Technical 37 chevy glovebox door
Discussion in 'Traditional Hot Rods' started by Bruski, Nov 20, 2016.
Tags:
  1. Bruski
    Bruski
    I am having trouble finding a door/hinge ***y. complete w lock/ knob...will other GM model cars, say Buick or Olds interchange?? Are 39 or 40 chevy the same?? I've been told 37's are rare and bring $$$$. Thanks, Bruce
  2. uncleandy 65
    uncleandy 65
    The 37 and 38 Chevy are the same size. These are the only ones that will work. If I remember right the stainless trim might be a little different. And yes they are hard to find and most times the hinge piece is missing. These were hard to find back in the late 80's when I was building a 38 coupe. The standard model didn't have a hole for the clock and some had a hole but there was a clock delete plate in it. Keep looking there are some still out there.
  3. Bruski
    Bruski
    Thanks...your info is what I suspected..but I had hoped other ones might work because they are easierto find...prior owner cut up door to mount a radio in it and used it as a cover and screwed it on...I don't need a radio...
  4. David Gersic
    David Gersic
    from DeKalb, IL
    Chevs of the 40s has the hinge:
    https://www.chevsofthe40s.com/detail/13660/Chevrolet_Hinge_***embly_Glove_Box_Door.html
    Speedway has a door:
    http://www.speedwaymotors.com/Speedway-1937-38-Chevy-Car-Glove-Box,46435.html
  5. David Gersic
    David Gersic
    from DeKalb, IL
    Funny, I have that too. Did they cut the centre out of your dash to install a billet aluminum panel too? That seems to have been a thing in 37 Chevys for a while.
    I have a cowl & dash here that want to use to fix that on mine. Don't yet have the tools of skills to pull that off yet though.
  6. Bruski
    Bruski
    Thanks for the links.....yes my dash has been modified, badly, want to try and get it back to somewhat original looking..don't want the billet look...the hinge looks good though..thanks, Bruce
  7. lonejacklarry
    lonejacklarry
    I have a door and a delete plate but no lock! If anyone finds one, see if there is another, please.
  8. Bruski
    Bruski
    I haven't found a lock/knob ***y yet...checking salvage yards also for parts....alot harder now days...
  9. lonejacklarry
    lonejacklarry
    I'm close to the point where I need to find an alternate. Not exactly a technical piece there.
  10. David Gersic
    David Gersic
    from DeKalb, IL
    Maybe just fix the door you have? Mine has a radio size hole in it, but is basically a flat surface so may not be too hard to patch. Or you could paint the Speedway one. I kinda like the decorative stamping on it, might look good painted and pinstriped.
  11. Bruski
    Bruski
  12. Bruski
    Bruski
    I've had thoughts about fixing the door...knowing now where to get the hinge ***embly..my Guage cluster has woodgrain inlay...maybe do the same to the box door...something to think on..
  13. vtx1800
    vtx1800
    I wasn't able to find the correct lock for my 38 glovebox either. Since it's been 30+ years since I found the latching mechanism I don't really remember what it came off of. I am thinking it may have been off the 50s era General Motors car, it doesn't work real well but at least it latches
    Bruski likes this.
  14. David Gersic
    David Gersic
    from DeKalb, IL
    Might look cool. My gauges are currently in ball milled aluminum billet. Going to change that to an engined turned insert.
    Bruski likes this.
  15. Bruski
    Bruski
    I found a complete ***embly w hinge, and knob/lock at a out of state salvage yard...a plain door with out any trim.. $300.00....seems high to me...it will need total restoring....????
  16. tb33anda3rd
    tb33anda3rd
    you need it, there are not a lot of them around, someone has stored it for the last 70+ years, it's been taken off and will be sent to you. hmmmm, what would you have thought it is worth?
    prewarcars4me and Bruski like this.
  17. K13
    K13
    I just reskinned mine was easier than trying to patch it.
    Sent from my HTC One_M8 using The H.A.M.B. mobile app
    Bruski likes this.
  18. 49ratfink
    49ratfink
    there are seven in ebays "completed listings". there is one listed right now, along with a "billet" one as well.
    Bruski likes this.
  19. K13
    K13
    tb33anda3rd and Bruski like this.
  20. Bruski
    Bruski
    I've seen complete ***emblies for Olds and Buick for around $100.00...that's why $300 seemed high..just saying...there was one on ebay with clock and trim w lock sold for $300...thought plain door would be less..
  21. David Gersic
    David Gersic
    from DeKalb, IL
  22. K13
    K13
    Just going to use a magnetic latch and the hole for the knob I am going to install was not drilled at this point.
    Bruski likes this.
  23. David Gersic
    David Gersic
    from DeKalb, IL
    Ah, whoops. I thought this was a pic of the original the OP found for sale. This is the one you reskinned. Nice job on it. I'll probably attempt something like this with mine.
  24. green53ford
    green53ford
    from Wisconsin
    Its been about 30 years but I seen to remember a jeep wagoneer glove box lock was a direct fit.
    David Gersic likes this.
  25. Bruski
    Bruski
    I'm in no hurry to spend $300 yet on an original door ***y..I'm going to get the repro hinge sssy. from Chevy's of the 40's though..I am thinking of rebuilding my existing door after seeing K13's door. I've got all winter to work on this..thanks for all the help and info,
    Bruce...
  26. rusty1
    rusty1
    ...here's my temporary fix, I used a wiper knob from a 50 Chevy p.u., bent the tang, bolted on an extention and it works, no lock function tho.
    Bruski likes this.
  27. Bruski
    Bruski
    I've seen some innovative knobs used for glovebox"s...on a variety of cars at cruise in's and shows...one car had a chrome lighter knob for pull knob..many options there...
  28. David Gersic
    David Gersic
    from DeKalb, IL
    I like the handle. I wonder if it could be mounted to something like a VW bug glove box door latch.
  29. photo 2.JPG I Know it is not a Chevy but I was missing a glove box door on my 39 Ford dash and just made one. Was not too hard.
    Bruski likes this.
  30. Bruski
    Bruski
    Wonder why so many glovebox doors go missing...hmmm?
