Projects 1931 Model A Coupe Y-Block Build (Father&Son)
Discussion in 'Traditional Hot Rods' started by NathanxStewart, Jan 4, 2016.
  1. Thanks roger!!
  2. y'sguy
    y'sguy
    from Tulsa, OK
    So what's the latest?
    NathanxStewart likes this.
  3. Sorry haven't had much to update about, just been doing some small stuff. But I did just put the final coat of primer on the body, i'm going to be driving the car just with primer and I'll finish the body work and paint it shiny eventually
  4. Final coat of primer is on! Going to repaint some of the inside, I'll post some inside shots later, then going to paint the firewall white. Almost time to put the body on the ch***is!!
    dwollam, D-Russ, loudbang and 4 others like this.
  5. Blue One
    Blue One
    from Alberta
    What kind of primer are you using ?
    Just as a cautionary note, some primers will allow water to be absorbed through the primer and also the body filler will absorb moisture too.
    Rusting will start where you can't see it and then will appear later on after the shiny paint is applied.
    If you have any questions on this contact Paint Guru on here.
    loudbang and NathanxStewart like this.
  6. metal man
    metal man
    That's a good quality DTM epoxy primer, and there's no filler on the car at this point. It's well protected.
    loudbang, NathanxStewart and Tim like this.
  7. Blue One
    Blue One
    from Alberta
    That's good
  8. Yeah it's summit racing epoxy primer, good stuff!!
  9. Inside of the car painted and will be painting the firewall white probably Tuesday night, want the epoxy primer to completely cure before painting over it. Then it's time to put the body on the ch***is!!
    dwollam, Dino64, D-Russ and 2 others like this.
  10. Hunter73
    Hunter73
    Oh man. It looks terrible. I tell you what...just send it to me in Texas so you don't have to look at it anymore. Heck, I'll even pay for shipping.
  11. loudbang
    Man you are moving right along on this beauty. So happy to hear it will be SHINY some day.
  12. Hahaha that's very generous of you! The thing is, I haven't stopped looking at it yet [emoji6]
  13. Thank you! Some day it will be! As soon as I decide what color, but for now I'm going to drive it like that. No ****ty rat rods here. I take pride in my work!
  14. Fire wall is white, body on the ch***is next!!
    dwollam, cretin, Dino64 and 3 others like this.
  15. greaser
    greaser
    Firewall looks great. Is that Wimbledon White?
    NathanxStewart and loudbang like this.
  16. thall
    thall
    from nc
    read this start to 'now' and sitting here totally amazed at craftsmanship and skills displayed. Love it...
    I do have one question/observation I'm trying to figure out. I noted the rear differential housing seems biased to the p***enger side ~2" or so... wuffo? just wish to educate myself.
  17. metal man
    metal man
    It's because he built the car from my leftovers. We had a '57 p***enger car 9'' housing, which we just used the center of. We also had two big bearing 31 spline axles, that were from two different rear ends, but when put together were the right width for this car. We also had a 31 spline 4.1:1 pumpkin with trac-loc that we wanted to use. So, we put it all together with new tubes and truck housing ends from yet another 9" that was laying around. Hot rod recycling[emoji2]
  18. Thank you! And no it's just a ford truck color from the 80's
    greaser likes this.
  19. Thank you!! Really appreciate it
  20. Having a lift is awesome
    Body is on the ch***is!! Such a good feeling!!
    Some small things left to do then it's time to wire it!
    crozch, 54reno, tomkelly88 and 16 others like this.
  21. Tim
    Tim
    from KCMO
    Hell yes!
  22. Oh wow! It's starting to look like a car! (A very nice car!) You've come a long way. :)
  23. Tim
    Tim
    from KCMO
    Fun to study it as it gets closer and closer to a full vehicle. The first thing that jumps out at me is the push bar/ nerf coming out of the panel instead of coming from under it. Keeps the car looking trim.
    Curious if your louvered visor will let some of that pressure under it out.
    Man....
    Can't wait to see the video of it getting sideways :)
  24. bengeltiger
    bengeltiger
    x2^^^
  25. Schwanke Engines
    Schwanke Engines
  26. Dino 64
    Dino 64
    from Virginia
    The rear wheels are positioned perfectly in relation to the width of the body. What's the track width between the rear tires ? Great build, thanks taking us along for ride. [emoji106]
  27. hotrodderhaag
    hotrodderhaag
    19 pages of pure excellence . Very nice. Very well built! great job!!!
    crozch and NathanxStewart like this.
  28. Thank you!! I'm getting really excited now
  29. Thanks Tim!! The louvers will allow the air to escape that gets trapped under the visor but they're mostly there just to look cool honestly hahah. Hopefully soon you will!
    Tim likes this.
  30. Thank you sir!!
