Technical RADIATOR SUPPORTS
Discussion in 'The Hokey Ass Message Board' started by mad mikey, Nov 8, 2016.
  1. mad mikey
    mad mikey
    Hello hambers. I would like to see some pics, ideas for rad. supports on early 30s cars other than fire wall mounted type. Thanks in advance. Mikey.
    dana barlow likes this.
  2. Atwater Mike
    Atwater Mike
    Mikey... I've seen some 'magazine cars' with 12" support 'struts' that went from 8" up on the radiator shell 45 degrees down to 6" back onto the frame rail, both sides. Looked clean, but I like the firewall rods. (just 'old & stubborn'):D
    mad mikey and dana barlow like this.
  3. dana barlow
    dana barlow
    from Miami Fla.
    This is also about the same as I did,running from part way up down to frame. Running from rad top, too top firewall would get messed up in my 4x2 carbs 002 (4).JPG
  4. chevy57dude
    chevy57dude
    ^Yeller engines are cool^
  5. TTTT8
    TTTT8
    Had to go digging thru old photos, but here is what I did long ago in my T-Bucket. I picked up the radiator support with a threaded rod, then the rod split in to two other rods, each going to an open bolt hole on the heads. To be clear, the motor mounts were solid (actually the rubber donut type, so very little engine movement) and there was no mechanical fan in the way. The triangular shape stopped the radiator from flopping around on crummy roads. This was taken when it was painted black, before it was chromed.
    Sorry I don't have any other photos of it, but dang, that was over 20 years ago. Hope this gives you an idea to work with.
    dana barlow and mad mikey like this.
  6. mad mikey
    mad mikey
    Thanks Mike, Dana, and TTTT8, some cool ideas there. Been thinking of changing them on the coupe.
