Technical Ford model A front cross member question on AV8 build
Discussion in 'Traditional Hot Rods' started by MR K., Oct 24, 2016.
  1. MR K.
    MR K.
    So on my roadster I am building I have the rear end where it needs to sit. That is with the frame almost level..little lower in the front. The rear cross member i have tilted back 3 degrees. The front member i have tilted it back 7 degrees. But between the frame and front cross member i have a ugly gap to fill on top now. I figure with the members in the correct angle the spring wont bind. Or do i make the member flush with the frame....which may bind my spring a bit when i tilt my axel 5 to 7 deg back.
    Sent from my LGUS991 using The H.A.M.B. mobile app
  2. MR K.
    MR K.
    My gut tells me just weld the big gap. The spring will move better with the correct geometry. Guess i jusy talked myself into it. [emoji1]
  3. cretin
    cretin
    How about a photo of what you've got going on?
    "big gap" is a bit of a relative term.
  4. I guess I'm not understanding what's going on here. I thought the Model A front crossmember already had the proper tilt built into it.
  5. 1946caddy
    1946caddy
    from washington
  6. Model A Gomez
    Model A Gomez
    I think Late to the Party is right, the crossmember has a built in angle. The crossmember is set in the stock frame straight and the front axle has the proper angle.
    Late to the Party likes this.
  7. MR K.
    MR K.
  8. MR K.
    MR K.
  9. MR K.
    MR K.
    This is tiled back 7 deg. Which is what my axle and spring should be
  10. MR K.
    MR K.
    Just mocking and tacking things up..and this just looks....well...just not right.
  11. Atwater Mike
    Atwater Mike
    Lay, Mr. K...an angle finder on the center of the member. You will see that there is already a 'manufactured twist', amounting to 7 degrees positive MORE than the 'flats' where it joins onto the frame. (looks like you have more at the center now, like 12... just a guess.
    But bear in mind one thing: Any frame 'rake' you end up with must be subtracted from the caster in the front member.
    Uhh...That'd be 7 degrees from LEVEL, and that is level with Terra Firma, that being the ground.
    MR K. likes this.
  12. MR K.
    MR K.
  13. BJR
    BJR
    Are you measuring at the ends of the crossmember, or where the spring mounts to? Should measure the angle where the spring mounts.
  14. MR K.
    MR K.
    I will need to look at the new member. I did know they had that built into them. I knew the orginal did.
  15. MR K.
    MR K.
  16. MR K.
    MR K.
    At ride height with and angle finder on the center front its tilted back 7.5 degrees.
  17. MR K.
    MR K.
    Center, front surface of the crossmember.
  18. MR K.
    MR K.
    My frame rake is 2 degrees down..so your saying my angle should be 5
  19. Guylian
    Guylian
    Mr K, Look at Edward Lloyd build threads from Germany. He shows how to address your gap problem!!!!!
  20. MR K.
    MR K.
    thanks guys! great stuff
  21. Ford Mike
    Ford Mike
    Did you end up just welding it in? My first thought would be this would really throw off your radiator angle, thus your hood length and gaps. I didn't do anything to the crossmember in my car and I am running 5 degrees of positive caster on my front axle
  22. MR K.
    MR K.
    No i just have things tacked. Im going to get the top flush with frame. Then re tack. I did know it had 5 deg built into it. But frame goes 1.5 degrees down to the front. So maybe a small adjustment might be needed
  23. Centre front surface?
    Shouldn't you be centre,on top of crossmember or am I getting it wrong?
  24. bct
    bct
    Who is the manufacturer of your cross member?
  25. MR K.
    MR K.
    bct likes this.
  26. MR K.
    MR K.
    Your right. I was wrong.
  27. All good,people who haven't made a mistake haven't made anything.
    nailed31 likes this.
