Projects The bucket of ugly! A de-uglifying thread...
Discussion in 'The Hokey Ass Message Board' started by need louvers ?, Aug 14, 2013.
  1. 26 T Ford RPU
    26 T Ford RPU
    Fred, I was waiting for you next build instalment eagerly and this bomb shell is just the coolest thing, totally awesome. :cool::cool::) JW
  2. tfeverfred
    tfeverfred
    Thanks! Next up will be to get the rear shocks and be done on that end.
    On a funny note about saving money, my new intention was to get the brake calipers and rotors from the auto parts store and use Speedways bracket kit to install them. That would run $286+ tax. If I go with Speedways full kit with rotors and calipers, it'll be $294. Plus, Speedways kit has all the bearings and seals. Sometimes, ya just can't beat the Hot Rod parts suppliers.:)
  3. tfeverfred
    tfeverfred
    Oh, having never cut the arms off Henry spindles, I may have some questions for you guys. I REALLY can't afford to screw these up. I already have a brand new grinding disc and new cut off wheels. When I get in from work on Monday, the package will be waiting for me. This is worse than waiting for the brown truck!:mad:
    daddio211 and 26 T Ford RPU like this.
  4. 26 T Ford RPU
    26 T Ford RPU
    Be super careful with the cut off disc !! :rolleyes::eek:;) JW
    loudbang, daddio211 and tfeverfred like this.
  5. tfeverfred
    tfeverfred
    Why? I've got 8 fingers and 2 thumbs. Losing 1 or 2 will be okay. Right?:D Seriously, I'll be careful.
    need louvers ? and 26 T Ford RPU like this.
  6. 26 T Ford RPU
    26 T Ford RPU
    I was too, sometimes its just not enough. The funny thing about what I did was that the Surgeon that put me back together was missing a finger on the same hand from an angle grinder:confused:o_O JW
  7. loudbang
    Tell the parts donor that was a very good thing he did
    Dick Stevens and daddio211 like this.
  8. steel rebel
    steel rebel
    Wow Fred some F1 brakes would fit so good on those.
    Just had to throw that out because you mentioned me a while back.
    Build your own car.
    Gary
    need louvers ? likes this.
  9. justabeater37
    justabeater37
    I started with a rusty old T touring front half, threw it on an A frame I had sitting in the shop. The look kind of grew on me. image1.jpg 12821386_823578647754510_1522295415493224236_n.jpg
    daddio211 and loudbang like this.
  10. justabeater37
    justabeater37
    14937338_979682168810823_7259352434357947527_n.jpg 14695514_969985793113794_5245735961221156941_n.jpg 14725763_969985986447108_8830342319138186357_n.jpg A bunch of time and spare parts later it is starting to look like something. 14937338_979682168810823_7259352434357947527_n.jpg
    kiwijeff, AndersF, daddio211 and 4 others like this.
  11. Good job to the anonymous donor!
  12. tfeverfred
    tfeverfred
    Having had the tracking #, I knew what would be waiting for me, when I got home today. Checked the pieces out and did a quick test fitting. Drank a beverage and just stared at them for a while. Thanks again, sir. Gawd, I love this hobby!
    I had already gotten a couple new cut off wheels and a new grinding disc. I'll probably cut and grind the left over arms this weekend.
  13. tfeverfred
    tfeverfred
    Today I cut off the remaining arms off the spindles. Worked out great. Final smoothing will be tomorrow. HOO YAH!
  14. need louvers ?
    need louvers ?
    Good lookin' work Fred!
  15. 66panel
    66panel
    So what do you do for steering arms?
  16. 26 T Ford RPU
    26 T Ford RPU
    My guess would be doped bolt on items. JW
  17. tfeverfred
    tfeverfred
    Gary, the further I get, the more I'm feeling the drum brake vibe. When I get to that stage, which hopefully won't be long, I'll seriously do some heavy thinking on it. This isn't a "traditional" build, but it'll be nice. My vision for this car is awesome (if you could get in my head, you'd agree) and I'm doing everything I can to stay on track. Ideas and suggestions, as well as critiques are always welcome. This is only my second rodeo, but it'll be my best effort.
    Dick Stevens and Tim_with_a_T like this.
  18. tfeverfred
    tfeverfred
    I'm going with the flat bolt on style mounted in front of the axle. Since I'm going with a spring behind the axle setup and wishbones, the usual steering arms won't clear.
  19. tfeverfred
    tfeverfred
    Thanks, but when are you going to give us an update on yours? While I'm grateful for being allowed to piggy back your thread, I'd much rather see what you've been up to.
  20. steel rebel
    steel rebel
    Fred like I ended my last post "build your own car" I wouldn't have posted if you hadn't mentioned me earlier. I'm sure my '50s/60s build mind works different than your '80s/90s thinking. If I were in your place I would go down to the junk yard and find an early '50s Ford truck and take the front brakes off of it, take them apart and rebuild them. Yes I know those old trunks aren't in the abundance now as they were in the past but that's still my thinking.
    Here again Fred I'm just talking and I am sure your bucket will be *****in!
    Tman likes this.
  21. Blue One
    Blue One
    from Alberta
    I have the spring behind the axle Fred and wishbones.
    I also have my steering arms to the rear with the tie rod behind the rad.
    And as you know I have drum brakes now too.
    whiplash1923T and daddio211 like this.
  22. tfeverfred
    tfeverfred
    Man, what arms are you using? The dropped ones I've looked at won't clear the wishbones.
  23. tfeverfred
    tfeverfred
    Gary, I just like to jab at you because I know how you hate disc brakes. Trust me, if the junk yards here didn't crush everything pre 2000, it would change my direction on a lot of things. On my budget, I'm limited to what I can find and afford. So, building it my way is really a no brainer.:)
    Nothings for sure. But I'm going at a pace that, while it's frustratingly slow, it allows me to research each and every step. Hell, in my head, I've got 2,000 miles on this thing.:D
  24. Blue One
    Blue One
    from Alberta
    You can see pictures on my build thread of how they worked out, they are extra long Superbell steering arms from Pete and Jakes.
  25. tfeverfred
    tfeverfred
    You have a link?
  26. Blue One
    Blue One
    from Alberta
  27. Blue One
    Blue One
    from Alberta
  28. tfeverfred
    tfeverfred
  29. Blue One
    Blue One
    from Alberta
    Good luck Fred. I scratched my head a lot trying to figure mine out.
    The primary consideration for me was not pointing the steering arms to the front of the axle.
    To me that just isn't right.
    It took some doing but I got it.
  30. need louvers ?
    need louvers ?
    Fred, I have to second the use of F-1 stuff. They don't seem to be rare, and you can buy the drums, shoes, wheel cylinders and such at any brake warehouse and most parts stores when you need them. The bonus is, not only '48-'52 F-stuff will do the deal, but also '53-'56 stuff as well. Guys have been yanking these front ends out from under these trucks for about 35 years now to modernize, and are common as dirt. I could have a set for ya by 2PM, no questions asked....
    'Bout 100.00 seams to be the going rate around these parts, and Speedway sells a bearing kit for about 40.00. I say all this, 'cause man, drums look sooooooooo much better on a "T", even if "traditinal" isn't really the end game. My F-1s stop my car like nobody's business, as well as discs would, and are simple and compact. Think about it a bit....
    The way to go about this is a pair of forged steering arms from all the major suppliers for '35-'48 Ford applications. Speedway's number is 702 2756 pln for 69.95, although i'd look at Super bell and others as well. hey drop the tie rod 3 3/4" and sneak it right under the lower rail of the hairpins. Use a regular early Ford tie rod. much stronger than the flat plate and heim end stuff. You can kinda see mine in this picture.
