  1. themoose
    themoose
    A little rework to the rear of the roof using madfish's rendering
    COUPES, 2redrovers, daddio211 and 2 others like this.
  2. waylow64bird
    waylow64bird
    from Buffalo MN
    Make this into a wagon [​IMG] please and thank you
    509garyd likes this.
  3. madfish
    madfish
  4. waylow64bird
    waylow64bird
    from Buffalo MN
  5. GASSERBOB
    GASSERBOB
    from USA
    Hi Moose. Could you color the 2 photos of my RPU in with the front fender color please? Thank you Moose. Bob.... 010.JPG 011.JPG
  6. superleggera
    superleggera
    a few additional tweaks in addition to the above ones. custom2.jpg .
    timmy2times, COUPES, themoose and 2 others like this.
  7. Squablow
    Squablow
    Takes skills to put shadows and reflections into a Photoshop job, but to match the level of blurryness like this is also impressive.
  8. themoose
    themoose
    Here's one....
    daddio211 and kiwijeff like this.
  9. themoose
    themoose
    And the second view
  10. OahuEli
    OahuEli
    from Hawaii
  11. Rocky
    Rocky
    Classified Editor
    53nashlow4door.jpg Some years ago I bought an old 53 Nash 4 door and played around with a little photo shop program....wanted to see what it'd look like slammed and then with the car shortened...looks like a huge Metropolitan!
  12. GASSERBOB
    GASSERBOB
    from USA
    Thank you very much Moose for your time. I appreciate it. Bob............
  13. waylow64bird
    waylow64bird
    from Buffalo MN
  14. COUPES
    COUPES
    from England
    Thankyou Madfish and Moose! Looks even cooler!
  15. Peanut 1959
    Peanut 1959
    I'd like to see a HAMB-friendly kustom based on these modifications, but using a proper photo. Maybe clean up the proportions a bit in the process. Any of you PhotoShop masters up for the challenge?
  16. themoose
    themoose
    Something a bit different
  17. madfish
    madfish
    Here's a few tweaks I'd like to make to Mooses photoshop rendition.
  18. OahuEli
    OahuEli
    from Hawaii
    timmy2times, gonmad, kiwijeff and 3 others like this.
  19. themoose
    themoose
    Just put a little lipstick on her.....
  20. OahuEli
    OahuEli
    from Hawaii
    Looks like a cu***ber with wheels.:eek::D
    Peanut 1959 and daddio211 like this.
  21. themoose
    themoose
    Yes but a very fast cu***ber...
  22. COUPES
    COUPES
    from England
    Looks awesome Superleggera! A friend posted a picture of it on FB and thought it needed a tweek. Thanks man!
  23. Peanut 1959
    Peanut 1959
    Just replace the wheels and tires with whitewalls, and I think we've got what I was after!
  24. HiHelix
    HiHelix
    Oh dear Lordy.. dats splendorific!
    themoose likes this.
  25. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    I'm back with another request. Madfish did this for me awhile ago. The real car is getting closer. The color will probably be a hunter green, not two toned.
    I posted this version because the detail is more visible. What I'm considering is the side lovers on the hood.
    The story is that when the GM br*** was making the final approval on this detail that the drawings were laying on a table and when they were signed, the signatures were upside down. So, the louvers wound up being 'upside down'.
    After searching I could only find one example of someone flipping them. (Which I believe involves cutting a section out of each side panel and flipping them side to side.) In this instance, the section was also lowered. What I would like to see is the louvers with the side 'bubble' reversed in place. And as an option, just the louvers switched leaving the 'bubble' in it's original orientation. Finally, the stainless trim. I would like to see it on and off in each version.
    Here is the hood side from the actual car. I have the material to make two complete hoods, one with the modification and one stock. I just don't want to cut up metal until I see what it is going to look like.
    Thanx in advance,
    Bruce
    Blownfuel likes this.
  26. themoose
    themoose
    @GearheadsQCE
    Not sure if this is what you want plus I see a lot of variations for hunter...
    kiwijeff and madfish like this.
  27. 'Mo
    'Mo
    Would anyone care to put '56 Buick lenses in these bezels?
    (...and feel free to fix the paint, if you'd like.;))
  28. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Yes that's it. When I looked carefully at the actual hood sides, I realized that the louvers were made in such a way that they can be flipped as you have shown, but that the louvers themselves have the wrong 'rake'. I had to look at them for a long time to see why they just didn't seem right.
    I think that the louvers need to be in the orientation of your second picture but at the top of the 'bubble' like the original. Seeing how the metal was shaped that would make it necessary to cut each one out and weld it in separately. Thanx for the Photoshop. You saved me a lot of work. I like the color of green you made it. I may go a shade or two darker, but that's close.
    By the way, I think the story about the upside down drawing is false. Looking at the real metal, you can see that it was intended to be the way it is.
    Thanx again,
    Bruce
  29. Rikster
    Rikster
  30. themoose
    themoose
    'Mo, timmy2times and Peanut 1959 like this.
