Projects Took the first drive today
Discussion in 'Traditional Hot Rods' started by texkbc, Sep 13, 2015.
  1. GASSERBOB
    GASSERBOB
    from USA
    You did one hell of a job. For what that body looked like. Car is looking bad ***.
    texkbc likes this.
  2. Nick O
    Nick O
    from Ohio
    looking real nice!!!! congrats on your first ride, you will enjoy many more
    texkbc likes this.
  3. dirt t
    dirt t
    This post is what happened to me on first drive, after the thrill of the first drive brings you back to reality do a through inspection of all suspension bolts steering and check rearend for proper grease level .
    texkbc likes this.
  4. texkbc
    texkbc
  5. texkbc
    texkbc
    Putting in a floor this weekend
  6. texkbc
    texkbc
    [​IMG]. Cut out from a model t running board
  7. 2bubbas
    2bubbas
    Looked great! I sure like the look!
  8. texkbc
    texkbc
    [​IMG]. Having some fun now
    heavydumper, flyin-t, Merge and 6 others like this.
  9. Jibs
    Jibs
    Look up Bad*** in the dictionary ^^^^this picture will be there!!
    texkbc likes this.
  10. texkbc
    texkbc
    [​IMG]. [​IMG]. Couple more pics from my drive Sunday
    heavydumper, flyin-t, cfmvw and 2 others like this.
  11. Runnin shine
    Runnin shine
  12. Krash
    Krash
    from Cleveland
    Sinister looking! Congrats!
    texkbc likes this.
  13. texkbc
    texkbc
    Runnin shine likes this.
  14. cfmvw
    cfmvw
    Looking forward to hearing more about it; really like your car, it has a lot of character and soul.
    texkbc likes this.
  15. A Boner
    A Boner
    Screw painting it.....just buy a case of Gibbs oil!
    texkbc likes this.
  16. Gary Addcox
    Gary Addcox
    Man, those '57 9" rears were MADE for '34 Fords. They fit better than the original banjo. You have really come a long way. Hope to see you at LSRU next April. Be lookin' for ya.
    texkbc likes this.
  17. Gary Addcox
    Gary Addcox
    By the way, you must be related to Cyclone and paintslinger. All three of you have done so much with so little.
  18. Gary Addcox
    Gary Addcox
    That "kid in a candy store" feeling doesn't go away with age. In 2010, at 64, I felt it as I drove my Deuce for the first time.
    texkbc likes this.
  19. Gary Addcox
    Gary Addcox
    In some earlier pics, I remember that roof looked like my Grandmaw's rub board. You did great with your "hammer" from a welding gas cap.
  20. Gary Addcox
    Gary Addcox
    I agree with HRP. Most bodies in this condition would only be resurrected by professional bodymen. You have certainly earned this fellow Texan's respect.
    texkbc likes this.
  21. texkbc
    texkbc
    flyin-t and Jeff34 like this.
  22. texkbc
    texkbc
  23. texkbc
    texkbc
  24. bschwoeble
    bschwoeble
    Welcome to the real world of hot rodding. Not many of you (us) left.
    texkbc likes this.
  25. Okie Pete
    Okie Pete
    I was amazed that you saw a car in the rotting pile you had . Then you built a car out of it . But what blew off my hat was you dropped in a Y-block for power . I want to shake you hand and hand you a cold beer.
  26. dirt t
    dirt t
    texkbc likes this.
  27. loudbang
    "Y" block looks like it belongs there.
    texkbc likes this.
  28. Tim
    Tim
    from KCMO
    Great hot rod!
    texkbc likes this.
  29. continentaljohn
    continentaljohn
    What a great build and amazing budget . This is why I love the HAMB jalopy journal. ="texkbc, post: 11162090, member: 32553"]Thanks, and this may sound dumb but I built this from knowledge that I gained totally from the HAMB. I have never built a car before. I learned from all the great build threads that have been posted. I know this is not a top notch car but I would never have even attempted this without seeing some of the examples on this site. I did all the work myself and stayed well below $10k. I tried to use original parts and traditional methods.
    Build list
    Chopped 4”
    Original frame and cross members
    Flattened rear crossmember and used a 1940 Ford spring
    Original front spring – reversed
    1934 ford wishbone split
    Orig Ford Axle – dropped 4” by Joe’s Hot Rod Shop
    1934 Ford front spindles
    F1 steering box and column- modified flange
    1939 Ford Brake/Clutch pedal
    1957 Ford nine inch rear , rebuilt brakes
    Modified early dodge truck shock mounts for front with Model a headlight bar ends for headlamps
    Vintage Guide headlights
    1956 272 Ford y block with t-5 ******
    Ford 16” steel wheels and trim rings
    Original speedometer
    Original grill
    Original Ford Hood
    Original E brake handle
    1932 Ford pitman arm
    Original Ford s**** gas pedal
    1936 rear radius rods
    New front backing plate ***emblies from SO-Cal
    Porter mufflers
    Walker Radiator
    New fuel tank from Bob Drake
    Master cylinder –Bob Drake
    New fuel and SS brake lines –Speedway
    Fuel,oil and temp gauge –Stewart Warner (new from Speedway)
    Painless wiring harness
    Front and rear shocks from Speedway
    Rams horn exhaust - Speedway[/QUOTE]
    Doesn
    catdad49 and texkbc like this.
  30. jvpolvere1
    jvpolvere1
    texkbc likes this.
