Projects The george shull special 33 ford pickup
Discussion in 'Traditional Hot Rods' started by john dioli, Sep 19, 2016.
  1. wheeldog57
    wheeldog57
    Holy backyard reverse eye spring, batman! I WILL be using that "high tech" vise trick. Thank you very much for that pic of your vise- great, simple ingenuity. Build that truck the way YOU want and enjoy the hell out of it
  2. rusty1
    rusty1
    if that's a sunroof, I'd loose that first!
  3. john dioli
    john dioli
    Wheel dog it was very easy put a line on spring every inch or so, then put spring in vise and it only took about three turn of the vise at each line and prolly five p***es total to reverse it.
    Rusty when and if i go the body that sunfoof is the first to go.
    wheeldog57 likes this.
  4. Neat time capsule, only thing that would bug me is the sunroof. I'd fill that and blend some paint in. Very cool ride, dig the wheels as well.
  5. SkyDriver
    SkyDriver
    John, thanks for taking good care of George's truck. He and Nancy have been great friends of ours since the Over the Hill Gang was formed in 1973. He was originally in the San Bernadino chapter while I was in the San Diego group. They moved to east San Diego County in the late 70's. The truck was a red/orange color back then (as I recall), but otherwise pretty much the same as you received it. The truck did receive an award at the first STREAK (1974), but I don't remember what for. George and Nancy also drove a gold colored '40 Ford Tudor in the 70's and early 80's.
    Obviously, it is now your truck to do with what you please, but (IMHO) if you change the wheels and two tone it, it'll be just another truck.
  6. Richard Head
    Richard Head
    If you cut the 32 bar just inside of the headlights, you can pivot the curved portion out just enough to clear the pickup grille shell. Just make sure your fenders/braces are tight and adjusted for fit first.
    Dave
  7. sawbuck
    sawbuck
    from 06492 ct
    x2 thats what i did on my 34...
  8. john dioli
    john dioli
    Yes
    yes I agree I have decided to leave truck as is just changing headlights and bar other than that it will stay as it always has been I talk to nancy once a week or so so if you like I can say you said hi . Just need your name
    John
  9. john dioli
    john dioli
    Thanks d
    Thanks Dave once I get it back together I will work on the bar
    John
  10. SkyDriver
    SkyDriver
    Bill Hogue
  11. john dioli
    john dioli
    well a little update I'm STILL waiting for my axle in its third month (all I want for Christmas) anyway I decided to check the wishbones good thing I did.
    Who has ever seen a co**** thread tie rod before, what they did was welded a nut into wishbone and got some all thread then welded the tie rod end to that scary but worked for over 40 years
    new bungs and tie rods
  12. john dioli
    john dioli
    well i finally have a lot of progress on the truck, the axle is done and looks great and Dennis did a fantastic job on the tie rod and spindles, I modified the headlight bar ended up cutting out the center section and welding in a new piece of stain less , gave it its first cleaning in 10 years and now she is ready for the havasu dueces show in havasu
    john
  13. *****in' !!!
    john dioli likes this.
  14. hotrodA
    hotrodA
    Great truck! Sent you a PM.
  15. john dioli
    john dioli
    Just saw PM will do and thanks
  16. CharlieLed
    CharlieLed
    How did it go at The Streak this weekend?
  17. quickrack-alan
    quickrack-alan
    from Ireland
    All the photo links are broken.
    Damn shame as I'd like to see the truck.
    studebaker46 likes this.
