Saving a 32 Ford Body
Discussion in 'The Hokey Ass Message Board' started by rcnut223, Dec 11, 2011.
  1. flatford39
    flatford39
    Well I will tell you one thing that is a positive...you are not working with old rusty parts that you need to soak forever or apply heat to to get even moving in the right direction.
  2. rcnut223
    rcnut223
    from wisconsin
    You are correct, At least I am past that point ...:)
    concerned it could be a warped housing from when I welded the brackets on the rearend ...not sure how I check for that>>>
  3. Deucedreamer
    Deucedreamer
    from BC Canada
    I just read through your whole thread. Congratulations on saving a Deuce 5 window couple. You are indeed a very talented individual and should be very proud of yourself. I saw the pics of your 3 Window, damn, you don't make it easy on yourself do you? I hope you post a build thread on that one too.
  4. rottenleonard
    rottenleonard
    Most modern alignment equipment can measure if a rearend is bent. Also most large tire shops will check the alignment for free.
    Looking for a noise under load I would be suspecting an issue either the ring and pinion setup, or an issue with the gear contact surface.
  5. rcnut223
    rcnut223
    from wisconsin
    Well everything is back together again. Really did not find anything in the brakes although I changed shoes hardware and drums . Not driving the car as it's too icy outside
    I also pulled the right axle shaft , found 2 of these metal shavings on the end of the shaft. 003.JPG
      104.5 KB
      168.2 KB
  6. rcnut223
    rcnut223
    from wisconsin
    Took the car out today for the first time since the brake change
    No difference same issues
  7. rcnut223
    rcnut223
    from wisconsin
    So....
    Pulled the center section
  8. rcnut223
    rcnut223
    from wisconsin
    ImageUploadedByH.A.M.B.1454797053.302364.jpg i have a 3.00 center section that is a known en***y
    So I installed it ...
  9. rcnut223
    rcnut223
    from wisconsin
    ImageUploadedByH.A.M.B.1454797209.914777.jpg ImageUploadedByH.A.M.B.1454797232.381092.jpg
    Looks like a dirt track car
    Verdict .... Drum roll please
    Success ! Noise is gone
  10. JimmyD3234
    JimmyD3234
    from PA
    A- REAL - MAN -CAN - FIX - IT - HAVE - FUN ;) :cool::cool:
  11. rcnut223
    rcnut223
    from wisconsin
    You bet!!
    ****s that I will have to do this all again after sending the center section Back to get repaired
  12. flatford39
    flatford39
    Glad you found it. After all you have done on this car I bet you are relieved. I know I would be.
    Tom
  13. big duece
    big duece
    from kansas
    What the hell was rubbing in the carrier?
  14. rcnut223
    rcnut223
    from wisconsin
    Honestly don't know
    Can't see anything obvious
    Lots of br*** in the rear end grease way too much to be normal
    Also the pinion had started leaking , only been driven 5-6 miles tops
  15. brady1929
    brady1929
    Great job Mike.
  16. rcnut223
    rcnut223
    from wisconsin
    Tom, Yup relieved to say the least
    Thanks Brady
  17. big duece
    big duece
    from kansas
    o_OStill trying to figure out where the br*** is coming from.
  18. damnh6
    damnh6
    from australia
    Great thread have just gone from start to here .I will follow with interest !
  19. A Boner
    A Boner
    Did you drive it this summer? Got any pics? Nice save!
  20. wheeldog57
    wheeldog57
    The "br***", could it be the crush sleeve was crumpled too much? Maybe the pinion is rubbing on the pinion seal, creating the leak also
  21. rcnut223
    rcnut223
    from wisconsin
    Hi guys
    Here's a shot of it on the road this summer
    Rear 3rd member was swapped for a new one !
    mgtstumpy, greaser, kiwijeff and 11 others like this.
  22. damnh6
    damnh6
    from australia
    Hi I have just re-read the thread ,I am using a sedan roof also in my 32 coupe build .Could please explain what you meant by a slow curve in the sedan roof compared to the coupe roof and how you fix the difference ,thanks. the whole thread has been a great help and to myself and another friend doing similar really appreciate your efforts to explain and take pictures along the way , it has already saved us many hours of headaches and making mistakes. gary
  23. rcnut223
    rcnut223
    from wisconsin
    Thanks Gary, glad to hear this old thread is helping you and your friends
    I learned a lot and made many friends doing this project !
    As for the roof
    Let me see if I can find a picture that shows you what I mean
    But to verbalize :
    Sedan roofs can be used on a coupe but you will need to remove some of the area behind the side windows as well as the reveal. It's Fat so to speak when you look at them from the side
    On the top behind the rear roof opening it's a little long as well, this is easy to deal with
    Mike
  24. damnh6
    damnh6
    from australia
    thanks Mike for your reply .If you are able to post the picture showing what you have described that would fantastic,gary
  25. rcnut223
    rcnut223
    from wisconsin
    Gary
    Here are a few shots of a coupe roof and a sedan roof . This will give you a perspective on the differnce.
    The last image shows the are that will need to be removed (parden my wiggly fingers). It's not exact but it give you the idea.
    I will look for the actual images i have for this operation tomorrow evening.
    Thanks Mike
  26. rcnut223
    rcnut223
    from wisconsin
    Here is the key cut line shown on a coupe. I have also shown the key measurement you need off a coupe (arrow to arrow ). For what it's worth , in my opinion it would be easier to cut a fordor than a tudor sedan.
    kidcampbell71, 509garyd and loudbang like this.
  27. damnh6
    damnh6
    from australia
    Thanks once again for taking the time to post and explain ,gary
  28. rcnut223
    rcnut223
    from wisconsin
    Glad to help! FYI...I found the pictures I need to post for you. Will do so tomorrow night
  29. rcnut223
    rcnut223
    from wisconsin
    Here are the pictures I was talking about
    I will let them speak for themselves
  30. kma4444
    kma4444
    Just read this through from the beginning. Great stuff, great work.
