Projects Craigslist find 1927 Model T Fordor
Discussion in 'Traditional Hot Rods' started by rab71, Oct 11, 2016.
  1. themoose
    themoose
    @rad71
    I'm looking forward to watching your build come together,gonna make a great looking ride.....Here's the green version that you requested.
    kidcampbell71, kiwijeff and rab71 like this.
  2. rab71
    rab71
    Haha thanks. I knew mine was a 27 anyway. Honestly it's not like it matters. It's what it will be is more important. And it will be a hot rod.[emoji16]
  3. rab71
    rab71
    Wow! That is perfect! You really hit this one out of the park. Thank you!
  4. manyolcars
    manyolcars
    I like the 26-27s. I wish you well on the build. Henry closed the factory in April of 27 to start on the Model As so without looking for production numbers I am sure he made more 26s than 27s. I think the inside door panel was slightly different
  5. rab71
    rab71
    I can see the production numbers plain as day. I should take a picture and post it. If I can make it to my storage unit where it is I'll do that.
  6. manyolcars
    manyolcars
    rab71 likes this.
  7. rab71
    rab71
  8. rab71
    rab71
    To the guy that messaged me about length and width. I went out today and measured it. It is about 89x53 inches give or take. I was short on time as I snuck out of work to do it. And the more I look at the body the more it grows on me to just leave it original. Cleaning up the surface rust and matching to the original paint... [emoji848] dangit... that's why I'm not doing a thing until I get my **** together.
    patmanta likes this.
  9. rab71
    rab71
    Got some wheels and tires,a frame, and a steering box from a 52 Ford in great shape. Some spindles too. Gonna be slow going, this stuff isn't cheap. [​IMG]
  10. patmanta
    patmanta
    from Woburn, MA
    That a TT frame?
  11. rab71
    rab71
    Yep sure is[emoji6]. It's stronger than a model a frame super thick metal. It will still need to be modified for my application but I couldn't beat the price and the shape it's in.
    Jimmy B likes this.
  12. patmanta
    patmanta
    from Woburn, MA
    That's PERFECT. That will be a lot simpler for you than trying to get that body working on an A frame.
  13. daredevilcustoms
    daredevilcustoms
    from Ohio
    I know you're just starting the build, but I'd be interested in the upholstery material and door panels if you're not going to use them as long as they are the grey with red pin stripe. Thank.
  14. rab71
    rab71
    Thanks! After doing a little research that is what I found out. The car will not sit "low" I'm not even going to channel it. I want it to sit at a rake. I do have a drop axle. I was told it was built in the sixties. Which is the era I'm trying to go for. I have not decided in coilovers and ladder bar/hair pins , or spring and split bones/hair pins or what for rear suspension.
  15. rab71
    rab71
    They are grey, I don't recall the red pinstripe though. The seats need to be reupholstered. Everything else is is pretty mint. To be honest I hadn't decided what I was going to do. I would like to do black vinyl. Minimum on the seats. I like the clean simple look. Not sure about the doors and headliner yet. They are in such good shape, I may leave them. I will definitely keep you posted.
  16. I wanna say, I hate you, haha.
    You deserve some type of award, for, starting with such a clean body, and for what you payed for it.
    I'm jealous, you did real good, and I'm real keen to watch this build.
    I also liked the part, where you sent the seller a pic of the cash in your hand.
    rab71 likes this.
  17. Sakke
    Sakke
    from Finland
    Your T looks really great ! An old Aurora model kit " Hi-Stepper " came to my mind immediately. Sorry can`t post a pic, but do a google search if interested.
    rab71 likes this.
  18. rab71
    rab71
    Yeah I am very lucky. I almost feel guilty not restoring to original. Really hoping not to **** this up. I've done a couple cars most would probably consider rat rods. Here is my current.[​IMG]
    This next one with the T will be much nicer. Really want to keep with the correct era as close as possible. I wish I could move faster on it but I have a kid in college and another in Highschool. They ain't cheap!
    Thommyknocker and kiwijeff like this.
  19. rab71
    rab71
    I will look that up, thanks! Currently I get a lot of my ideas from old 60s hot rod magazines. And this website.
  20. rab71
    rab71
    kidcampbell71, slv63 and kiwijeff like this.
  21. ct1932ford
    ct1932ford
    Very Nice! Go Man Go!
    rab71 likes this.
  22. Here's a center door T I built a few years back, in 1/24the scale, just for fun. IMG_20161116_140614.jpg IMG_20161116_140633.jpg
    kidcampbell71, slv63 and rab71 like this.
  23. rab71
    rab71
    kiwijeff likes this.
  24. 31 Coupe
    31 Coupe
    bondojunkie likes this.
  25. That T looks strange on a drag strip. :eek:
    BTW, it's not a 4-door. ;)
  26. rab71
    rab71
  27. roddin-shack
    roddin-shack
    Before You Get Too Far Along I would Suggest You Get A ***le For It, If You Do Not Already Have One. Good Luck With The Build.
    czuch likes this.
  28. rab71
    rab71
    I can ***le it any time in WI. It's easy here. Just gotta pay the man for the paperwork.[emoji6]
  29. roddin-shack
    roddin-shack
    Thats good for you, I suggested it because here they make you pay the tax on the car value as it stands. They make you get an appraisal on the value and that is what you pay. So it is better to get it ***led before the work starts.
  30. rab71
    rab71
    I understand that completely, thank you. If I had a ***le I would buy one. It's no rush. I am not starting to put anything together until I have all parts. This will be quite a while. No rush.[emoji106]
