Let's Talk Cyclecars
Discussion in 'The Hokey Ass Message Board' started by Bigcheese327, Dec 4, 2007.
  1. motoklas
    motoklas
    from Bern, CH
    .......... more photos with VALE SPECIAL!
    ... no reading maps any more?
    chriseakin, Rolfzoller and Jacketch like this.
  2. Kume
    Kume
  3. banjeaux bob
    banjeaux bob
    from alaska
    14907090_1060253150761009_8673769805431566390_n.jpg From J-P C. ...
    chriseakin and Rolfzoller like this.
  4. banjeaux bob
    banjeaux bob
    from alaska
    14915694_657628341070959_8773244328618046967_n.jpg 14720393_657627671071026_1508488410957945781_n.jpg 14947547_657628184404308_8190140821166107704_n.jpg Just a few from H.K. ... #1) Messerschmitt Kabinroller,#2) Reminds me of one of those Baby Bugattis...electric powered,and #3) Heinkel.
    motoklas and Rolfzoller like this.
  5. banjeaux bob
    banjeaux bob
    from alaska
  6. The37Kid
    The37Kid
    ^^^^^^^^^^^^ Great photos! Bob
    Rolfzoller likes this.
  7. banjeaux bob
    banjeaux bob
    from alaska
    Duncan P. driving his GN up Honister Hill during the VSCC Lakeland Hillclimb. Dave C. image. ... 14925390_1180173942076753_1511714116690723717_n.jpg
  8. banjeaux bob
    banjeaux bob
    from alaska
    1415628022663_Image_galleryImage_dmvidpics_2014_11_10_at_1.JPG Another fabulous image of VSCC's Lakland trial.Sorry folks that it's Austin Seven.I just couldn't resist the look on the lady's face!
    tomkelly88, ebtm3, Jacketch and 2 others like this.
  9. She's driving right? He's hanging on for dear life!
    banjeaux bob likes this.
  10. ebtm3
    ebtm3
    And someone tilted the camera!
    Herb
  11. I dunno Herb, that Austin seems a little nose high, and almost rubbing the tires on the rear fenders :)
  12. The37Kid
    The37Kid
    You're right, they could be going down the return road. Bob
  13. banjeaux bob
    banjeaux bob
    from alaska
  14. motoklas
    motoklas
    from Bern, CH
    Jacketch, Rolfzoller, ebtm3 and 2 others like this.
  15. motoklas
    motoklas
    from Bern, CH
    P.S.: she is on film from minute 0:40 to 1:17, but entire film is nice!
    Z.
    banjeaux bob and The37Kid like this.
  16. rooman
    rooman
    Not so much if you watch the video Herb. (and also look at the people in the background of the original photo).
    Roo
  17. The37Kid
    The37Kid
    Thank you motoklas! That looks like a great event. Bob
  18. ebtm3
    ebtm3
    OK I was wrong (again!)
    Never thought that a Seven had enough b**ls to do that. I would be scared to death to wind a two main crank that tight ---no wonder guys broke them.
    Thanks, Zoran! Great post
    Herb
  19. Kiwi Tinbender
    Kiwi Tinbender
    Zoran....Brilliant!! Certainly way more of a real event than the poser Colorado Hillclimb that we Hotrodders have been fed as of late....:eek::):)
  20. Wonder if that Austin has a supercharger on it... kinda like dual exhaust on a VW- my grandfather described them as "about as effective as a fart in a windstorm" :D
  21. So, I have to ask... does bouncing up and down in the p***enger seat really help one get up a hill :D???
    My great-grandfather used to lean forward in the cab and talk to the steering wheel to "help" their corn delivery truck make it up the hills of Roxborough :)
    sorry for all the family history- just missin' my folks & Philly (and Herb and Doug)
  22. banjeaux bob
    banjeaux bob
    from alaska
    bill,they call it bouncing. I'm sure there are more videos out there of trials.I think the idea is that it bounces the rig out of rut while still moving with out stalling.You get stuck,you're all done.
  23. motoklas
    motoklas
    from Bern, CH
    From Wikipedia:
    The original 1922 four-cylinder Austin Seven engine had a bore of 2.125" (54mm) and stroke of 3" (76mm), giving a capacity of 696 cc and RAC rating of 7.2 hp. From March 1923 the bore was increased to 2.2" (56mm) giving 747 cc and 10.5 hp. The side-valve engine was composed of an aluminium crankcase, cast iron cylinder block and cast iron cylinder head. Cooling was by thermosiphon, without a water pump, and the dynamo was driven from the timing gears.
    The big end bearings were lubricated by jets from an oil gallery in the crankcase, the oil striking the crankshaft webs which were drilled accordingly. Originally the journal diameter was 1.125"; this was later increased to 1.3125". The three bearing engine (from 1936) used a white metal centre bearing.
    The splash-lubricated crankshaft (pressure fed on some sports models) at first ran in two bearings (two ball bearings at the front, roller at the back) changing to three in 1936.
    Some more information about Austin-7 engines...
    Zoran
    Ned Ludd likes this.
  24. motoklas
    motoklas
    from Bern, CH
    P.S.: Couldn't posted any picture, maybe later...
    Z
  25. motoklas
    motoklas
    from Bern, CH
    austin 1930 7 ulster, blower.jpg AUSTIN-7 specifications.jpg austin-7, engine 2 bearings.jpgF.jpg austin-7, engine 3 bearings.jpgF.jpg austin-7, engine 3 bearings.jpg austin-7, compressorDSCFd.JPG austin-7, compressorDSCF3116.JPG austin-7, compressorDSCFcx.jpg
    P.P.S.: I could!
    Z
  26. banjeaux bob
    banjeaux bob
    from alaska
    Rolfzoller, Kume and ebtm3 like this.
  27. SR100
    SR100
    Saw this on the 'As they were...' thread. I think it was based on a 1939 Crosley.
  28. Ned Ludd
    Ned Ludd
    Duly reposted on the Specials thread. Thanks!
  29. banjeaux bob
    banjeaux bob
    from alaska
    417039_386360161442634_2038557442_n.jpg Wales. G.C.L. image
    Ned Ludd, Kume and Jacketch like this.
  30. banjeaux bob
    banjeaux bob
    from alaska
    15032709_1159900914088551_9028292941630096339_n.jpg Sumner J.A.P. Special 1936. Via G.C.L. ...
    ebtm3 and Jacketch like this.
