Hot Rods GM fuel tank float to ford gauge
Discussion in 'The Hokey Ass Message Board' started by okiewelder, Nov 10, 2016.
  1. okiewelder
    okiewelder
    from central Ok
    I have a 62 ford unibody truck. Several years ago l was in a hurry to get it on the road. Well long story short l got a generick aluminum fuel cell and mounted it in the bed. It has a gm float and my gauge is ford. Any easy way to make it work?
  2. Paul
    Paul
    Editor
    Swap out the sender
    firstinsteele likes this.
  3. squirrel
    swap out the sender. Or put a 10 ohm resistor in series with the GM sender, and read the gauge backwards. If you have a 30 ohm sender, it will be kind of close, but if you have a 90 ohm it might not be quite what you want. At least it's cheap to try it.
  4. ffr1222k
    ffr1222k
    Is the GM sender the 0 - 30 ohm (prior to 65)or is it the 0 - 90 ohm (65 to present day)?
  5. okiewelder
    okiewelder
    from central Ok
    I actually have the sender out of the tank. I tryed a old ford one that was in another tank but didnt bend it properly to work. Thank you for the replys
  6. squirrel
    measure the resistance....
  7. okiewelder
    okiewelder
    from central Ok
    Well my cheap *** multimeter will not read the ohms. It will read it but, l can take the leads off and get a totally different reading the next time l hook it up!
  8. squirrel
    what happens to the reading when you move the sender arm? They usually do bounce around a lot.
  9. okiewelder
    okiewelder
    from central Ok
    Oh yea the resistance changes like it is supposed to on the float. My multimeter just gives me a different reading each time l try it.
  10. squirrel
    what kind of numbers do you see? Can you get it to settle down somewhere near the full end of the scale? It should be either close to 30 ohms, or close to 90 ohms.
  11. RICH B
    RICH B
    Long time ago, when a buddy added a extra tank to his '60 something Ford PU, we cut the sender apart and re***embled it with the rheostat upside down to get around the gauge reading backwards problem; but we were young and stupid and didn't know you couldn't do stuff like that.
  12. squirrel
    That sounds a lot easier than just sticking a label on the gauge!
    RICH B likes this.
  13. ffr1222k
    ffr1222k
    It may be giving you different readings because of the location of the wiper on the variable resistor being different each time. If you haven't yet, try your reading with the float all the way up and all the way down. You probably have the 0-90 ohm float. If so, you will read inverse of what the gauge indicates, but you will stay on E a long time, and run out of gas between 3/4 tank and full.
    Do like Jim did and remark the gauge or just know that it is backward and use as is.
  14. okiewelder
    okiewelder
    from central Ok
    Yea in my first life after hs when l was trying to get college educated l was a electronics tech. It has been a few years but, l kinda remimber how to use a multimeter. The cheap one l has shows different values when the float would be in the empty position
  15. BJR
    BJR
    That looks like something you would only do on an Edsel.:p
    squirrel likes this.
  16. 5brown1
    5brown1
    I just purchased a product which functions exactly like the one from tanks from Spiyda Design in England. Cost was about $56 including shipping to USA. They have videos on line showing the operation. Haven't installed it yet as I just got it Thursday. It is called the Gauge Wizard MK3
  17. Texas57
    Texas57
    Or add a gas gauge that matches the sender.....or, get a gas gauge that can be programed to match any sender's ohms range(without even knowing what the sender's range actually is). Speedhut makes them I'm told.
