OK,... What adjustments, removals, etc will I need to drop a Flathead V8 onto a set of Modeal A rails?? I briefly heard something about either needing a different set of motor mount brackets or crossbrace or both and more?? just want to have everything I need going into it before I dig in. thanks in advance! Jason
I'll second Harry's suggestion on buying Mike Bishop's book. Couldn't have built my AV8 as far as I have without it! I've read mine to death and STILL get stuff out of it! Regards, Dave.
Me Too!! Definately get the Bishop/Tardel book...............I used two, one in the garage and one next to my lazyperson chair.
This is what step one looks like. Or you could bring the car motor & trans fab tools all together for a looksee and .
As if you neeed any more endor*****ts, get the Bishop/Tardel book for sure. It's probably the best written book on the subject. It gathers ALL of the old traditional ways of building hot rods under one cover. Like someone else said, I've got two. One for the shop and one for the library. Frank
Great book! I used it a couple of weeks ago when I carved a Deuce K-member to fit a Model A frame. The book is now in its third edition -- and still has wrong wishbone info. The '32 is correct, not too long. The '33-'34 is too short, by about 1-3/4 inches. Sorry for the error. We have never figured out how we did that! I lengthened a '33-'34 wishbone a couple of weeks ago, using a Model A yoke. I'll put together a short how-to and post it here this weekend for those of who have a '33-'34 wishbone. Consider it my penance. Mike
Just this weekend I tacked in my flathead mounts into my A frame. The book is great and has instructions for an un-boxed frame. However, I purchased my ch***is partially boxed. I could have modified the instructions from the book, but I pussed out and wound up buying motor mounts from Ch***is engineering. All the specs were supplied on where to install the mounts. After some careful measuring and t******* I tacked them in. The motor fits without a hitch and clears the radiator just fine. Probably cost a bit more than making them myself, however.
yup its a great read, was lacking on the how to fit an Olds rocket to your Model A bones....... never mind will figure that bit out, even for the Ch***is and build texch its well worth it.
