Projects Hand Made Intake...Webers on a 332
Discussion in 'Traditional Hot Rods' started by Ron Falk, Nov 9, 2016.
  1. big duece
    big duece
    from kansas
    Speaking of cams the OP will have to look for a wide lobe seperation, with as little overlap as possible to prevent reversion at high rpm. Inglese suggest cams with 112 lobe seperation or wider up to 115 degrees.
  2. ghornbostel
    ghornbostel
    Cam was a concern when I did my motor. It occurred to me that reversion at high rpm to Jim Inglese is 8000 rpm. Looking at grinds it was apparent that the state of tune I was looking for, the cam to do that ran out of power at 5500 rpm. When I questioned about reversion, I was told by a few Weber tuners that it probably wouldn't be a problem at below 6000 rpm. With the hood and air cleaners off I have observed the carbs at that rpm and didn't see reversion. Also over the span of 30000 miles have I not observed raw fuel inside the air cleaner boxes. This is my experience and only something for you to consider. The cam is a Crower 282 and has 107* lobe separation and 26* overlap.
    Sent from my iPhone using The H.A.M.B. mobile appp
  3. big duece
    big duece
    from kansas
    Good seat of the pants feedback, thanks for sharing! I doubt too, that when I get mine going I will not be buzzing 8k for the concern of reversion.
  4. Ron Falk
    Ron Falk
    I can certainly tell you this will not spin over 6000. The good news is that the Crankshaft is good,and the old cam is good to grind with. I should have those back in a week or two. I will press on with the Manifold later this week...Then there are a few less important projects.... I have to get an FE Flywheel drilled yet,and figure out my motor mounts.. I am wondering if it is worth the money to get an Aluminum flywheel..This Lincoln one is 8000 Lbs!!!
  5. saltflats
    saltflats
    from Missouri
    If it's 8000 Lbs you better stay with a steel flywheel.
  6. Mike VV
    Mike VV
    from SoCal
    YES...looks good so far, but DO make the runners flush with the inside of the plenum box.
    Then, put a LARGE bead of weld on the outside of the runner to plenum box, then with a grinder, form a nice large radius inside for the fuel/air to be able to roll around a radius rather than a hard corner.
    Hard corners are NEVER good in heads or intake manifolds.
    Mike
  7. Ron Falk
    Ron Falk
    Welll...we are finally back in business on this whole set-up. I had to s**** my aluminum manifold...and went to Stainless...as my Tig gave up the ghost.. This will be pretty much the same as I used the templates from the old manifold,but will be polished when its done. I am still waiting for my Cam to come back,and for the Crank to get here..so at least I have some time. Next week,my head palte material should be here...and the runners are already being polished here at the shop.
  8. drtrcrV-8
    drtrcrV-8
    Would you care to discuss how you arrived at a '59 Lincoln and 332"? The last Lincoln Y-block was '57, & Lincoln didn't come in 332", although between Lincoln & F-8 Ford truck parts(up through '64) you could probably come up with that number. What block, what bore size, which crank, what stroke, what aftermarket rods, etc???Also what year /size heads?
  9. jvpolvere1
    jvpolvere1
  10. H380
    H380
    from Louisiana
  11. Ron Falk
    Ron Falk
    Hi,sorry for the delay. It is a truck motor out of an F600.
    It looks like I may be s****ping the whole project though.....the machine shop called...and nobody can get .030 bearings for her.I cannot justify welding the crank....its just too costly..Might be time to count my losses on this one :(
  12. mrhp
    mrhp
    from MICHIGAN
    Found some bearings on fee bay. I would add a link, but don't know how. Just search 332 y block bearings. That's how I found them. Good luck.
  13. Ron Falk
    Ron Falk
    Thanks for all the info...I went down all the avenues from everyone here...and got some NOS bearings headed my way! Thank god for this site...Im just a youngster to these old motors...and need all the knowledge i can get!
    Thanks
  14. Ron Falk
    Ron Falk
    I stand corrected...it was an F-800.
  15. mrhp
    mrhp
    from MICHIGAN
    Great news! I hate to see somebody hit a wall on a build.
    Ron Falk likes this.
  16. glrbird
    glrbird
    Royce Brechler (they misspelled his name) knows tons about these engines and parts. He can be found at www.y-blocksforever.com (RB) , nice guy and some one you should know.
  17. drtrcrV-8
    drtrcrV-8
    Was the cam gear drive or timing chain? Suggest '57 Lincoln or Mercury TP Cruiser heads(largest 'stock' valves) The truck crank should be forged steel(good thing!!), instead of cast Nodular Iron(cars), the rods should also be better, Like I mentioned earlier: check '57-up trucks(& Schoolbusses) for intake manifolds that take "modern" Holly bolt pattern carbs(also good source for 'Rams-Horn Ex manifolds). You probably have other ideas, but always good to know possible alternatives, 'just-in-case'! Also, look up RICH FOX (he's played with these motors a bit as well). Also how to use FE Bellhousings/Flywheels on these motors.
  18. drtrcrV-8
    drtrcrV-8
    ALSO : I'm glad to see someone else who's not afraid to try something different : WELCOME to the "DARKSIDE" of hotrodding!! Anybody can mess with Chevys, but it requires DEDICATION to go out into the dark with an "Unpopular" motor that your friends & relatives will ask "Why you messing with that piece of S@%%# ? It's so much safer/cheaper/easier to drop a Chevy in it & go!" They just don't 'get' it! SO :Welcome to a place where you have to THINK/do your own research/ build it your own way! AND REMEMBER TO HAVE FUN DOING IT!!! LOL!
  19. Ron Falk
    Ron Falk
    I will be running the Truck heads for now...I had them milled down,and will keep an eye out for the better heads.I did get the Ram Horns with it,and they will be going on as well.It looks like I will be putting the whole Enchilada together over Xmas break.My Crankshaft and Cam just got done,and my bearings are finally here!! The Crank is the Forged Steel..I had to take .040 off the mains,because it was the only available bearing..I also have an FE Bell..and will more than likely use a lighter FE flywheel and get it Re-Drilled.
    I still need to get the Intake plates back from the machine shop though...but thats the easy part. I wonder what kind of power this thing will make.I had a 272 in the old Fairlane..The 332 is punched.040....so that should put me at like 341....or close.
    I cant wait to fire this thing up!
    timmy2times likes this.
  20. Ron Falk
    Ron Falk
    I have never done so much research in my life...LOL
    Thjanks for the help!
  21. drtrcrV-8
    drtrcrV-8
    In many ways you've gone a lot further with your build than I did some 50yrs ago: all I did was drop some 11.5/1 x .030 over Jahns cast pistons into a '57 Lincoln 368, home ported the heads, used an adapter to put a later Holly on the small base manifold, used the '57 exhaust manifolds, added a Vertex mag, Then dropped it into a '53 Lincoln 4dr sdn. with the stock Hydromatic. In it's day one hell of a sleeper, especially on top-end, but very tame by your build(or so many others today)! The mid-range torque will surprise the hell out of you!!(suggest you read Smokey Yunick's theories about rod length vs stroke for an answer)
    loudbang and timmy2times like this.
  22. Ron Falk
    Ron Falk
    Ever since I was a little kid...I have had a thing for Torque. When I was 13 working at a campground...one of the guys there had a 70 chevelle with a 454...He gave me a ride ..and made it one to remember. Since that day...I have always wanted a motor that would rip the tires at 25 going through town(Bad huh..LOL) I think those memories drive people to build what was cool when they were very young...I know that's what drives me...and the history behind the old engines cant be beat..At a car show......all the older guys turn into kids..and share some pretty wild stories! That's what I really am looking forward to.Thanks for al the Input,I will post Pics as I get closer here in the next few weeks
    Ron from Frozen Wisconsin
  23. glrbird
    glrbird
    I hate to be the bearer of bad news, but those ram horns will not work if you are putting it in the Fairlane. You need rear dump manifolds or custom built headers.
  24. Ron Falk
    Ron Falk
    I guess making some exhaust flanges might be in my future too then...I guess I have some Ram horns to part with then..LOL Thanks for the heads up!
  25. glrbird
    glrbird
    If you are going to build headers, I would recommend fender well style, things are pretty tight with a y-block and isn't going to be any better with that engine. Time and patience, its all doable and will make a great street car.
  26. Ron Falk
    Ron Falk
    Things are bumping along in Lincoln land....and everything is in place to start ***embling this thing....except my flanges for the intake...hopefully next week i will have this block smoothed and ready to ***emble...its going quite well
    mrhp and loudbang like this.
