Technical Engine Painting
Discussion in 'The Hokey Ass Message Board' started by TagMan, Nov 23, 2016.
  1. TagMan
    TagMan
    I've always used rattle cans for painting an engine, but I want to try using a PPG single stage urethane this time. I was planning on shooting DP40LF epoxy primer on first, but a friend said to just shoot color on the bare block. Is epoxy primer on cast iron a no-no for some reason ??
  2. chopolds
    chopolds
    from howell, nj
    I've heard that on cast part, no primer is necessary. On sheet metal ones, yes. Personally I use a thin coat of epoxy on all the engine parts. It has better adhesion than paint, evens out the coloring, and can smooth it out a bit. You can't go wrong with primer. Just keep the entire paint film as thin as possible. SS urethane is a great paint for engines, as is BC/CC, Centari or polyurethane.
  3. squirrel
    I've done a couple with acrylic enamel, over bare iron. Seems to work fine.
    I don't like seeing primer spots when the paint gets chipped....same on frames, I just paint black over the steel, no primer.
  4. rocketsled59
    rocketsled59
    Epoxy on any bare iron or steel. Just get it clean. Done many restos that way. Unless you have an industrial dtm paint you can't expect any real durability by applying automotive paint to bare metal. 32 yrs exp speaking. RS59
  5. squirrel
    that engine I painted with Centari 25 years ago still looks pretty good...
  6. AMC360
    AMC360
    from Canada
    I used an epoxy primer and painted my flathead base clear. Turned out great
  7. firebrrat
    firebrrat
    Look at por 15 paint I absolutely love it and have been painting all my engines with it 1479971878526.jpg
    Sent from my SM-G900V using The H.A.M.B. mobile app
  8. mgtstumpy
    mgtstumpy
    Etched first and light coat of primer before painting..wet rubbed
  9. chopolds
    chopolds
    from howell, nj
    Even Pearl White is possible, using House of Kolor urethanes.
    modelkitbasher likes this.
