADIATOR QTY 1 RETAIL EACH $22.95;
    VINA-8133-SS - STNLS 28/31 RODS QTY 1 RETAIL EACH $48.95;
    VINB-9030-SS - 32-'48 FORD CAR/'32-'50 TRK POL QTY 1 RETAIL EACH $16.95;
    VINBA-13613 - SATIN ALUM LED THIRD BRAKE LIGHT QTY 1 RETAIL EACH $42.95;
    VINBAAA-13771-SR - DOME LIGHT QTY 1 RETAIL EACH $35;
    VINC-13450-37 - 37/8 CHV T/LENS QTY 4 RETAIL EACH $7.95;
    VINC-13450-37BD - 37/8 CHV B/DOT QTY 2 RETAIL EACH $16.95;
    VINC-13450-39 - 39 CHEVY T/L LENS QTY 2 RETAIL EACH $7.95;
    VINC-13450-39BD - 1939 CHV B/DOT QTY 5 RETAIL EACH $16.95;
    VINC-13450-40 - 1940 CHV T/LENS QTY 5 RETAIL EACH $7.95;
    VINC-13450-40BD - 1940 CHV B/DOT QTY 3 RETAIL EACH $16.95;
    VINC-13450-41 - 41-'48 CHEVY T/L LENS QTY 3 RETAIL EACH $7.95;
    VINC-13450-41BD - 41'-48' CHEVY T/LT LENSE W/BLUE- QTY 2 RETAIL EACH $16.95;
    VINCHP-13125/6B - BLACK 33/34HL ST QTY 5 RETAIL EACH $48.95;
    VINCHP-13125/6C - CHRME 33/34HL STAND QTY 1 RETAIL EACH $44.95;
    VINCL-8658-W - T-STAT COVER QTY 1 RETAIL EACH $11.95;
    VIND-13000-SBP - "DIETZ" STYLE PRIMERED 7" H/L KI QTY 2 RETAIL EACH $68.95;
    VIND-13001-RM - OUTER RIM DIETZ QTY 1 RETAIL EACH $16.95;
    VINHR-13125/6-SS - POL STNLS "HI-BOY" H/L BRACKET K QTY 1 RETAIL EACH $60.95;
    VINHR-13405-BD - PONT STYLE TAIL QTY 2 RETAIL EACH $47.25;
    VINHR-13450 - LENSE PONT T/LGT QTY 5 RETAIL EACH $8.95;
    VINHR-13450-BD - LENSE PONT T/LGT QTY 3 RETAIL EACH $15.95;
    VINHR-13520 - PONT PAD EACH QTY 2 RETAIL EACH $6.95;
    VINHR-13550 - CHROME LICENSE PLATE LAMP ASSY QTY 7 RETAIL EACH $11.95;
    WWWBUNG - THREADED STEEL FUEL FILLER BUNG QTY 3 RETAIL EACH $15;
    WWWCR-45 - CURVED ROUND 45-DEG SPOUT ANGLE QTY 2 RETAIL EACH $115;
    WWWCS-45 - CURVED SQUARE 45-DEG SPOUT ANGLE QTY 1 RETAIL EACH $115;
    WWWCS-90 - CURVED SQUARE 90-DEG SPOUT ANGLE QTY 1 RETAIL EACH $115;
    WWWFS-90 - FLAT SQUARE 90-DEG SPOUT ANGLE QTY 1 RETAIL EACH $115;
    WWWTDF - TEAR DROP FLAT QTY 1 RETAIL EACH $135;
    GIBB-208 - DISCONTINUED 32 L/REAR COVER QTY 1 RETAIL EACH $80;
    GIBB-258 - 32 3W DECK LID QTY 1 RETAIL EACH $285;
    GIBC-413 - 33-34 SEDN L/RER QTY 1 RETAIL EACH $175;
    GIBC-430 - 33-34 STK TNL CV QTY 1 RETAIL EACH $110;
    GIBC-430R - TRANS TUNNEL QTY 1 RETAIL EACH $110;
    GEN1007E - ENGRVD FOR GENNIE 3 SPEED QTY 3 RETAIL EACH $19.95;
    GEN1012BB - LIGHTED R/M BOOT IND BK 4SP QTY 1 RETAIL EACH $84.95;
    GEN1015L - 12" SS LO SHIFTER STICK QTY 2 RETAIL EACH $63.95;
    GEN1023-10 - MOPAR SHIFTER MTG BRKT KIT (MID QTY 2 RETAIL EACH $52.95;
    GEN1023-3 - FMX SHIFTER MOUNTING BRKT KIT (M QTY 2 RETAIL EACH $52.95;
    GEN1023-6 - TH350 SHIFTER MNTG BRKT KIT (MID QTY 2 RETAIL EACH $52.95;
    GEN1023-7 - 4L60, 4L80, 400, 700 BRKT KIT (M QTY 1 RETAIL EACH $52.95;
    GEN1023-8 - 4L60E SHIFTER MTG BRKT KIT (MID QTY 1 RETAIL EACH $52.95;
    GEN1024-2 - RM C6 SHIFTER MTG BRKT KIT (REAR QTY 1 RETAIL EACH $52.95;
    GEN1024-6 - RM 350 SHIFTER MTG BRKT KIT (REA QTY 2 RETAIL EACH $52.95;
    GEN1024-7 - RM 4L60, 4L80 MTG BRKT KIT (4 BO QTY 2 RETAIL EACH $52.95;
    GEN1024-8 - RM 400 SHIFTER MTG BRKT KIT (REA QTY 1 RETAIL EACH $52.95;
    GEN1050 - LO-DAPT KNOB ADAPTER QTY 6 RETAIL EACH $24.95;
    GEN2005 - BLACK - LO-LINE PLUS BOOT QTY 4 RETAIL EACH $34.95;
    GEN2015 - EXP CLEVIS KIT QTY 1 RETAIL EACH $29.95;
    GEN3015 - KICK-DOWN- STANDARD (350 ONLY) QTY 2 RETAIL EACH $54.95;
    GEN3021 - DUAL THROTTLE - SPRING (S.S.) QTY 1 RETAIL EACH $9.95;
    GEN7005 - STEALTH THROTTLE PEDAL QTY 3 RETAIL EACH $114.95;
    GEN7006 - STEALTH BOOT QTY 2 RETAIL EACH $9.95;
    GEN7009 - STNLS FORD DIMMER SWITCH COVER QTY 1 RETAIL EACH $16.95;
    GEN8050 - COLUMN SHIFT KNOB - ALUMINUM QTY 1 RETAIL EACH $24.95;
    GEN8051 - DISCONTINUED ENGRV COLMN KNOB QTY 4 RETAIL EACH $19.95;
    GEN8056 - ANTENNA WATERPROOFING KIT QTY 2 RETAIL EACH $14.95;
    GENKNOB20006 - ALUM KNOB-PLAIN QTY 3 RETAIL EACH $14.95;
    GENKNOB20010 - PLAIN BLACK SHIFTER KNOB QTY 4 RETAIL EACH $11.95;
    GENKNOBEP1002 - NOSTALGIA SOLID IVORY SHIFT KNOB QTY 1 RETAIL EACH $24.95;
    GENKNOBGK9001 - SHIFT KNOB 'HUFFER BLACK' QTY 1 RETAIL EACH $39.95;
    GENKNOBGK9002 - SHIFT KNOB 'HUFFER RED' QTY 1 RETAIL EACH $39.95;
    GENKNOBGK9006 - SHIFT KNOB 'BULLET NOSE BLACK' QTY 1 RETAIL EACH $39.95;
    GENKNOBGK9007 - SHIFT KNOB 'BULLET NOSE PUPLE' QTY 1 RETAIL EACH $39.95;
    GENKNOBINR2006 - RESIN KNOB INSERT FOR GENNIE 5/1 QTY 3 RETAIL EACH $1.95;
    BIL72120 - MIR MNT INSIDE GLUE-ON POL QTY 2 RETAIL EACH $16.95;
    BIL72220 - MIR MNT INSIDE BOLT-ON POL QTY 1 RETAIL EACH $19.95;
    BIL72520 - DISCONTINUED OS ARM/STRT LEFT QTY 1 RETAIL EACH $19.95;
    BIL72625 - DISCONTINUED MIR ARM 5-1/2" PSGR QTY 1 RETAIL EACH $19.95;
    BIL72725 - DISCONTINUED MIR ARM BENT PSGR T QTY 1 RETAIL EACH $24.95;
    BIL73420 - MIR HEAD LG RECT POL QTY 2 RETAIL EACH $48.95;
    BIL73520 - MIR HEAD OVAL POL QTY 1 RETAIL EACH $53.95;
    BIL73620 - DISCONTINUED MIR HEAD 3" RD OFFS QTY 2 RETAIL EACH $47.95;
    BIL73720 - DISCONTINUED MIR HEAD 4" RD OFFS QTY 1 RETAIL EACH $52.95;
    SSIS6131C - CHROME ALUMINUM SB CHEVY SHORT VALVE COVER - BALL QTY 1 RTL EA 99;
    SSIS8491 - POLISHED ALUMINUM GM TURBO 350 TRANSMISSION PAN - QTY 2 RTL EA 109.9;
    BOR011264 - STRG U-JOINT STL 9/16-36 X 3/4 SMTH BORE QTY 1 RTL EA 71.83;
    BOR925201 - P/S HOSE KIT 2 PC SS GM PUMP TO 74-78 MUST R&P QTY 1 RTL EA 160.55;
    BOR921001 - BILLET TOP CAP FITS VEGA 140 STRG BOX MACH FSNH QTY 1 RTL EA 68.93;
    BOR013464 - STRG U-JOINT STL 3/4-36 X 3/4 SMTH BORE QTY 1 RTL EA 71.83;
    WAR20345-DOWNS - B/SCRN CHEV 34/35 STANDARD / DOWNS QTY 1 RTL EA 50;
    VIN67-17741-MH - POL S/S 4 RND REPL FOR HINGE-PIN MIRROR QTY 1 RTL EA 23.95;
    VINB-13324-3W - COWL LAMP PAD QTY 1 RTL EA 5.95;
    VINB-37118-S - 28-'31 WINDSHIELD FINGER PULLS QTY 3 RTL EA 59.95;
    BIL47320 - VENT CRNK FORD (TO 1948) POL QTY 1 RTL EA 74.95;
    EDL8133 - DUAL FEED LINE/THUNDER SERIES CARB W/FUEL FILTER QTY 1 RTL EA 94.85;
    EDL42494 - ELITE VALVE COVERS QTY 2 RTL EA 375.9;
    EDL4200 - 10-PLASTIC ALLEN PLUGS QTY 1 RTL EA 3.99;
    TCI600-6607-00 - GM 77-EARLY DISC BRK HOSE KIT QTY 3 RTL EA 180;
    TCI9510 - DIMMER SWITCH COVER QTY 1 RTL EA 25;
    TCI700-7602-00 - FORD RUBBER TRANS MOUNT(C4) QTY 2 RTL EA 76;
    PER1181LCS - IGNITOR (LOBE SENSOR) DELCO 8 CYL QTY 1 RTL EA 80.95;
    RFWWS-1 - 2-SPEED WIPER SWITCH - PLAIN QTY 1 RTL EA 17.95;
    CHR8866 - PULLEY ALTERNATOR GM (SATIN ALUMINU QTY 2 RTL EA 53.95;
    SUS2007 - SATIN ALUM 4 X 2-3/4 CAST MIRROR HEAD QTY 2 RTL EA 70;
    RNM1101S - SATIN SB CHEVY V8 QTY 1 RTL EA 49;
    PNJ1206-1/2 - HEAVY DUTY ADJUSTABLE END (1/2 INCH) QTY 1 RTL EA 24.95;
    TAY38008 - TEAL CONVOLUTED TUBING ASSORTMENT QTY 1 RTL EA 12.95;
    TAY42800 - CLIP-ON SEPARATORS 7-8MM BLACK QTY 1 RTL EA 6.95;
    TAY41056 - SHRINK SLEEVES BLACK QTY 1 RTL EA 7.95;
    SPWXLFWC - EXTRA LARGE FLEXIBLE S/S WIRE CONDUIT (PR) QTY 1 RTL EA 28;
    PRR1425 - CALIFORNIA MIRROR W/LED T/SIG LTS (PR) QTY 1 RTL EA 74.95;
    PRR8214C - SEAT BELT QTY 2 RTL EA 50;
    PRR8214D - SEAT BELT QTY 2 RTL EA 50;
    PRR8214E - SEAT BELT QTY 2 RTL EA 50;
    PRR8214F - SEAT BELT QTY 2 RTL EA 50;
    PRR06128 - CAST BAR (FLATTENS CURVE OF '32 DASH) QTY 1 RTL EA 15;
    PRR8400C - SEAT BELT QTY 1 RTL EA 14;
    PRR5210 - DUAL 10 (PULLER) REAR MOUNT FANS QTY 1 RTL EA 129;
    IDI2801000010 - CABLE SHIFT LINKAGE-2 IDIDIT COLUMN - GM TRANSMIS QTY 1 RTL EA 131.95;
    IDI2802000010 - CABLE SHIFT LINKAGE-2 1/4 IDIDIT COLUMN - GM TRAN QTY 1 RTL EA 131.95;
    IDI2801500010 - CABLE SHIFT LINKAGE-2 IDIDIT COLUMN - AOD TRANSMI QTY 1 RTL EA 193.95;
    IDI2401300010 - FLOOR MOUNT ADJUSTABLE 2 QTY 2 RTL EA 57.9;
    IDI2402300010 - FLOOR MOUNT ADJUSTABLE 2 1/4 QTY 3 RTL EA 86.85;
    IDI2510500040 - KNOB GEAR SHIFT DECO POLISHED QTY 3 RTL EA 77.85;
    IDI2510000040 - DRESS UP KIT DECO POLISHED QTY 2 RTL EA 89.9;
    IDI2500010040 - DRESS UP KIT PUSH IN POLISHED QTY 1 RTL EA 58.95;
    IDI2500250020 - DRESS-UP KIT TILT&TELE CHROME QTY 1 RTL EA 45.95;
    IDI2600000010 - INDICATOR ACRYLIC WITH POINTER 3 SPEED QTY 1 RTL EA 25.95;
    IDI2600050010 - INDICATOR ACRYLIC WITH POINTER 4 SPEED QTY 1 RTL EA 25.95;
    IDI2401400010 - FLOOR MOUNT CLASSIC CHEVY 2 QTY 1 RTL EA 15.95;
    IDI2401550040 - FLOOR MOUNT SWIVEL BALL POLISHED 2 FOR CHROME COL QTY 1 RTL EA 118.95;
    IDI2311000030 - DASH MOUNT BRUSHED 2 65-66 FORD PICK UP QTY 1 RTL EA 89.95;
    IDI2208310040 - ADAPTOR 3 BOLT POLISHED QTY 1 RTL EA 76.95;
    IDI2201100040 - ADAPTOR 9 BOLT SHORT STYLE POLISHED QTY 1 RTL EA 125.95;
    IDI2306470040 - COLUMN DROP 6 1/2 X IDIDIT II 2 POLISHED QTY 1 RTL EA 82.95;
    IDI3000053449 - RAG JOINT - 3/4-36 X 3/4 DD QTY 1 RTL EA 111.95;
    GRT3312 - STEERING WHEEL ADAPTER QTY 1 RTL EA 21.95;
    GRT3315 - STEERING WHEEL ADAPTER QTY 1 RTL EA 21.95;
    GRT3316 - STEERING WHEEL ADAPTER QTY 1 RTL EA 21.95;
    GRT3164 - STEERING WHEEL ADAPTER QTY 1 RTL EA 21.95;
    GRT3187 - STEERING WHEEL ADAPTER QTY 1 RTL EA 21.95;
    GRT3193 - STEERING WHEEL ADAPTER QTY 1 RTL EA 21.95;
    gRT3197 - STEERING WHEEL ADAPTER QTY 1 RTL EA 21.95;
    GRT3260 - STEERING WHEEL ADAPTER QTY 2 RTL EA 43.9;
    GRT3280 - STEERING WHEEL ADAPTER QTY 1 RTL EA 21.95;
    GRT3284 - STEERING WHEEL ADAPTER QTY 1 RTL EA 21.95;
    GRT3389 - STEERING WHEEL ADAPTER QTY 2 RTL EA 43.9;
    GRT3405 - STEERING WHEEL ADAPTER QTY 1 RTL EA 21.95;
    GRT3508 - STEERING WHEEL ADAPTER QTY 1 RTL EA 21.95;
    GRT3540 - STEERING WHEEL ADAPTER QTY 3 RTL EA 65.95;
    GRT3586 - STEERING WHEEL ADAPTER QTY 1 RTL EA 21.95;
    GRT5162-1 - STEERING WHEEL ADAPTER QTY 1 RTL EA 21.95;
    BAM93181 - BLOWER PARTS QTY 1 RTL EA 50;
    BAM93182 - BLOWER PARTS QTY 1 RTL EA 50;
    BAM93183 - BLOWER PARTS QTY 1 RTL EA 50;
    BAM93184 - BLOWER PARTS QTY 1 RTL EA 50;
    BAM93161 - BLOWER PARTS QTY 1 RTL EA 50;
    THU3349 - MUFFLER GLASSPACK STAINLESS QTY 2 RTL EA 160;
    THU3560 - MUFFLER STAINLESS GLASSPACK QTY 2 RTL EA 160
    DAKHND-3 - CONTROL HANDLE - EARLY GM QTY 1 RTL EA 42;
  2. 71buickfreak
    71buickfreak
    from Oklahoma
  3. 71buickfreak
    71buickfreak
    from Oklahoma
    to the top. Lots of good stuff available
