Hot Rods Spalding Bros Repro, for "Too Tall" Ganahl.
Discussion in 'The Hokey Ass Message Board' started by Marty Strode, Jul 13, 2015.
  1. TerrytheK
    TerrytheK
    Well, you sure do make it look that way! :D
    Awesome workmanship here. Again, thanks to you and Pat for keeping this thread up to date and letting us follow along. The posts on the CHRR were fun to follow too - sure would love to make it there some day!
  2. 50Fraud
    50Fraud
    What a treat to watch this process! Thanks again!
  3. Marty Strode
    Marty Strode
    George, Jeff and Jerry switched to Alcohol after they blew-up the gas engine, about 8 seasons after they bought the truck in 2003. They also told me that Jim Oddy helped out with camshaft selection and setup the injector. When we walked into the track last Friday, I heard the familiar "Rump,Rump" sound, and told my buddies that it sounded like the truck. We hustled toward the noise, and sure enough, it sounds just like it used to. I just had to pose for this shot, to revive old memories ! Bizio @ Bakersfield 2016 #2.jpg Bizio.jpg
  4. Marty Strode
    Marty Strode
    Roo, I certainly enjoyed the visit, it's always great when you finally meet someone, that far exceeds your expectations in character, and I expected plenty. It was also fun to get in on your bargaining on those covers !
    1947knuck likes this.
  5. falcongeorge
    falcongeorge
    from BC
    :( the last time I saw it was probably 2004/2005. Are there any blown g***ers left in the NW?
    Like the hat! Last time in Vietnam, I got a Hawaiian Punch hat, I gotta keep an eye on it so my wife doesn't throw it out!:D
  6. DDDenny
    Marty
    So I'm sitting in the stands with no hair, hat, sungl***es, not even any sunscreen and I say to my pal that I sure wish I had brought my gardening hat, he looked at me kinda funny.
    Two places you don't wanna show up at without a hat, Bonneville and Bakersfield.
    Atwater Mike, volvobrynk and Tman like this.
  7. Marty Strode
    Marty Strode
    The only blown G***ers in the NW, that I know of are the modern ones, quite different from the ones we revived the cl*** with in the 80's.
  8. falcongeorge
    falcongeorge
    from BC
    :(:( God I miss that....
  9. Marty Strode
    Marty Strode
    I got quite a sunburn several years ago, it took a while to heal. Some of my old buddies in their 80's are dealing with skin cancer, I get a lot of remarks on my big hat, but I don't mind.
    1947knuck and loudbang like this.
  10. falcongeorge
    falcongeorge
    from BC
    I got my Hawaiian Punch hat after Deuce Days, man I got fried! My wife HATES it.:D If I ever make it to Bonneville, I gotta get a Pure pith helmet!
    volvobrynk likes this.
  11. Marty Strode
    Marty Strode
    Well, today between posts, I got the roll bar installed for a preliminary fit. I intentionally cut the legs a little long, so for now It's "Too Tall", kinda like the driver ! After I get the top edge of the body trimmed, rolled and welded, I will cut it to the proper height. IMG_7138.JPG IMG_7139.JPG IMG_7140.JPG IMG_7141.JPG IMG_7142.JPG IMG_7144.JPG
  12. D.N.D.
    D.N.D.
    Hi Marty
    Nice fit on the hoop into the body
    In about 65' here in so-cal George Boltoff ran his blown gas 92' like the truck with just a wisper of black out the pipes in the day light, so everybody knew that it was his digger and they sure do sound good that way
    DND
    falcongeorge likes this.
  13. Marty Strode
    Marty Strode
    The turtle deck has some rust in the driver side front corner. Rather than make a section to repair it, I am looking for that section (2" wide) off of an original 23-25 deck, to fit and weld. If anyone out there knows of one, PM me. Thanks. IMG_7145.JPG IMG_7146.JPG
  14. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Geez Marty,
    I figure with your skill you could knock that out in about 10 minutes. Piece of conduit as a hammer form and tack that baby in there.
    volvobrynk and loudbang like this.
  15. Marty Strode
    Marty Strode
    Bruce, I could make that part, but it would be easier and faster to fit real "Henry" steel in there. I would use a bead roller instead of conduit, however.
    1947knuck, volvobrynk and loudbang like this.
  16. Weedburner 40
    Weedburner 40
    Geez Marty, trying to take the easy way out[emoji16] . I have to agree, no matter how good you are, some things are still better if you can get a original replacement.
  17. Marty Strode
    Marty Strode
    Dale, What a great visit with you, on our way back from CHHR. Keep those projects and ch***is kits going ! I have already received a PM, on the possibility of the replacement sheet metal.
  18. Marty Strode
    Marty Strode
    I worked on the belly pan today. Using 18 ga electro-galvanized steel, I bent the sides around a 1" tube bending shoe. Some notching was required to clear suspension brackets on the outside of the frame rails, and the bellhousing area. It's just blocked up for a visual, it will be bolted to the outside of the rails. I will also bend up and install a 3/4" round tube frame, inside the pan for support and protection around the driver's feet. IMG_7148.JPG IMG_7150.JPG IMG_7153.JPG IMG_7156.JPG IMG_7160.JPG IMG_7161.JPG IMG_7162.JPG IMG_7157.JPG IMG_7158.JPG IMG_7159.JPG
  19. Weedburner 40
    Weedburner 40
    Yes Marty, it was a great visit, although a bit brief, especially when Bob decided he hadn't spent enough money in Backo
  20. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Marty,
    Being serious now:
    When you say you formed that around a 1" diameter 'bending shoe' is that the piece in the Brake? I see how the upper clamp is moved back, but what keeps the tube from just being pushed up when you start the bend? Is there a flat bar welded to the tube?
    As you can tell, my metal forming is more closely related to blacksmithing.
  21. Marty Strode
    Marty Strode
    Bruce, Yes, there is a 2" wide strip of 10 ga welded to the tube, I have them in all diameters, from 1/2" to 5-1/2". It makes it easy to hold bend centers. IMG_4203.JPG
  22. rooman
    rooman
    Good guess mate. The fingers/leaf in the brake is pinching a flat bar/strap that is welded tangential to the tube.
    Damn--holeshot by Marty. :)
    Roo
  23. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    :D
    The larger tube version shows the strap 'under' the tube. My guess, before I saw that, would have been 'tangential' to the O.D. Does that make sense?
  24. Rand Man
    Rand Man
  25. Marty Strode
    Marty Strode
    " Tangential" ? Where did you guys get that "Big Word" dictionary ?
  26. Marty Strode
    Marty Strode
    Here is a couple of better shots, showing the entire car. The top edge of the body will finished next. IMG_7165.JPG IMG_7163.JPG
    1947knuck, HEMI32, volvobrynk and 8 others like this.
  27. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    I liked the way it sounded when Roo typed it. I was an Autoshop Teacher. I used to come up with words like that for the kids to define and explain. Kinda like applied math.
  28. Marty Strode
    Marty Strode
    I worked on the top edge of the body surround today. With aviation snips, I trimmed off the vertical flange, and with a hammer and dolly, I flattened and trimmed the flange to the proper width. After adding the 2 filler pieces, I shaped the flange over the round tube and skip welded the total perimeter. Now I can shorten the roll bar to the proper height. IMG_7167.JPG IMG_7168.JPG IMG_7169.JPG IMG_7171.JPG IMG_7172.JPG IMG_7174.JPG
    1947knuck, HEMI32, volvobrynk and 7 others like this.
  29. Looking great Marty!
    Steve
  30. pgan
    pgan
    While Marty's doing the heavy lifting up in OR, I've been busy scrounging small parts. Earlier I mentioned two things: (1) This re-creation will be as exact as possible, but also practical, given my budget and the car's intended use. (2) Given No. 1, I can't afford a dash-full of 1st-series, curved-gl***, smooth-bezel S-W gauges like the ones you see in the original photo of the dash. Next best, I figure, are the much more affordable and available 2-5/8" black-face, step-bezel Stewart-Warners. I just found an NOS in-the-box fuel pressure gauge at the CHRR swap, so here's a look at what I have so far.
    The large mech. tach I got free and just had rebuilt by No. Hollywood Speedo with the correct drive. Now I'm looking for any sort of pre-'63 Chev/GMC distributor (Mallory, GMC truck?) incorporating a tach drive, that I can mate with one of my 12-plug Nash tops.
    I don't need the vacuum gauge, and a couple of the pressure gauges. What I do need are two Fuel level gauges, preferably a working 12V one with a sender. The Spaldings apparently hooked the other to a sender in the pan to read oil level. If it looks correct in the dash, that's good enough for me.
    The best find--thanks to a tip from Dennis Webb--is the Bell dash-mounted fuel pressure pump. The guy who had it, Dean Bernstrom, said he had it in his lakes Model A in '48, and that it's been in several race cars since. It's in great HAMB1.jpg HAMB2.JPG HAMB3.JPG HAMB4.JPG working shape, and the best part is that it has Bell Auto Parts embossed in the fluted handle.
    Next I'll try to get some progress shots of the engine at Bob McKray's. And I'm looking for someone in So-Cal who can groove dirt-track tires.
    I'm very glad Marty's doing the heavy lifting.
    Pat Ganahl
    1947knuck, HEMI32, CW's40TPU and 10 others like this.
