History Steel Wheel Identification - Mystery
Discussion in 'The Hokey Ass Message Board' started by Grudge, Nov 9, 2016.
  1. Grudge
    Grudge
    Hi all,
    I bought a 60 F100 (5-1/2" stud spacing) and it has an unidentified set of steel wheels. No provision for center hubcap and no stampings that I can see. I ***ume it's an aftermarket wheel of some sort intended for full hubcaps, but maybe not..
    Has anyone seen these before and can you identify their origin? Just trying to solve the mystery.
    Thanks,
    Aaron
  2. Atwater Mike
    Atwater Mike
    I've seen a wheel like that on a "General Purpose" Jeep, (15" X 5", 5 on 5.5" pattern, plain center, no provision for small caps; 'solid' construction (no 'windows' spaced between the center and rim; 'Solids' is what the wheel vendors call 'em)
    I noted the large center bore, also.
    gas pumper and Asphalt Demon like this.
  3. junkman8888
    junkman8888
    I have two just like it, my understanding is they are early '60's Ford pickup
  4. 302GMC
    302GMC
    from Idaho
    Lincoln ...
  5. Asphalt Demon
    Asphalt Demon
    from Australia
    I have some too!
  6. Asphalt Demon
    Asphalt Demon
    from Australia
    lincoln have clips
  7. stillrunners
    stillrunners
    from dallas
    no....Lincolns also came without clips for those full wheel caps.........two guys for Lincolns...they are not Imperials....
    Asphalt Demon likes this.
  8. Mrmeenyo
    Mrmeenyo
    I like those better than the wheels that came on my 61 F100. I can't wait to get rid of these! [​IMG]
  9. Rocky
    Rocky
    Classified Editor
    Lincoln....had em on my 50 lido coupe. Made for full wheel covers.
  10. Grudge
    Grudge
    Sorry for the late reply, thanks for all the responses. I guess Lincoln did some weird stuff back before global corporate platforms and bean counters took over. Only bummer is that I can't run a center cap :(
    Aaron
  11. junkyardjeff
    junkyardjeff
    They were doing it in the 80s,the 80s crown vics that came with full wheel covers had similar rims that no small cap could be put on. Only the police cars came with the good rims.
  12. 302GMC
    302GMC
    from Idaho
    Of course you can run hubcaps ... look at the bumps on a Ford pickup or pre '48 car, then mark the Lincoln wheel where the bumps go. You can weld the bumps on & dress them, or drill 3 or 4 holes a couple sizes under 1/4'' where they go & tap for 1/4'' x 20 round head screws ... use stainless ....
    Close inspection of some '60s Peterson magazine cars show Merc wheels with Ford truck baldies using these methods.
  13. Grudge
    Grudge
    Thanks for the idea.
    Aaron
