Who makes a good sand blast cabinet, i'm looking to buy a small one are they all about the same? Thanks.
I bought one of the $199 Harbor Frieght Cabinets, seems to work fine. Had problems with the light switch, and had to make up some spacers when I ***embled it to get the bottom gasket to seal properly.
Have the H F one too, had the same problem with the light switch. After you ***emble it make sure to go around all the inside seams with caulking or seam sealer before you put sand in it, makes a big diference on the sand dust in the garage. Also a good water trap helps a lot too. Works pretty good for the money.
Try these guys they a lot of choices.Have all the replacement parts to. http://www.tptools.com/dept.asp?dept_id=12&from_header=yes
A buddy of mine built a quickie cabinet from a large plastic storage container and a small bucket gun sandblaster. He put a small plastic window in the top, cut glove holes and taped in sleeved gloves and just put his trouble light in for light. Worked pretty well for about $20 invested. Flatman
