Technical Affordable header options on a 390fe in a 64 galaxie
Discussion in 'The Hokey Ass Message Board' started by Tommyk74, Nov 1, 2016.
  1. Tommyk74
    Tommyk74
    from Nashville
    I need some help tracking down affordable header options for my car
    First off my car is a 1964 galaxie with a 390fe with cast heads one day they will be upgraded to aluminum so I would like to use them on either but it's not a deal breaker. I have power steering, automatic trans, and the giant starter and generator. My galaxie is lowered with 3 inch blocks in the back and 1 1/2 coils cut on the front so ground clearance another problem.
    Any options would be great long tubes, shorties, mid-lengths, block huggers and or cast iron options all and all I'm looking for some advice form some of you guys that own galaxies or have owned
  2. RmK57
    RmK57
    I would rule out long tubes if your car is lowered. The affordable long tubes have the front two tubes p*** under the lower control arms, even with normal ride height they still drag on speed bumps. I would be looking at shorties and they may
    have to be modified to clear your steering box , crossmember, ...........
  3. rjones35
    rjones35
  4. Tommyk74
    Tommyk74
    from Nashville
    I was thinking 400 or less. I have been looking for header a long time Now and I know that number is going to be difficult or Impossible to get that cheep. I was just hopping Someone on here knew something I didn't.
  5. mikhett
    mikhett
    from jackson nj
    I have FPA LONG tubes on my 62 XL but its not lowered.I guess 700.00 in 2007 might not be AFFORDABLE, though.
  6. Tommyk74
    Tommyk74
    from Nashville
  7. Mr48chev
    I bought a set of their headers for a Cad 500 in a Chevelle/camaro the other day and they got here in record time and look pretty decent. Haven't tried them on yet. The welds are a bit sloppy in a spot or two and I might have to have my son touch those up but the price was great.
    They show a set for a FE in your car.
    https://racinginnovationandsupply.com/catalogsearch/result/?q=ford+390+exhaust+headers
    Also says the 65 and later is different than the 64 and earlier
  8. Rex_A_Lott
    Rex_A_Lott
    Buy your own tubing, make your own headers. After a while one of two things will happen:
    Either you will have a fine set of headers you can be proud of, or the price starts looking better and better for the others. Good Luck
    falcongeorge and X38 like this.
  9. Hot Rod Cowboy
    Hot Rod Cowboy
    http://maddogheaders.net/products/ford
    Scroll down a good ways. Part #9201 for '60-'64 Galaxies w/FE.
    $450 and made in the US.
    I don't have any first hand experience but I know some 4x4 guys that had good things to say about their headers.
  10. Tommyk74
    Tommyk74
    from Nashville
    These look pretty nice lots of different headers depending on your cars options
  11. FritzTownFord
    FritzTownFord
    First off, you're running an FE - nothing is cheap about building them. You want cheap, dump the FE and drop in a nice 5.0L and problem solved. Now, if you really want to keep the FE, your next problem is no matter which brand you buy they will be a Royal ***** to install in that Galaxie. Soooo...
    Just do it once and do it best with the FPA headers. They are built like a NASCAR project - don't leak at the heads or the flange, and they will last longer than your engine. (use studs and nuts). I know this because I've used two sets - one on my F-250 Camper (10 years with no leaks), and on my Hot Rod - three years and s****ed over curbs with no damage.
  12. Tommyk74
    Tommyk74
    from Nashville
    Trust me I know the exhaust manifold drama, and manifold bolts drama. I just installed fresh heads with studs and nuts I also installed an old street master intake . I only broke 3 blots in process. I put my cast manifolds back on shamefully.
  13. RmK57
    RmK57
    The Crites / Maddog headers are good value, ( I have a set on my 57) but there sure not going to work on a lowered Galaxie. Buy a cheap set of shorties and cut'em up to fit if you have to, who knows you may get lucky and not have to cut anything.
  14. Tommyk74
    Tommyk74
    from Nashville
    I feel way better about cutting up a set of 150 dollar headers then a 400 to 600 dollar set
  15. 57Custom300
    57Custom300
    from Arizona
    X2. Had a 63 Galaxie 4sp car way back when with a set of ****** long tube headers. You would think a big car like that would be easy to install those headers. You had to put the zbar and the header in at the same time with the engine jacked up against the body. Starter side was no easier. Car wasn't lowered either. If you had the heads off they would go right in though.
